1972 super beetle asking $5000 for it, just started a new job and do not have time to continue working on it.
Stock 1600 dp, was resealed last year and fitted with a new stock carb done by the Bug House. Flywheel was turned aswell. The car runs great.
Just lowered on a set of topline maxx struts in the front as well as a topline front end rebuild kit (Kit includes center tie rod, right and left tie rods, two ball joints, idler arm bushing, steering damper, damper bushing, urethane control arm bushings, and sway bar bushings, flip it bump steer kit)
Topline front disk brake conversion kit, Complete rear brake rebuild, stops on a dime
The rear has been lowered two outer splines, new polyurethane bushing installed at this time . The rear shocks were replaced with kyb low gas shocks.
New parking brake cables
New front and rear tires on the stock rims.
Vintage speed classic short throw shifter
Custom Autosound radio with aux cord.
New kenwood speakers in the rear
New battery
very small amounts of body rust, its mainly surface rust but all in all body is good, both front pans are solid the only bad spot of rust is under the battery, which seems like most have an issue there. I do have a brand new replacement panel just have not had time to put it in.
