Results 1 to 18 of 18
Thread: only have 1st 3rd and 5th
  1. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    windsor 2.0, ginster 1.8t
    04-28-2012 03:38 AM #1
    so i was leaving my friends house.... and my car would only go into 1st 3rd and 5th
    car shifted prefectly till then its a 97 2.0 gti, i feel like someone ****ed with my linkage. but its too dark so anyone have any other ideas?
    ( wouldnt go to reverse 2nd or 4th)
    Quote Originally Posted by ZACHER3tuning View Post
    only on vortex, could this turn into a argument.
    http://forums.vwvortex.com/showthrea...Project-molest
    Mar 23rd, 2008
    N/A
    N/A
    04-28-2012 05:09 AM #2
    One of the plastic ballcups on one of the pushrods probably popped off it's linkage under the hood.
  3. n00b
    May 31st, 2011
    97 Gti 2.0
    04-28-2012 10:55 AM #3
    the same thing happened to my in my 98 gl. i replaced the bushings and changed the fluid and nothing changed. it turned out that a part of my trans that the linkage was mounted to had broken which caused me to loose gears. start with the good ol visual inspection
  4. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-28-2012 12:20 PM #4
    thanks
  5. Member somebodynowhere's Avatar
    Feb 10th, 2010
    203 CT
    3.0 Vr Corrado, 8v mk3, 8v mk2
    04-28-2012 12:24 PM #5
    Shift tower
  6. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-28-2012 04:12 PM #6
    turns out i dropped my ipod in the shift tower and jammed up in there lol
    RIP ipod
    Apr 18th, 2011
    Jacksonville, Florida
    96 Jetta GL
    04-28-2012 04:40 PM #7
    Quote Originally Posted by builtvw View Post
    RIP ipod
    Wow... rofl that sucks.
  8. 04-28-2012 05:06 PM #8
    haha ive had the same happen with a pen... not thinking i popped the hood and started screwing around with the shifter linkage box (not sure the exact name of it)... and i realized the previous owner had ziptied the box in place. well i broke the zip ties and moved it around, and now i cant figure out where the box goes in the engine bay, so i just left it sitting kinda wierd.... my haynes manual doesnt show where to install it... if anyone knows PLEASE let me know.
  9. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-28-2012 06:16 PM #9
    at least it was a free ipod
    Photobucket
  10. Member gtr3nos1's Avatar
    Sep 6th, 2008
    Danbury CT
    97 Golf VR6 (Show Car) 99.5 A4 1.8T (Daily) 95 Jetta City 97 Golf (Sold) 00 Gti VR6 (Sold)
    04-28-2012 06:27 PM #10
    damn!! that thing is so done
    Vag-Com up to 2005, pm me
    Eastwood Fender Roller for rent, pm me
  11. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-28-2012 06:54 PM #11
    Quote Originally Posted by gtr3nos1 View Post
    yup from me trying to slam into second lol
  12. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-28-2012 07:22 PM #12
    ok so oncce i removed the ipod i didnt actually test it out, so now i have reverse but no 2nd or 4th. could i have bent something trying to slam it in gears? the linkage on the trans has nothing wrong with it
  13. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-28-2012 08:45 PM #13
    bump
  14. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-29-2012 03:12 AM #14
    bump
  15. 04-29-2012 03:28 AM #15
    There are c-clips known to fall off on the shift cable trans bracket. Sounds like this happened to you. The c-clip I'm speaking of holds the outside of the shifter cable (in this case, gear selector cable) to the bracket on top of trans. If this pops out, the pulling motion the cable still works (1st, 3rd, 5th,) but the cable will bow when push pressure is applied for 2nd or 4th. The cable is bowing and has slack without the securing c-clip to that bracket. Look around where this first happened to you, see if the clip is laying on the ground. They can land and stay on top of the trans if you are lucky.
    Did you know that it's not pronounced Em Kay ? ALL OF THE CAR LOUNGE WILL BE HAPPY TO LET YOU KNOW THAT. SERIOUSLY. IT STANDS FOR MARK. DID YOU KNOW THAT? BEFORE THAT A1,A2, A3, ETC WAS USED. LIVE UP TO TCL STANDARDS BEFORE YOU GET ON MY ASS. THAT'S DISGUSTING.
    Example of TCL's standards
  16. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-29-2012 12:44 PM #16
    i dont see anywhere where there would be a clip missing, any chance you have a picture
  17. Member somebodynowhere's Avatar
    Feb 10th, 2010
    203 CT
    04-29-2012 03:36 PM #17
    Try adjusting your shift linkage if everything seems complete and intact if that doesn't work you probably damaged your shift tower internals. Happened to me in my Rado and I only had 2nd and 4th.
  18. Member builtvw's Avatar
    Sep 19th, 2009
    coopersburg
    04-29-2012 07:26 PM #18
    Quote Originally Posted by somebodynowhere View Post
    alright thanks cause this is really annoying i guess i should just order a rebuild kit
    something like so: http://www.ecstuning.com/Volkswagen-...hifter/ES6769/
    also how would one "adjust" the linkage
