Results 1 to 4 of 4
Thread: please please please help
  1. 04-28-2012 01:03 AM #1
    hey guys i lost/ cant remember where i sat the torque converter bolts for my 00 jetta with an 01m. would anyone know the specific size and pitch i could buy at the hardware store?
    Nov 7th, 2011
    Woodbury, MN
    2008 VW Jetta 2.5
    04-29-2012 09:36 AM #2
    I would buy they from the dealer as they are likely metric 10.9 shouldered bolts. This won't be expensive and it is the safest solution. If you MUST use hardware bolts, get 10.9 or harder (NOT 8.8), make sure they are NOT too long, DO NOT use a lock washer, a flat washer will be fine, and use red or blue lock-tite. Then turn the engine by hand to see if the heads of the bolts protrude out too far and hit on the engine or a shield or whatever. I still would recommend the dealer for this one. Sorry.
    Brad
  3. Member Stangrcr1's Avatar
    Mar 5th, 2012
    Marysville, WA
    2001 Jetta VR6 12v 2000 Ford F250 Diesel 4x4 2007 Ford Focus 1982 Ford F250 1956 Willys
    04-29-2012 03:33 PM #3
    The torque converter with the 01M has studs, not bolts. And the nuts are shouldered.
  4. Member CoolAirVw's Avatar
    Mar 8th, 2007
    Kansas City Missouri
    05-05-2012 06:58 AM #4
    They are nuts..
    10mm x 1.25. If I recall correctly.
    www.KansasCityTdi.com
