Results 1 to 4 of 4
Thread: 24V VR6 downpipe wont fit
  1. Member twin2626's Avatar
    May 11th, 2006
    Niagara falls
    2003 Jetta GLI
    04-29-2012 03:55 PM #1
    I removed the old downpipe. Only 1 broken stud and a disintegrated exhaust clamp.
    I cut the old pipe at the Y section to be able to remove it easier. But when I went to install the new pipe (Just an OEM pipe), I can't get it up in between the subframe and the heat shields.
    It basically won't go up in through the hole. I just have the car jacked up as I don't have access to a hoist.
    Anyone else run into this issue?
  2. Member spitfire481's Avatar
    Mar 20th, 2007
    Baltimore Md
    04 GTI 24vT, 2013 FR-S
    04-29-2012 06:48 PM #2
    i had to lower the sub frame to install my techtonics downpipes if that helps you any
    Apr 30th, 2007
    Quebec, Canada
    Jetta TDI 03, Corrado 24v 90.
    04-29-2012 06:52 PM #3
    The other way I think you could try is by removing the manifolds, but there's a risk of braking a stud. I don't know if there would be enough room to fit the downpipe under the hood.
  4. Member twin2626's Avatar
    May 11th, 2006
    Niagara falls
    2003 Jetta GLI
    04-29-2012 07:14 PM #4
    It worked. I lowered the subframe a little and jammed the thing in there. What a PITA. I didn't want to risk breaking any bolts on the manifolds.
    Thanks Everyone.
