Results 1 to 16 of 16
Thread: Mowing problems
    Feb 15th, 2010
    Chesterfield, Indiana
    2009 Caliber SRT4, 1989 Mazda B2200, 2010 RAV4
    04-29-2012 01:08 AM #1
    My wife and I have recently moved into a new house (renting). We are responsible for yard care. I haven't mowed grass since I moved out of my parents house.
    The problem I am having is that there are tiny rocks in the yard........EVERYWHERE. The driveway is made of these rocks and I guess at some point before we moved in they got scattered throughout the yard.
    I'm slinging rocks all over the place, hitting the house, hitting my car, the neighbors house, pretty much nothing within a 100 ft radius is safe. They're not big enough to do any major damage to property but I caught one in the nether regions today and it hurt like hell. I would hate to hit somebody that happened to be walking by or one of the neighborhood kids.
    Any thoughts on what to do about this? The rocks are so small that a rake doesn't really do any good, and raising the deck on the lawnmower doesn't seem to make much difference.
  2. Member emmettlodge's Avatar
    Nov 7th, 2007
    Ohio
    2012 Tacoma 4x4, 2010 Tacoma 4x2, 1990 E30
    04-29-2012 10:16 AM #2
    Buy a mulching mower with no discharge chute.
    All rights reserved. No fur-bearing animals were harmed during the creation of this post. Caution: May cause irritability, sleeplessness or warts after prolonged reading. May cause some laboratory rats to rip through their cages, fly across the room and brutally murder hundreds of innocent people. Not to be combined with other posts except under the advice of a physician.
  3. Senior Member spockcat's Avatar
    Jun 4th, 2003
    07 Z4MC, 11 328i Touring
    04-29-2012 01:16 PM #3
    Raise the mower blade up so it cuts grass, not the dirt and rocks.
  4. Member unimogken's Avatar
    Jan 19th, 2005
    South of Jazzydub, WA
    6 Tap Kegerator
    04-29-2012 03:08 PM #4
    You could lay down an inch or so of topsoil on top of the grass then overseed it.
    My Honda mower has 2 blades and the upper blade is a suction blade.
    You could see if you can replace your suction blade with one that has a lower suction rating so you wouldn't pick the rocks up!
    I really wish everyone would update their location in their profile!
    Someone buy my car already!!
    Always looking for free firewood to feed my hungry wood stove!
    Feb 15th, 2010
    04-29-2012 07:20 PM #5
    Quote Originally Posted by spockcat View Post
    Already addressed this, the deck height is not the issue. I'm on the middle notch.
    Suggestion about the mulching thing might work. I have the mulching cover the mower came with, I guess all I need to do is buy new blades?
    Feb 15th, 2010
    04-29-2012 07:22 PM #6
    Quote Originally Posted by unimogken View Post
    If we were planning to stay in the house long-term I'd definitely want to do something, but I can't see spending that kind of money on a rental house.
    Sep 12th, 2005
    Milwaukee, WI
    1986 IDI Golf, 310K Miles.
    04-29-2012 09:04 PM #7
    Is the yard small enough to use a reel mower? If you looked around, it might be possible to find an old one powered with a gasoline engine. It should not pick up rocks.
    Another option would be a bagger rotary mower. Use that until the supply of rocks is cleaned up and in the bag.
  8. 04-30-2012 02:27 AM #8
    I would recommend that you go to a rental place and rent a lawn vacuum. Although I've never used one, I suspect that it would do the trick. It shouldn't cost more than $50 for a few hours, probably $100 for the whole day. Unless you have more than .25 acres of actual grass, it probably won't take more than a few hours.
    My yard is naturally rocky, and I also have 2 yards of pea gravel in a play area. My son likes to drop these rocks all over the yard. I actually took my shop vac to the perimiter of the play area. It worked quite well. I didn't use a bag. Once done, I dumped the contents into a 5 gallon bucket. I then filled the bucket with water and let the hose run. This allowed the dirt and grass to float away, leaving the rocks. Once done, I dumped the rocks back into the play area.
    You could do the same with the yard vac and put the rocks back in the driveway.
    Apr 6th, 2006
    Oregon
    06 Xterra OR, 05 Suburban
    04-30-2012 08:13 AM #9
    Quote Originally Posted by Markos View Post
    I didn't even know they made such a thing.
    We have our grass covered in glass after a house fire, this thing would be fantastic.
  10. 04-30-2012 01:53 PM #10
    Quote Originally Posted by HookedOn16v View Post
    Crazy! Did your windows explode or something?
    Apr 6th, 2006
    Oregon
    04-30-2012 02:58 PM #11
    Yeah, most did blow out. The ones that didn't blow were demo'ed by the fire teams going in. Gigantic mess.
    Going to look at the renting that vacuum and cleaning up. Tilling the entire yard this weekend and starting over from bare land. 8 months away does bad things to landscaping, haha.
    Definitely appreciate you posting that thing, going to make life easier!
    Feb 15th, 2010
    05-01-2012 01:02 AM #12
    Me neither, that looks awesome!
    I could see myself getting this and getting carried away, end up doing my entire neighborhood.
    Sorry to hear about your house, that sucks.
  13. 05-01-2012 01:40 AM #13
    Quote Originally Posted by Roboturner913 View Post
    Sweet! Looks like they have these at Sunbelt Rental for under $60 for the whole day.
    http://www.sunbeltrentals.com/equipm...ry.aspx?id=s91
  14. Member unimogken's Avatar
    Jan 19th, 2005
    6 Tap Kegerator
    05-01-2012 04:20 AM #14
    A cool trick with Sunbelt rental is to find one that is closed on both Sat and Sun! Rent the tool on Fri and return Mon morning for the price of 1 single day!
    I do it all the time when I rent a log splitter!
  15. Member Mk1Racer's Avatar
    Apr 16th, 1999
    NJ
    '99 B5 wagon (RIP), '01 B5.5 wagon, '81 Scirocco, '04 FXDWG
    05-01-2012 07:44 AM #15
    You could try mulching blades, or you raise the deck to a higher setting.
    The above item is a chipper/shreader/vac. It's designed to suck up leaves and small twigs and chop them up. If you use it to suck up rocks/glass, it's going to kill the blade and create a ton of small glass shards. What would be better would be a decent blower. Either a backpack or push blower. I like the backpack ones, as they're a bit easier to maneuver and control. That, and a leaf rake.
  16. 05-01-2012 10:48 AM #16
    Okay, poor picture example. They do exist however without the blades, it with blades that can disengage. Call the rental place.
