Results 1 to 5 of 5
Thread: Lots of Fault codes HELP
  1. Junior Member gotgli's Avatar
    Apr 3rd, 2009
    Minnesota
    06 VW GLI 174k miles 6sp man
    04-28-2012 09:16 PM #1
    P0171 SYSTEM TO LEAN BANK 1
    P12A2 POWERTRAIN
    P0642 POWERTRAIN
    P0010 POWERTRAIN "A" CAMSHAFT POSITION ACTUATOR CIRCUIT BANK 1
    P2181 POWERTRAIN COOLING SYSTEM PERFORMANCE
    P0507 POWERTRAIN IDLE CONTROL SYSTEM RPM HIGHER THAN EXPECTED
    P2004 POWERTRAIN INTAKE MANF RUNNER CONTROL STUCK OPEN BANK 1
    When I come to a stop the RPM sometimes jumps to 2k then idles around 1k and also makes a loud rattle sound when it idles coming from under hood. Also when im in traffic and in 1st or 2nd and let off gas it jerks hard when i let gas off.
    Any ideas??
  2. Member ROH ECHT's Avatar
    Dec 9th, 2010
    auf asphalt
    `07 gti K04'd
    04-29-2012 01:42 AM #2
    Check into the throttle body recall.
    K04 PLAY...`07 GTI/AWE K04&DV/APR HPFP/S3 INJ's&fmic/RS4 fprv/FORGE fmic & T-B HOSE/TECH.TUNING TB/BSH PCV&MOUNT's/NSP BOOST GAGE/AP Lite-PULLEY/NEUS. P-FLO&BOOST PIPES/GIAC K04 H/O & DSG FILES/13.2"BBK/BILSTEIN DAMPERS/W.A.L.K./H&R SS SPRINGS+F&R-ARB's/TSW 8X18 NURB's...ZOOM DIS! 1/4 mi: 12.82 @ 112 mph
    Jul 19th, 2007
    Anacortes, wa
    2012 Jetta Tdi, 2007 Jetta 2.5
    04-29-2012 11:27 PM #3
    Quote Originally Posted by gotgli View Post
    P12A2 POWERTRAIN
    P0642 POWERTRAIN
    Any ideas??
    Make sure your oil level is okay first, thats probably your motor rattle, or there is something wrong with your cam adjuster. The p0171, and 0507 faults have a pcv valve recall that will fix that, p2004 IMRC valve also has a recall. p2181 is a faulty t-stat most likely, full scan with obd freeze frame would most likely comfirm that.
    2012 Jetta Tdi
    H&R sport springs
    15% tint
    VW Technician
    VAGCOM equipped, willing to help with it if in pacific NW area. Hit me up.
  4. Junior Member gotgli's Avatar
    Apr 3rd, 2009
    Minnesota
    05-04-2012 08:34 PM #4
    Dealer said no recalls on my car.
    Jul 19th, 2007
    Anacortes, wa
    05-04-2012 11:33 PM #5
    PM me your vin
    2012 Jetta Tdi
    H&R sport springs
    15% tint
    VW Technician
