VWVortex.com - Tdi into mk2 1.6na diesel
    Results 1 to 5 of 5
    Thread: Tdi into mk2 1.6na diesel
    1. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      95 gti 24vt toy, 04 tdi golf economy, 94 gti 12vt sold
      04-27-2012 10:31 PM #1
      Alright so I just went through the threads and didnt see much in the way of this swap. As we all know diesel is starting to become the best way to go but we also know the 1.6na diesel blows.
      Weve got a 97 passat tdi with only 170k on it (still new) Right now theres a debate on wether the sub frame is going to fit from the passat into the mk2. I've read that its wider slightly while at the same time some will claim it to work.
      We're a few days away from clearing away some room in the shop (hoist is blocked big time by tires) but it'd be nice to have some opinions on the matter. I will get some measurements and pictures when the hoist is open.
      Got a lot of stuff on the go. Might just make this a build thread so stay tuned.
      diesel life cause cold feet are fun....
    2. Junior Member
      Jan 24th, 2012
      Oakville Ontario Canada
      2001 TDI ALH Jetta daily,94 ice violet grey vr6 corrado, 1990 1.6d golf
      04-28-2012 01:39 AM #2
      best swap in the world
    3. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      A6 TDI Quattro wagon, A4 TDI Quattro racecar
      04-28-2012 06:42 PM #3
      Don't bother with the subframe - just swap the motor & trans over with ancillaries, including shifter and pedal box. Keep the mk2 subframe, suspension & axles. The Passat wiring should be almost P&P in a CE2 mk2 too, although not so much for a CE1.
      Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
    4. Member masterqaz's Avatar
      Oct 4th, 2007
      Oakville Ont
      04-30-2012 01:11 AM #4
      Sucks that the subframe is rotten in the mk2.
    5. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      04-30-2012 05:42 PM #5
      Ah shame. I think the Passat one is wider. The mk3 one fits if you grab the rear motor mount and bracket.
