any codes? hows the CTS? and did you do a Throttle body adaptation?
#1
I swapped an AEB into my CE1 MK2 and everything is perfect apart from one thing. When I start my car after it sitting for a few hours I have to press the throttle lightly to get it to start. If I dont it'll start and die instantly. As soon as its running its fine.
Pics for clicks.
#3
There are a few codes, 2 for the post cat O2 Sensor not being present, VSS no signal, Evap 2 codes.
Brand new CTS, did a throttle body adaptation twice.
#4
If you are on teh stock CIS pump, I would say it's the check valve for it.
It's allowing the gas to go back to the tank, and when you start the car, you will have less gas.
Try to turn the key maybe 3 times letting it prime, and test again, to see if it's better.
▀▀▀ EIGH-T6 // "Give me enough traction, and I will spin the WORLD!"
Portugal // Europe
MS II V3.0: http://eight620vt.tk/
#5
I'm having a similar issue with my 1.8t swap in my mk1. Is your motor idling properly after you get it started. Mine starts and then idles like this...
http://www.youtube.com/watch?v=F935I...1&feature=plcp
Any ideas? Once mine warms up it's good to go and idles normally. I think mine might be related to the coolant temp sensor.
"4 spoke wheels are only one spoke less gay than 3 spoke wheels, which are universally accepted as the gayest wheels imaginable."
#6
Mine idles perfect and I will try priming the pump a few times prior to starting it. Thanks.
