Results 1 to 6 of 6
Thread: 1.8t with 2.0t crank questions
  1. 04-28-2012 06:58 PM #1
    1 ? Is what numbers am i looking hp and 1/4 mile times with just the crank change bit of course im gona change rods and pistons maybe keep stock bore
    2? How is the low rpm power i seen one one youtube and it look pretty slow but made 335 on 12 pounds
  2. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    1989 16v, F250 Diesel, 2001 TT
    04-28-2012 11:57 PM #2
    seriously dude?
    a crank alone will net you a tiny bit of torque, maybe 15-20ft-lbs. I really want to flame you right now but I am not gonna.
    HAD - 1991 V8Q | 1990 Jetta 1.6 | 1984 Rabbit 16v | 1990 Audi CQ | 1988 Audi 80 10v | 2005 GTi 1.8T | 1991 GTI 2.0 ABA | 2002 Audi TT S362 |
    HAVE - 2001 TT 180Q F23 wifes | 1989 Jetta VR6 GLI | 2004 F250 PowerStroke |
    Looking for Custom Tuning, Shoot me a PM ! ME7.X !
    Mar 31st, 2008
    PNW - Oregon
    04-29-2012 01:15 AM #3
    Quote Originally Posted by ejg3855 View Post
    seriously dude?
    the temptation is very much there!
    hes one of them "i saw one on youtube, now i wanna build one!" kinda newb.. someone who should be driving a civic, instead of abusing a VW.
    and whats wrong with using the 2.0T block/crank/rods/pistons, and slapping the 20v head on it?
    isnt that how you do a 20/20 swap?
    isnt putting a 2.0 crank in a 1.8 block basically accomplishing the same thing, but with more work? isnt the 1.8 block basically the same dimensions as the 2.0 block?
  4. Member
    Aug 7th, 2004
    Rockaway,NJ
    94 golf
    04-29-2012 02:37 PM #4
    You cannot just slap a 20v head on a 2.0 block. If you change the crank in a 1.8t you will need different pistons and will give you more torque and ultimately more power. Prob not worth it unless you will be upgrading turbo and such
  5. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    04-29-2012 05:43 PM #5
    this should be in the 1.8t forums where this has been done a billion times before.
    the car that makes 335 on 12psi..is not jsut a crank switch. as stated it owuld need timign gear and chain swap,rods,rings,pistons,bearings,etc. but also a turbo upgrade to make that power...and 12psi with a 2.0l 20v motor is gonna be with a 30r more than likely, and it probably has some other goodies.
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  6. Member
    Jun 14th, 2001
    Music City USA
    79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
    04-30-2012 12:14 AM #6
    GPO in Nashville made a 2.0T from a 1.8T and awd conversion in 03 GTI. Makes 405 to the ground at about 25psi. Any more boost and it just gets stupid to drive.
