Bump
#1
Ive got an 06 Jetta 2.0T 6 speed manual and every time I hit the brakes, hard or soft, and at any speed I hear a loud clunking noise. It started happening after a road trip from North Carolina down to Florida. Ive inspected my brakes and the pads only have 5K on them. Also I have done the subframe bolt fix along with the shims and that didn't do anything. My question is, could it be the engine/transmission mount, or swaybar end links, or what? Any input is appreciated
Thanks,
Chris
#3
What area of the car is the noise coming?
ALWAYS Mention VwVortex FOR OUR DISCOUNTS!!!Need a Quality Mechanic? J's REPAIR AND PERFORMANCE, PLAINFIELD, IL VAG-COM EQUIPPED-815-556-0027 01E/01X TRANSMISSION REBUILDER BEST price for OEM VW parts- ERIC @ autobarn vw (mt prospect, IL_they ship) 866-308-0049 Need paint work? Collision Revision Plainfield, il talk with Tony Combs 815-439-7401
#5
It doesn't pull at all but it sounds like the clunk is coming more from the passenger side
#6
#7
Check your guide pins on the calipers, maybe they need grease? Jack up the car and see if you have any wheel play.
