VWVortex.com - torque specs on oil seal housings
    Results 1 to 6 of 6
    Thread: torque specs on oil seal housings
    1. Member Mk1 fa'days's Avatar
      Apr 24th, 2008
      Milwaukee, WI
      '78 Champagne II, 2 '80 Caddy's, '81 Subaru Brat, 1/2 '81 Caddy, '93 Passat, '99 Saab 9-3
      04-28-2012 06:04 PM #1
      I couldn't find the specs for the torque on the crank seal housing and other main oil seal housings in my Bentley so I was wondering if there is a specific torque our just tighten them as tight as I can with thread lock on the bolts? Let me know!
      Jul 21st, 2002
      Boise, ID
      2004 Flash Green V70R
      04-28-2012 07:42 PM #2
      Interesting the A2 manual doesnt seem to have specs for them either.
      Small bolts so good and snug with loctite is probably fine. Dont go too hard they will break easily.
    3. Member VWsEatRice's Avatar
      Jan 13th, 2004
      Tacoma WA
      84 Jetta GLI 86 Scirocco 16v
      04-28-2012 08:49 PM #3
      10 newtonmeters or 87inch pounds.
      from memory. just did it recently. was in my scirocco bentley. can't guarantee my short term memory but the long term still seems to work.
      i can update directly from the manual in a few hours to confirm those.
      i think they are called oil seal carriers.
    4. Member VWsEatRice's Avatar
      Jan 13th, 2004
      Tacoma WA
      04-28-2012 09:00 PM #4
      Install the new seal, lubricated with clean engine oil, with the lip on the inside and the closed side facing out. Fit the seal into position, and carefully drive it into place until it is fully seated in the seal carrier. Use care not to distort the seal as it is installed. For best results, use a seal driver such as Volkswagen special tool no. 3083, shown in Fig. 6-2. If reinstalling the seal carrier, torque the top three bolts to 10 Nm (87 in. lb.) and all other bolts to 20 Nm (15 ft. lb.).
    5. Member rabbitnothopper's Avatar
      Oct 19th, 2009
      D-Town REPRESENT : Texas
      RIP81. 78 VW Rabbit 1.5L EH 4speed 020 GC->GP, 82 Rabbit Pickup 1.6D
      04-28-2012 10:00 PM #5
      GREAT SOLUTION AND REPLIES GUYS
      EPIC FORUM SUPPORT!!!
      and now on with the mile/tons
    6. Member Mk1 fa'days's Avatar
      Apr 24th, 2008
      Milwaukee, WI
      04-28-2012 11:43 PM #6
      Awesome, saved me some broken bolts, thanks!
      Mk1 forum is the best that's why is the only one I frequent
