Results 1 to 24 of 24
Thread: Why is my 8v not running
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    04-29-2012 08:59 PM #1
    I just rebuilt my 8v and have all but the vacuum line on the side to the booster and one in the front to some emissions device hooked up.. Its cranking and is getting fuel and spark.. and timing is dead on
  2. Member AnAgentOrange's Avatar
    Jul 14th, 2011
    Palmdale CA
    91 GTI / 69 FJ40 / 98 Jetta
    04-29-2012 09:03 PM #2
    Plug those vacuum leaks
    Quote Originally Posted by under the radar View Post
    if you're not into chicks, a dude can hold your cup too.
    Quote Originally Posted by BattleRabbit View Post
    How do you kill a Mk.ii? Run it with low oil, at redline for a few hours while jumping it off things. Fill the engine with sticks and dirt. Repeat.
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    04-29-2012 11:05 PM #3
    Quote Originally Posted by AnAgentOrange View Post
    will it completely not start at all?
  4. Member AnAgentOrange's Avatar
    Jul 14th, 2011
    Palmdale CA
    04-29-2012 11:13 PM #4
    That's a lot of unmetered air it's receiving from that booster line. Definitely could be. But can't go further without fixing what we know to be wrong
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    04-29-2012 11:20 PM #5
    where should the distributor marks be pointing?
  6. Member Esevw's Avatar
    Dec 27th, 2002
    Puyallup, WA
    83 rabbit GTI
    04-30-2012 07:40 AM #6
    Quote Originally Posted by cll2993 View Post
    To piston #1, farthest left when your looking at the motor.
    Sent from my SAMSUNG-SGH-I727 using Tapatalk
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    04-30-2012 11:17 AM #7
    Quote Originally Posted by Esevw View Post
    ok I think that may be my problem I have it and the rotor pointing towards #4/ transmission
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    05-13-2012 09:44 PM #8
    I got the motor to start last week and it would idle (poorly) and die after about 20 secs. Now after sitting for a week it wont do anything.. but when i spray starter fluid it acts like it wants to but doesnt. whats going on?? i have all the vac leaks plugged now
  9. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    05-13-2012 09:53 PM #9
    With #1 cylinder @ TDC, the rotor in the dizzy should be pointed at about 1 o'clock and that should correspond to the mark on the dizzy body. And the mark on the cam sprocket should be level with the VC gasket surface.
    Check that first.
    FS:Sunroof Deflector
  10. Member
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    05-13-2012 10:01 PM #10
    the cam mark lines up and so does the dizzy
  11. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    05-13-2012 10:08 PM #11
    And cylinder 1 is at TDC, meaning the FW mark lines up also? Do you have the firing order correct and the rotation of the dizzy as CW?
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    05-13-2012 11:35 PM #12
    1342. crank is tdc also
  13. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    05-13-2012 11:53 PM #13
    compression?
  14. Member
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    05-14-2012 08:31 AM #14
    I'm not sure what it is.. I'll get a tester and check it within a couple days
  15. Member ps2375's Avatar
    Aug 13th, 2003
    Meridian, ID
    80 Rabbit, 94 Golf
    05-14-2012 08:58 AM #15
    Which cam mark, the one on the inside or the outside? I'd have to go look in my Bently Manual to be sure which one it needs to be.
  16. Member AnAgentOrange's Avatar
    Jul 14th, 2011
    Palmdale CA
    05-14-2012 01:16 PM #16
    Quote Originally Posted by ps2375 View Post
    It's the inward facing mark. Ask how I know, lol
  17. Member
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    05-14-2012 11:09 PM #17
    It's the one on the inside
  18. Member
    Aug 28th, 2003
    St. John's Newfoundland
    1992 Jetta
    05-15-2012 09:20 PM #18
    Yes. The timing mark on the cam pulley is towards the cylinder head. The other mark is used when the pulley is installed on the intermediate shaft. The cam and the intermediate shaft use the same pulley.
    Some times when I'm trying to get a car to start that refuses to start I will adjust the distributor while cranking the car over to see if it will make an attempt to fire up.
    Keep us posted.
