Results 1 to 6 of 6
Thread: Going standalone
  1. Member masterqaz's Avatar
    Oct 4th, 2007
    Oakville Ont
    94 JTI Vrt 60-1 .58ar exh obd2 440 racefile 20psi/meth
    04-27-2012 09:36 PM #1
    So Ive got the oppertunity to build a nice ice violet grey corrado and it'll be running dta standalone. Havent really dealt with these before but I had one question regarding the old factory wiring.
    What do I do with it. Pull all the engine wiring and unplug it from the fuse panel?
    Just want to be sure. Sounds right in my head.
    Forced convection.... Now we grillin.
    Some times she goes, some times she doesn't.... Way of the road
    Rem 870 super mag in max 4 camo for sale. Pm me
  2. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    04-27-2012 10:33 PM #2
    I just removed the Digifant ecu and it's wiring harness i still use the oem harness from the fuse panal for fuel pump, head lights/fog/turns, abs,wipers ect.ect.
    500HP 1990 Cowrado
    Nov 19th, 2008
    Atlanta-Chicago
    92 verde rado gernade(dd),90Q 20v, red rado 16vt(in progress)
    04-28-2012 08:42 PM #3
    Quote Originally Posted by REPOMAN View Post
    I have to say I like your build(s)
    I will be running also 034 efi(Ic) on my 16vt setup, did you use 034 relay panel too? And did you run stock fans setup with stock wiring for the fans?
    Wiring not a issue for me, I like oem setup much as possible.
    I know vems-lugtronic uses factory harness as plug and play system and make new wire harness with new ECM. So does 034 as making custom wire harness. That some cool stuff. I like 034 products bc always had good feedback from them.
  4. Member
    Nov 19th, 2008
    Atlanta-Chicago
    04-28-2012 08:46 PM #4
    Quote Originally Posted by masterqaz View Post
    I know few guys just cut the ECM harness and spliced standalone harness for power and ground and other vital signals for the cluster. Some just make new fuse- relay box for standalone system too.
  5. Member GTijoejoe's Avatar
    Oct 5th, 2001
    OH
    '98 GTi, '06 Evo Mr
    04-29-2012 02:35 AM #5
    I just cut the harness on the engine side, everything else is still there for me.
    2.0T+034efi+meth = 300+whp = Part out PM me for anything
  6. Member REPOMAN's Avatar
    May 3rd, 2001
    Portland OR
    1990 VW Corrado
    05-02-2012 12:59 AM #6
    I mounted a fuse panal under the hood and run fuel pump relay, ECU, I/C pump and Injector power
    from it. I wired Aftermarket fans threw the 2 wire fan switch on the radiator and power it from the positive on the starter and ground it to the ground stud. in the pic on the driver fender behind the I/C is the small fuse panal.
    500HP 1990 Cowrado
