TTT
#1
A LOT OF NEW ITEMS ADDED...SCROLL DOWN!!!!!
I let my old thread die so this is a new one with some more stuff in it.
Prices DO NOT include shipping
More items will be added as I dig through my garage...
Swallowtail only valve cover: $30
Swallowtail shift boot, perfect $30
Swallowtail dash defrost vents (1 has a couple cracks that are easily repairable:All 3 for $20
Swallowtail manual window washer bottle: $20
Swallowtail metal stalks, condition is fair $20
Swallowtail taillight cover: $10
Poly motor mount inserts: $10 a piece
Burgandy horn button: $15
Tan horn button: $15
Brown horn button: $15
B1 Dasher horn button: $20
GTI sport wheel insert: $8
Early gas tank straps: $20
Gas hard line: $15
Rear strut caps: $8 a set
Oil temp swith: $3
Rad fan switch: $3
Heater control switch: $1
Early Audi Cigarette light assembly: $5
Badges: $10 a piece (Rabbit sold)
Black Ash tray: $10
Jetta heater control panel: SOLD!!
Woodgrain heater control panel: $10
Euro Champagne brown radio faceplate with 1 knob: $15
Hood release, no cable included: $15
Tan shifter base: SOLD!
Black 4+E shift knob: $15
Rear side marker: $5
Golde tan/chrome sunroof crank, needs polishing: SOLD!!
Oil and coolent caps: $5 a piece
Rear strut mounts: $10
Uber rare NOS "Passat L" Metal badge, you'll never find another $35
Shaved driver's side fender off a '78 $85
Blue vinyl shift boot, in great shape out of a Jetta $30
Only imperfection:
Beer tap handles, drill out and make shift knobs!
Rogue Dead Guy Ale $35
Bells Third Coast Ale gold top $10
Points & Condensor $3 each
Window cranks SOLD!!
Door handle surround $2
and inserts $1 a piece
Mk2 Weighted shift rod $20
Defrost switch $8
NOS chrome trim for gas cap SOLD!
Rabbit shifter rod SOLD
3" Aluminum shifter extensionSOLD
Early Early base model rabbit rubber shift boot NLA
Cork valve cover gasket set $10
Late Westy rear bumper rub strip, perfect, the brown mark is the lighting not the strip$15
VW Grill emblem $10
Inside hatch covers $20
What appears to be a Scat chrome oil pan. It came on an engine i bought and i was told it leaked a bit, may need a small weld repair on the side otherwise great shape $30
Picture of side where the leak is cover with silicone
Tan early dash carpet $30
Water pump housings, take you pick for $15
Swallowtail airbox, freshly picked from the yard. Will clean up nicely, no cracks! $40
Later style bearing strut caps, small cracks on the bottom of one, but not visible when installed. Hold tight! $15
Jetta floor mat. I've been using this to put my wet or dirty shoes on for a while. It's dirty but will clean up great. $10
13x5 Scirocco man hole cover rims. One was a spare, probably never used and in excellent condition. the other is also in great condition but a little dirty. No rust, curbage or bends on these! $50 for both or make an offer on a single
Spare:
Other:
Exhaust stuff Clamp and hangers no longer available,make an offer on the rest!
Used 8v 190mm clutch kit with some life still in it, didn't slip at all when installed:
Make offers
Complete 1.6L Fuel injected 8v cylinder head $20
Early front tan door cards in useable shape (Fits caddy', 4-door rabbits and jettas): $25
Drivers side:
Passenger side:
American bumper shocks (One depressed but can be pulled out) These have not been drilled out like most: $35
Datsun Chrome oil caps. Fit a bit loose need minor mods to fit to your valve cover: $15 each
Compared to vw one:
More random stuff:
Exhaust stabilizer bar $10
Oil temp switch $3
Rad switch $4
Shift linkage piece $5
Some sort of throttle bracket: $10
U piece? Make offer
2.0L Injectors, unknown condition $10 a piece or $30 for all 4
I'll add more when i dig through some more stuff...![]()
#6
Door sills are sold!!
#8
Tan shift boot base sold!
#11
Double bump but just added some new stuff![]()
#15
Chrome gas cap trim is sold, along with new items added!!
#17
plz u still have it right
#19
#20
Large duckbill, shift rod extension, and jetta heater control panel are all sold!!
#23
Swallowtail hood latch and window cranks are sold!!
#27
Swallowtail seatbelts are sold!!
#28
Grant wheel is sold!!
#33
Polo wheel sold!
2 shift knobs and another 3" shifter extension are now for sale
Some prices lowered![]()
