Results 1 to 2 of 2
Thread: New B6 Owner...Few questions about wheel specs
  1. Member Vdubed13's Avatar
    Jun 6th, 2008
    WEST VIRGINIA
    Bagged -Big Turbo -MK4 and Slammed B6 A4 1.8TQ
    04-28-2012 08:54 AM #1
    Just picked up a B6 A4 1.8T Quattro a few months ago.
    Specs.
    APR Stage 1+
    TT 225 Injectors
    PODI Boost Gauge in pod
    I am wanting to stance it a lil on some wheels and just found a good deal on some LMs. I am not sure if i can run these sizes and if anyone has any pics of there setup that is close to it..
    19x8.5 ET32
    19x10 ET45
    Anyone ever done a 10 in the rear of quattro and if so lets see some pics i dont want major poke i just want it kinda sit flush maybe a lil poke and look good its my daily and want it to look awesome
    Specializing in Powder Coating and VW/Audi Performance and Maintenance
    VAGWERKS PERFORMANCE AND COATING
    -Powder Coating -Air Ride Installs - Frame Notches - Coilover Installs - Engine Performance- You name it we will do it, From full swaps to oil changes
  2. 04-30-2012 02:03 PM #2
    With quattro, you don't want to differ that much in wheel width between the front and rear wheels. The larger difference can result in damage to the differentials. A one inch difference in width is considered the maximum safest difference allowed.
    As for the offsets. Many wheels with an ET32 offset will do nicely to push the wheel out to the edge. Depending on the tires used, you might need to slightly roll the edges of the fenders (if the sidewall on the tires is square instead of rounded).
    I run during the summer a set of 19x9 ET 32 OZ Superleggera III wheels with no issues. If you have a big brake kit, you'll want to also check for caliper clearance (which could be resolved by using spacers).
    Everything else is up to your own personal taste.