  19. Member
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    05-17-2012 10:03 PM #19
    The compression is 160 170 160 150... So I have spark compression gas and air.. So I think tomorrow I'll fill up the tank will high octane gas and some water treatment stuff.. The car sat for 2 years then I got it got it running but it was knocking do I rebuilt it and since then I've put a gallon of gas in it and it idled a for a little while on that.. Could it be a gas issue maybe?
  20. 05-18-2012 09:51 AM #20
    I'm guessing we're talking MKII DigifontII here...
    If you have:
    Cam Sproket Inside Mark level with the top of the head
    Intermediate Sproket outside dot lined up with Main Pulley Notch (+/- 1/2 tooth)
    Installed: Main Pulley, Tensioner, Timing Belt, Dist. Squid Assy (1, 3, 4, 2) {CW rotation} Air Box (with MAF) All Sensor connections, All Vacuume lines, and Idle stablizer, and PCV
    (NOTE: alternator, air con, water pump and power steering belts are optional for short testing runs)
    Distributor installed with connector towards your right hand, when facing the vehicle.
    Neutral Safety or Clutch Interlock switches
    Proper amount of Motor Oil with pressure sensors connected.
    A GOOD WELL CHARGED BATTERY
    Make sure the vacuume to the Fuel Pressure Regulator is as short to the throttle body as practical. Sometimes vac lines get stopped uo.
    Ensure sparkplug wires (including the coil) are in good condition, firmly seated and routed away from ground sources.
    Check your Idle Adjustment Screw O-ring
    Check all Electrical Grounds and Bonding Straps are installed, all other connections are clean and firmly seated (especially CPU, can be rather fussy...).
    If she has sat up a while, make sure birds are not living in the exhaust pipe, or bees in the fuel lines.
    NOW
    if you have all of that, and you have new clean gas, air and spark, and still all cranky and no starty...
    pull the blue coolant sensor connector off and give her a crank.
    If she starts and runs, run her above 3000 rpms three times and it should reset the CPU.
    At least I think it's three, maybe five. My buddy said he thought it was 3200 for five times...
    For best results, consult Bentley, or the internets.
    If it runs with it off, and dies when you plug it back in, then you maybe have a bad sensor somewhere.
    If still no fire then consult on how to check MAF, Hall Effect, Throttle Switches, both Coolant sensors (sometimes three) and Coil triggering.
    If all else fails, be patient. Avoid any urges for "exploratory surgery", but specific inspections or tests may be required.
    Good Luck.
    Your mileage may vary.
    EDIT: I think Bentley says something that the compression for all of the cylinders has to be within a certain range. I did not read it closely at the time, but 20 psi maybe a lot of difference.
    Any experienced gearheads care to comment? (how about head bolt tightness?)
  21. Member JettaKid90's Avatar
    Jun 19th, 2009
    Seattle, WA
    90 Jetta 8V (Cracked Head Under Reapair) (She's ALIIIVE! 4/25)
    05-19-2012 04:59 AM #21
    Quote Originally Posted by threecaster View Post
    1.8 litre:
    New . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10 to 13 bar (145 to 188)
    Minimum . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7.5 bar (108 psi)
    Maximum permissible difference between any two cylinders . . . . 3.0 bar (43 psi)
    Cylinder head bolts (engine cold):
    Stage 1 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 30 ft lbs
    Stage 2 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 44 ft lbs
    Stage 3 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Tighten further 1/2 turn (180°)
  22. Member
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    05-20-2012 05:15 PM #22
    Now my fuel pump relay is clicking rapidly and won't stop the fuel pump won't kick on or anything.. I put another one on it and the same thing
  23. Member JettaKid90's Avatar
    Jun 19th, 2009
    Seattle, WA
    05-24-2012 02:16 AM #23
    From what your saying, there might be a short to ground in the wire from the relay to the pump itself cousing that affect. A diagram and a nice DMM will do the job.
  24. Member
    Sep 16th, 2011
    simpsonville ky
    91 Jetta Coupe
    05-25-2012 12:57 AM #24
    I figure there's probably a short in 12v or ground
