Results 1 to 14 of 14
Thread: my UNIbrace woes :(
  1. Member sixteen10's Avatar
    Nov 16th, 2008
    South Africa
    2008 Golf V .:R32
    04-29-2012 08:27 AM #1
    Hi guys
    A friend and I tried installing my UNIbrace yesterday and were shattered after 5 hours of fail. The install took so long because it was a new process to us both including stripping the interior.
    Initial pictures before I got fed up and put the camera away :
    I ran into some issues I hope you guys can assist with :
    1. The first was drilling the upper mounting points , we measured everything over and over again , let alone just twice until we were happy that our fitment template looked as close to possible as the images in the rather vague installation guide. Once we drilled we immediately found a secondary layer of metal below and were unsure as to drilling it because of no mention of said layer in the instructions. Having just read LoyalSage's Unibrace thread I see this is now correct.
    2. This is the most concerning issue and I hope the 4 door R32 doesnt differ somewhat to the 2 door , we found the area of installtion to have a "dip" as seen below :
    Which leads to this gap when alligning the brace :
    Now if you tighten the top it pulls the bottom of the brace away from the body.
    We stopped after installing just one nutsert due to this concern. Is this normal or is my 4 door incompatible with the brace?
    Also , the first nutsert install went badly and we had to drill it out , leaving it somewhere in my car. When we installed it the nutsert pulled to the side completely throwing off the mounting point of the brace.
    I hope you guys can assist as I do want to get this in , even after the first install left me far from impressed
    Sixteen10's 4 Door .:R32 | Shawn's Speed Shop | gottiR32 Approved | Milltek Sport
    Quote Originally Posted by zevion View Post
    IMO the first major 'R' engine failure was they put that puny little 4 pot into it to begin with.
    Nov 22nd, 2011
    Aurora, IL
    2008 Golf R32
    04-29-2012 08:36 AM #2
    I cannot comment on the compatibility, but I am sure a small spacer, like a thick washer, wont do any harm.
    I'd like this brace, but I also like transporting my bike in the car when I go mountain biking.
    SKYdude
    08 R32 DBP
  3. Member sixteen10's Avatar
    Nov 16th, 2008
    South Africa
    2008 Golf V .:R32
    04-29-2012 08:40 AM #3
    Quote Originally Posted by SKYdude View Post
    I cannot comment on the compatibility, but I am sure a small spacer, like a think washer, wont do any harm.
    I agree , we would have also gone with the washer , however we thought it safer to check first
  4. Member
    Oct 7th, 2008
    San Mateo, CA
    2008 VW R32 - CW
    04-29-2012 01:34 PM #4
    watching. i hope to learn a thing or two from this thread before i install my unibrace... hope you figure it out.
  5. Member sixteen10's Avatar
    Nov 16th, 2008
    South Africa
    2008 Golf V .:R32
    04-29-2012 01:56 PM #5
    Quote Originally Posted by LoyalSage View Post
    Thanks mate , hopefully some of the guys here can help out. BetaOp9 said he had the same issues , hopefully Bruce will chime in
  6. Member germanbycar's Avatar
    Apr 27th, 2009
    Gainesville, FL
    P51 Mustang
    04-29-2012 02:37 PM #6
    Don't get discouraged. This went better then the first time Shawn and I went at it.
    Paint it black and take it back.
    Shawn's Speed Shop
  7. Member GTItraveler's Avatar
    Apr 24th, 2002
    San Francisco, CA
    2004 RS .:R32
    04-29-2012 04:57 PM #7
    Hey Grant,
    I do my best to follow forums, but sometimes I miss posts. If you were having so much trouble with your UNIbrace XB why didn't you simply email me? I am always available to answer questions, but it's better to do so before getting into trouble.
    My first question, did you use the installation instructions? They are pretty comprehensive and have been honed by user comments through over a thousand installs.
    Regarding the "dip" you can use a washer, but I don't think this is essential as the rest of the brace is bearing directly onto a flat surface. As long as the nutserts are sufficiently torqued there will not be a problem with that gap.
    Regarding your comment about the brace lifting when one nutsert is installed, this is normal and will be rectified when all four nutserts are correctly installed and torqued equally.
    Regards,
    Bruce
  8. Member JRutter's Avatar
    Nov 25th, 2009
    Bellingham, WA
    07 A3 3.2
    04-29-2012 10:15 PM #8
    I don't know if this will help, but here is my 4-door A3 install vortex write-up:
    http://forums.vwvortex.com/showthrea...e-XB-3-install
    A VR6 AWD w/ lots of goodies
  9. Member GTItraveler's Avatar
    Apr 24th, 2002
    San Francisco, CA
    2004 RS .:R32
    04-29-2012 10:17 PM #9
    JRutter: Thanks for posting
  10. Member sixteen10's Avatar
    Nov 16th, 2008
    South Africa
    2008 Golf V .:R32
    04-30-2012 02:35 AM #10
    Hi Guys
    Thanks to Bruce Levin for giving me a call this morning and just chatting me through my concerns. It appears that for the most part we are on track and the install seems to be on the right track.
    We'll get back at this on the weekend and finish it up , one nutsert at a time
  11. Member sixteen10's Avatar
    Nov 16th, 2008
    South Africa
    2008 Golf V .:R32
    04-30-2012 05:01 AM #11
    Just before we finish this , can anyone else confirm they also have that "dip/indentation" just to put my mind at ease?
  12. Geriatric Member PSU's Avatar
    May 15th, 2004
    Pennsylvania
    2004 R32, 2008 R32
    04-30-2012 12:39 PM #12
    It's simply four bolts.
    Easy to remove.
    MKV | MKIV | AWhiteRabbit| perfect.
  13. Member
    Mar 8th, 2001
    Cape Town, South Africa
    1996 Mk1 Citi Golf(Race Car), 1996 Mk3 GTi , 1993 Land Rover Defender 110, 2008 TR MkV R32
    04-30-2012 04:38 PM #13
    Quote Originally Posted by sixteen10 View Post
    Good luck with the install..... may the force be with you
  14. Member sixteen10's Avatar
    Nov 16th, 2008
    South Africa
    2008 Golf V .:R32
    04-30-2012 04:44 PM #14
    Quote Originally Posted by HOWIE-WP View Post
    Thanks Howie
    Sent from my VR6 powered iPhone.
