VWVortex.com - all motor build
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 29
    Thread: all motor build
    1. 04-28-2012 01:51 AM #1
      im looking for any helpful info or ideas to add to my build
      tt =3 intake +2 exhaust valve kit
      tt 288 cams
      megasquirt 3
      2.9 clone
      ported exhaust manifold
      tt 2.5 down pipe to 2.5 catless exhaust with duel side exit turbo mufflers
      ported tb
      stock rebuilt bottom end
      10lb flywheel
      ford coilpack conversion
      copper plugs
      autotech shock therepy wires
      gutted interior
      quaife lsd
      i have all of this exept mega squirt and i was wondering if anyone had any ideas what else could help my build make more power im not going to turbo this car i want to push the vr6 motor and see what i can produce
      thanks for any input
    2. Banned vento86's Avatar
      Oct 13th, 2008
      04-28-2012 10:03 PM #2
      You would be lucky to see 200+ horse. I had pretty much the Sam mods( minus mega squirt) and my car made 198
    3. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      15 Jetta 92 Corrado VR6
      05-02-2012 08:36 AM #3
      I hit 198whp no matter what I did I would consider a different intake manifold if your goals are above 200whp.
      -Paul
      1992 Corrado - ALL MOTOR Drag Project
      1995 GTI VR6 - Retired - 12.90@106 R32 power - 12.833@106 12v power
      KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    4. Member root beer's Avatar
      Jun 22nd, 2004
      Linthicum, MD
      96 Harlequin Golf 98 Tacoma 4wd
      05-03-2012 02:11 PM #4
      Yea, that intake needs to go if you're going to MS.
      I wouldnt go with that valve kit.
      13.33@101
      All Motor, Daily driven 12v Harlequin
    5. 05-04-2012 12:04 AM #5
      stock valves size is the best with those tt cams.....
      a short runner intake manifold will put you at over 200whp with the proper tune.
      Racing Improves the breed..
      "I have fought the good fight, I have finished the race, I have kept the faith"- 2 Timothy 4:7
      CrossroadsLI
      MY ALL MOTOR BUILD THREAD
    6. 05-08-2012 10:36 PM #6
      i dont see how thats possible techtonics tuning had the same all motor set up minus the ford coil conversion and autotech wires making 278 whp and running 11.5s iv seen the videos and colin at techtonics said the cam and valve combo nets about 45 hp so theres no way im not breaking 200 cause im dynod at 201 right now with bolt ons and a stock motor
    7. 05-08-2012 10:39 PM #7
      [QUOTE=sundayshadow;77299555]i dont see how thats possible techtonics tuning had the same all motor set up minus the ford coil conversion and autotech wires making 278 whp and running 11.5s iv seen the videos and colin at techtonics said the cam and valve combo nets about 45 hp so theres no way im not breaking 200 cause im dynod at 201 right now with bolt ons and a stock motor the build will be done in about a week or so ill dyno it with the new motor and post it ill be suprised if im not above 280 but i could be completly wrong its happend before lol
    8. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      05-09-2012 01:34 PM #8
      Bernd's 12v never made that kind of power. The 24v did/does.
      Many struggle with the 200whp barrier, there are ways across and a stock type manifold is not part of it.
      -Paul
    9. 05-14-2012 10:08 PM #9
      i am going to try to hit atleast 240 and i think thats reasonable and if not ill throw some methonal into the mix and that will deff put me past the 270 mark in any event the engine is in im going to brak it in and then put my 2.9 on cause i havent finished it yet and then ill dyno it and ill post it it will probably be about two or three weeks i appriciate all the feed back thanks guys
    10. 05-14-2012 10:09 PM #10
      Quote Originally Posted by sundayshadow View Post
      and ill dyno it again with the short runner its just i dd this car and i feel like a short runner will make it unbearable lol but i gotta do what i gotta do **** i may even put it on itb's
    11. 06-04-2012 09:25 PM #11
      heat tape
      the intake spacer
      port match ur manifolds
      run a external oil cooler
      ceramic coat the manifold and exhaust housing engine temp down
      if u lift the back of ur hood up 1 inch it drops the bay temp 20 plus degrees
      230 to 200 -207
    12. Member FLATBLACKMK2's Avatar
      Oct 10th, 2003
      Mickey Mouse's Trouwzah'z Dude.Guy
      92 Monstah 4Lugz6Slugz,84 GLI fo'door
      06-08-2012 06:38 PM #12
      sorry but 270hp not gonna happen.........M/S or whatever ITB's still not on a 12v....ask rootbeer or need_a_vr6 they've been racing and building fast all motor set ups since way back...
