Results 1 to 8 of 8
Thread: Mk4 gli front end clunck noise
  1. Junior Member vwnathan's Avatar
    Sep 30th, 2010
    Mashpee
    76 bug GONE,97 MK3 Jetta GONE, 04 Gli RIP, 05 Gli
    04-28-2012 04:01 PM #1
    When I'm backing up and have the wheel turned to the right I get this loud clunck noise from the front end. New struts, bearings, and mounts up front. Cv joints are fine and all bolts are snug. What else could it be? Could it be the dogbone mount? Is that hard to swap out? It's a 1.8 gli with a 6 speed. I'm stumped!!
    Work eBay l Gli parts for sale l My MK4 retrofit project
    FOR SALE MK4 Golf exhaust, 3" Magnaflow from a 1.8 Jetta, Can get my hands on many parts at a good price, just ask!!
  2. Moderator Flyin18T's Avatar
    Jan 10th, 2001
    Long Island
    04-29-2012 08:51 AM #2
    You might have broken a motor mount bolt. Be careful and have it looked at asap.
    Sent from my HTC_Amaze_4G using Tapatalk 2
    2012 MKVI Jetta GLI / 2008 Civic Si Sedan / 2007 Mazdaspeed 6 / 2004 MKIV Jetta GLI (1.8T) / 1996 MKIII Jetta GLX VR6
    https://twitter.com/Flyin18T
  3. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    04-30-2012 04:07 PM #3
    Dogbone replacement is easy to do, 3 sockets, a ratchet, and 12-18" prybar is all you need. Could take half an hour if it's your first time, 10 minutes or less 2nd time.. That is unless you broke a bolt or cracked the trans housing.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  4. Junior Member vwnathan's Avatar
    Sep 30th, 2010
    Mashpee
    05-07-2012 07:18 PM #4
    Okay so finally got to checking things out. Its not any motor mount bolts. I rule out strut bearings because it did it still right after I replaced them!!! The only other thing I haven't done is the dogbone mount. I have another one with a urethane insert in it. I'll give that a try and see what happens.
  5. Member twin2626's Avatar
    May 11th, 2006
    Niagara falls
    2003 Jetta GLI
    05-07-2012 11:10 PM #5
    My ball joints were rattling. Just replaced both front and the clunk over bumps is gone.
  6. Junior Member vwnathan's Avatar
    Sep 30th, 2010
    Mashpee
    05-19-2012 09:45 PM #6
    Okay. So today finally got around to doing the ball joints. NOPE. Clunk is still there. No difference. I think I'll try the dogbone mount next. It's a gli and the bottom of that part of the subframe has bottomed out a few times from what it looks (damn speed bumps). Will update after the mount replacement.
  7. Junior Member vwnathan's Avatar
    Sep 30th, 2010
    Mashpee
    06-01-2012 07:39 PM #7
    Okay so far I have replaced struts, mounts, bearings. Front ball joints, tightened sub frame bolts (that were already tight). Tie rods are tight. Power steering fluid is up. Picked up a set of r32 control arm solid bushings, gonna try that next. Dogbone mount is a-okay. I can hear a clunk going over bumps coming from the rear. Maybe I'm looking in the wrong spot? Has bilstien sport struts in the rear. Maybe time to swap to oem? Maybe its the rear axle beam bushings? Motor mounts all seem tight. I'm beginning to become stomped. Maybe it's the steering rack itself??
  8. Member DC Jetta Guy's Avatar
    Jul 31st, 2004
    2005 GLI
    06-05-2012 10:07 AM #8
    If the clunk sound is coming from the rear, that sounds like a shock mount - specifically the shock-to-mount connection. Unbolt your shock mounts from the body and make sure the mounts are tight on the tops of the shocks. That's easy to do and rule out...
