VWVortex.com - Alternator help vr swap
    Results 1 to 14 of 14
    Thread: Alternator help vr swap
    1. Member dubious311's Avatar
      May 1st, 2003
      Lower Dutchess, NY
      90 VRT Jetta Coupe
      04-28-2012 02:16 PM #1
      Just replaced alternator and belt.
      Checked voltage at battery terminals and only getting 11Volts.
      CHecked wiring and noticed the blue excite wire was disconnected. Repaired wire and now the battery light comes on when the key is at on position and stays on when the engine is running.
      I'm still only getting 11 volts at battery terminals.
      Followed all the steps to test the alternator in the bently for a VR6 OBDII and everything checks out. Testing black wire to ground-12volts, checking the excite wire terminal to ground while key is on -12volts.
      Someone please help.
    2. Member BiH's Avatar
      Nov 27th, 2000
      Fairfax, VA
      1990 JETTA VR6, 2003 JETTA 1.8T, 2010 TOUAREG TDI
      04-28-2012 02:37 PM #2
      if I remember right there is two terminals on the alternator where exciter wire goes, if you put it on the wrong one battery light will come on.
      I do work on cars, anything short of engine and transmission rebuilding can be done. welding, custom and aftermarket as well as regular repairs. IM me for details, shop is in WOodbridge.
    3. Member dubious311's Avatar
      May 1st, 2003
      Lower Dutchess, NY
      90 VRT Jetta Coupe
      04-28-2012 03:23 PM #3
      There's only one way you can plug in the connector to the alternator.
      Anyone else?
    4. Member weejunGL's Avatar
      Feb 2nd, 2005
      Norwegen
      MKII 16vT Syncro
      04-28-2012 03:27 PM #4
      defective voltage regulator?
      stock vw alternator wiring isn't very good. upgrate will only do you good
      heavy gauge wire will help out
    5. Member dubious311's Avatar
      May 1st, 2003
      Lower Dutchess, NY
      90 VRT Jetta Coupe
      04-30-2012 02:54 PM #5
      Anyone else have any info or ideas? I just replaced the alternator last April and it ran fine. Replaced the alternator again and I'm not getting a charge. HELP.
    6. Member weejunGL's Avatar
      Feb 2nd, 2005
      Norwegen
      MKII 16vT Syncro
      04-30-2012 03:20 PM #6
      for **** sake, didn't you read my post?
      i dont mean to be rude here or anything, but since you don't get any charge out of it. they answer lies two posts up......
    7. Member stealthmk1's Avatar
      Aug 16th, 2001
      Philadelphia, PA
      84 GTI/86 4000q/92 VR6T/07 Rabbit/12 GTI/97 F-350
      04-30-2012 03:25 PM #7
      Check the alternator output directly at the output stud. It shouuld be at least 14v, if not then there's something wrong with it, plain and simple.
      Does voltage increase with revs?
      DCI
    8. Member dubious311's Avatar
      May 1st, 2003
      Lower Dutchess, NY
      90 VRT Jetta Coupe
      04-30-2012 09:29 PM #8
      BUMP. Anyone else have any ideas??
    9. Member stealthmk1's Avatar
      Aug 16th, 2001
      Philadelphia, PA
      04-30-2012 09:36 PM #9
      Anything to report back on the suggestions you were given so far?
      DCI
      Sep 18th, 2004
      vw jetta
      04-30-2012 10:18 PM #10
      put the coupe up for sale . buy a toyota.
      some feed back on suggestion might help others to help you
      A Dutty Dub
      OutCastDubs
    11. Member stealthmk1's Avatar
      Aug 16th, 2001
      Philadelphia, PA
      05-01-2012 10:29 AM #11
      Quote Originally Posted by gtidaddy View Post
      this
      DCI
    12. Member dubious311's Avatar
      May 1st, 2003
      Lower Dutchess, NY
      90 VRT Jetta Coupe
      05-03-2012 09:10 PM #12
      Pulled alternator to get it bench tested tomorrow. See what happens, hopefully it's bad.
    13. Member dubious311's Avatar
      May 1st, 2003
      Lower Dutchess, NY
      90 VRT Jetta Coupe
      05-04-2012 05:50 PM #13
      Alternator failed bench test replacement coming from German auto tomorrow.
    14. Semi-n00b
      Sep 22nd, 2007
      2015 GTI AUTOBAHN WHITE /2007 Audi A4 3.2/ 1990 JETTA COUPE VRT
      05-08-2012 04:11 PM #14
      Good Luck