      GOOD LUCK..
      Jay Fay
      Broke.Status.N.E.K<3F6squared<3GetLow<3VwFiends<3Fifteen52<3Ban chWerks<3sdobbinsphotography<3CreEp CuStOmZR.I.P.ALEXIR.I.P.Scott TaylorR.I.P. Moses
      DrivenApparelGengstout#SLAW#
    13. 06-09-2012 12:15 AM #13
      ok so i have a problem i think lol i know on big blocks and most engines big cams and valves make more valvetrain noise so my question is for someone root beer or one of you guys how loud is a vr with the 288 cams and the valve setup i listed form 2 to 4k iv got alot of valve noise i can hear it in the car while driving and my car is pretty loud any body got some input for that
      my head work was done at a machine shop i used a stock head gasket followed all specs and procedures all timing is spot on and in spec and everything in the engine besides the pistons rods and crank are new
    14. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      06-09-2012 08:45 AM #14
      Could be a stuck lifter, see if any are squished down.
      Also, what is the bottom setup? With 288s my exhaust valves hit my pistons and self-clearanced but that was stock block. If you have less clearance you might have bent valves. I would check compression.
      -Paul
    15. 06-09-2012 08:51 AM #15
      tt cams and bigger valves tend to dont like each other.
      CrossroadsLI
    16. 06-09-2012 09:07 AM #16
      compression is 153 across the board completly stock bottom end and car runs great minus the noise i checked the lifters and i dont see any failures
    17. Member FLATBLACKMK2's Avatar
      Oct 10th, 2003
      06-09-2012 09:31 AM #17
      how about the valve springs check them i had some seperate and break once made tons of valve slap noise worse then chains, the big valve and cams were just too much for the TT valve springs...went to schricks and problem solved..
    18. 06-09-2012 10:35 AM #18
      Did u notice and problems as far as how it ran cause this thing runs phenominally.
    19. Member FLATBLACKMK2's Avatar
      Oct 10th, 2003
      06-09-2012 10:40 AM #19
      only on hard acceleration where the valve lift was high, higher rpm's when i really hammered on her...and i only had 276's...
      4-6krpm's i think...really started to run rough..
    20. 06-09-2012 10:44 AM #20
      Its odd because the noise started after I broke the engine in it only makes it when its a running temp and only from 2-4k at idle u can't even hear a noise with a stethoscope and the only other thing I can think of is I can hear the noise in the exhaust also like through the whole system iv never heard a noise like this
    21. 06-09-2012 10:57 AM #21
      I put it to 7k and it didn't miss a blink and I've already raced my buddys r33swaped 240 and killed it that's y I'm confused normally a noise like I'm hearing corraltes to a drivability issue but I don't have any
    22. 06-09-2012 05:05 PM #22
      Ok so I was looking at the situation and the only thing I think that could cause that type of noise in the area of the car is the throwout bearing my reasoning is this it changes with rpm but is not present at idle I have no drivabilty issues and the noise could echo threw the timimg cover and resonante tstumps me is how I can hear it hrough the vavle cover the the only part that stumps me is the fact I can hear it in my exhaust
      So any thoughts on this
    23. 06-10-2012 10:25 PM #23
      so it is something in the head i got it to blow blue smoke so either its the rings or a head issue im going to perform a cylinder leakage test and figure out which cylinders are failing im fairly sure its in the head because thats where the noise is i appriciate all the help u guys gave thanks a bunch
    24. Geriatric Member need_a_VR6's Avatar
      May 19th, 1999
      Oxford, PA
      06-10-2012 11:29 PM #24
      If the machine shop used aftermarket guides without modifying them, its likely you have some crushed valve seals.
      -Paul
    25. 06-11-2012 09:38 AM #25
      Hey just out of curiosity what lifters are u guys running with the big cams cause I had complete lack of power from 5 to 8 and I believe it was my lifters not keeping up
