Results 1 to 8 of 8
Thread: No 4th gear
  1. Semi-n00b
    Feb 27th, 2012
    Fort Worth, TX
    1985 VW Cabroilet Wolfberg Edition
    04-29-2012 12:44 PM #1
    My daughter was driving her 85 Cabriolet yesterday and she lost 4th gear. She told me there was no loud kind of sound. She was shifting from 3rd to 4th and missed 4th and hit 2nd. She then shifted back to 3rd and proceded to 4th and there was no 4th.
    The linkage was scheduled to be rebushed today so I did it a day early. I was not too worried about the "no 4th" gear problem thinking that when I replaced all the shifter linkage bushings, it would go away.
    I finished up the linkage bushings and adjusted the shifter and I have the same problem. The shifter does feel better than it did though....
    I manually moved the selector through each gear and the tranny did engage in all gears but 4th. There is a different feel when you manually select 4th compared to the other gears. You can hear and feel the shift for move the gears on all but 4th. When it goes to move to 4th, it feels like it is just the selector moving, nothing else.
    When the car is moving, you can't move the shifter into any of the other gears without the clutch but it will fall right into 4th no problem.
    I search this forum, the bad rabbit forum and looked around the broken rabbit forum but did not find anything specific to 4th gear. I assume this is not a common problem. Any help would be appreicated, I really don't want to pull the tranny unless I am sure I have to. Thanks for reading.
    Apr 16th, 2009
    Wild Wonderful Wv.
    1965 Beetle, 1987 Triple White, 1988 cabriolet, 1993 2dr Fox gl, 1999 Jetta GL
    04-29-2012 04:14 PM #2
  3. Member vwdtag's Avatar
    Feb 2nd, 2005
    1981 Rabbit Conv, 1995 GTI
    04-29-2012 04:15 PM #3
    i would drain the tranny oil and look for any bits of metal. maybe 4th syncro is crushed.
  4. Member
    Apr 16th, 2009
    Wild Wonderful Wv.
    04-29-2012 06:02 PM #4
    Quote Originally Posted by vwdtag View Post
  5. Semi-n00b
    Feb 27th, 2012
    Fort Worth, TX
    05-04-2012 02:00 PM #5
    I drained the oil today and no signs of metal in the oil.
    THe tranny gave no signs of failing and the rest of the gears still shift with no problems. I have been driving it with 1st, 2nd, 3rd and 5th.
    I drained about 55 oz out of the tranny, the oil is pretty black but there is no metal in it. I am going to go back with Pennzoil syncromesh and see what happens.
  6. Member
    Apr 16th, 2009
    Wild Wonderful Wv.
    05-04-2012 02:36 PM #6
    What kind of shape is the golf club in ( the black rubber ball on the lever at the bottom end of the relay shaft) ?
  7. Member CajunSpike's Avatar
    Mar 11th, 2009
    New Orleans, LA
    91 Burgundy Etienne(2), 92 Green Carat, 99 Passat Sedan, 01 Passat Wagon
    05-04-2012 02:41 PM #7
    Quote Originally Posted by Beetle.freak View Post
    Item 2 on this page, the round ball thing on right connected to metal plate.
    http://www.germanautoparts.com/Volks...smission/186/1
    Apr 16th, 2009
    Wild Wonderful Wv.
    05-04-2012 03:11 PM #8
    This one...... if the rubber has come off it can keep the main shift rod from going all the way forward as you're pulling back on the shifter (depending on how out of whack the shifter adjustment is).....just a thought.
