Results 1 to 2 of 2
Thread: Forge dv valve orientation question r32 turbo
    Dec 29th, 2009
    lakeland, florida
    mk3 vr6 jetta
    04-28-2012 08:21 PM #1
    This may be a stupid question but the side and bottom ports on the dv valve which goes to the intake on turbo and which goes to the intercooler piping to the throttle body. This is on a r32 turbo and when I got it the bottom is going to the intercooler piping and the side to the intake to me it seems backwards from what I've seen on other cars if someone could help I'd appreciate it
  2. Member mk4vrjtta's Avatar
    Feb 3rd, 2007
    Rockford IL
    2000 Jetta vr6S
    04-29-2012 04:45 PM #2
    Quote Originally Posted by klethers View Post
    will work properly either way
    VRalliance#35 308whp/248ftlb --vortech v9 f-trim w/single idler 10psi, forge 007 DV, 262 cams, dual nozzle devils own water/meth, ported stock ex manis, tt downpipe, custom 3in exhaust, Autotech 10lb flywheel, sachs oem vr clutch, 034 motor mounts,ecs lightweight crank/power steering pulleys, vmaxx, R32 control arm bushings, 18x8.5 flik arctics
