VWVortex.com - 2L 16v swap into mk1 Help!!?
    Results 1 to 5 of 5
    Thread: 2L 16v swap into mk1 Help!!?
    1. 04-27-2012 10:26 PM #1
      Hey guys. so i swapped a 1992 passat 2L 16Valve into my mk1.. on the 8v there was a spot for my warm up regulator / fuel regulator which ever you prefer calling it.. to be mounted but I cant find a spot to mount it on my 16valve. any suggestions??? lemme know thanks!
    2. Member Jones84's Avatar
      Sep 5th, 2007
      Gresham Oregon
      84 GTI 2.0 High comp 16vT on MegaSquirt, 00 Subaru Outback
      04-28-2012 02:10 AM #2
      You need to use the ECU and Knock box out of the Passat. As well as the fuel dist and lines. the 2.0 16v fuel injectors are diffrent from the 8v as well as the timing. It will run on the 8v stuff but not well. to get the most out of the swap change it all..
      84 Rabbit GTI, 12.1.1 comp 16VT, 15psi 307whp 278wtq Winner 2012 bugRun Pro class
      JONES PERFORMANCE VW, Swaps, Custom Builds, MS install & tuning. MK1, MK2, Specialists
      2vwjones@gmail.com Website under construction.
    3. 04-28-2012 02:36 PM #3
      Im just running CIS basic with the 16v. Which from what other people have told me it will work.
    4. Member ps2375's Avatar
      Aug 13th, 2003
      Meridian, ID
      80 Rabbit(DEAD), 94 Golf, '69 Type1 Sedan
      04-28-2012 04:50 PM #4
      Just need the knock box and TB switches and the fuel lines w/ injectors. We had a donor 16V scirocco. The motor did very well on the CIS. We were not worried about cold starts, we just wanted consistant fueling, and mounted the WUR where the battery would've been along with a coolant catch tank we had mounted there.
    5. 04-28-2012 10:09 PM #5
      Okay thanks!
