Results 1 to 16 of 16
Thread: 97 vr6 timing chains and guides questions
  1. Member bubba293's Avatar
    Jan 27th, 2012
    Dillsburg
    1991 ford mustang 5.0 LX(sold),,, 97 gti vr6
    04-29-2012 10:35 PM #1
    Hey there, i just bought myself a 97 gti vr6 with about 155k on the clock, i do have an engine noise but i cannot tell if it is the timing chains and guides or if it is just more of a valve tapping, so can someone explain to me how to actually figure out if it is the timing chains and guides. Thanks, jordon
    Im gonna find me a clean gti!
  2. Member Stangrcr1's Avatar
    Mar 5th, 2012
    Marysville, WA
    2001 Jetta VR6 12v 2000 Ford F250 Diesel 4x4 2007 Ford Focus 1982 Ford F250 1956 Willys
    04-29-2012 11:43 PM #2
    Pull the intake, valve cover and upper timing chain cover and take a look.
    Here is the info on how to do it:
    http://forums.vwvortex.com/showthrea...s-on-a-12v-VR6
  3. Member bubba293's Avatar
    Jan 27th, 2012
    Dillsburg
    04-30-2012 06:47 AM #3
    Once i remove those, what am i looking for, like how will i know if the chains and guides are worn, just sights of wear? Or what
    thanks, jordon
  4. Member Stangrcr1's Avatar
    Mar 5th, 2012
    Marysville, WA
    04-30-2012 09:05 AM #4
    Go read the first couple pages of the link I supplied.
    I replaced my chains at 153k and all the guides were broken.
  5. Member bubba293's Avatar
    Jan 27th, 2012
    Dillsburg
    04-30-2012 10:23 AM #5
    i listened to your sound clip, and mine doesnt sound like that, i think mine might have more of a valve tapping rather then the chains and guides needing done, also i dont see them lasting 155k miles...
  6. Member bubba293's Avatar
    Jan 27th, 2012
    Dillsburg
    04-30-2012 10:24 AM #6
    also could you tell me about the labor in hours it takes to do the chains and guides?
  7. Member dogyouare's Avatar
    Aug 9th, 2009
    Port Orange, FL
    90 Jetta GL, 91 Corrado G60, 96 Golf GTI, 88 300SE
    04-30-2012 10:37 AM #7
    depends anywhere from 3hr to 1day
  8. Junior Member
    May 20th, 2011
    2000 Jetta VR6
    04-30-2012 11:30 AM #8
    Quote Originally Posted by dogyouare View Post
    haha, 3 hours to replace all guides and chains.....
    probably closer to two full days to do it right, removing the transmission, doing upper and lower chains/guides, tensioners, etc.
  9. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    Mk3 VRT, Mk4 VRT, Mk4 VR
    04-30-2012 12:08 PM #9
    Quote Originally Posted by slagdemon View Post
    That 3hr estimate is a bit ambitious... Doable but ambitious.
    Especially for someone who will be attempting this for the first time and not having the access to a shop lift etc. I like to dedicate and entire day to doing this (because invariably you get in there and see something you don't like and need to change - eg flywheel, clutch, bolts, rear-main, etc).
    "OP sounds like a MKIV guy"
  10. Member bubba293's Avatar
    Jan 27th, 2012
    Dillsburg
    04-30-2012 12:36 PM #10
    Well i am in a tech program and am confident on doing this. But im running out of shop days and probably wont be able to do it here, so i might have to have it done somewhere
  11. 04-30-2012 12:43 PM #11
    Quote Originally Posted by V-dubbulyuh View Post
    Also this would be a good time to replace the thermostat housing, thermostat, coolant pipe, cover and coolant temperature sensor if they are the original components. With these parts removed access is improved when resealing the upper and lower timing chain covers. In fact, I think for a MK3 AAA engine the thermostat housing blocks access to one or maybe more screws on the upper chain cover.
  12. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    04-30-2012 01:28 PM #12
    Quote Originally Posted by Peter Badore View Post
    Agreed, I do the coolant system at the same time.
    Plan on a full day though. You do not want to rush this installation.
    Last time I did this , just last week... I did not like the condition of the bolt on the intermediate gear and had to special order it... that in itself was 3 days. You always find something that you will want to upgrade. If there is anything questionable - replace it because you don't want to go in there within short time to replace something that you had full access to.
  13. Member bubba293's Avatar
    Jan 27th, 2012
    Dillsburg
    05-01-2012 11:06 AM #13
    How about a price on how much it would cost to do this myself, and how much it would cost to get it done at a shop?
  14. Member V-dubbulyuh's Avatar
    Nov 13th, 2005
    05-01-2012 11:26 AM #14
    Quote Originally Posted by bubba293 View Post
    Yourself:
    -Chains ~$175
    -Crackpipe & Thermostat kit ~$125
    -Rear main ~$15
    -Misc (bolts, gaskets, sealants, brake cleaner, etc) ~$50
    -Clutch kit if you want to do that too ~$depends on what you want
    -Your time (no idea what it's worth to you)
    And know it's done right.
    Someone else:-All parts quoted above.
    -Labor ~$400-700 depending on who you go to
    And hope some certified tech/VW-Audi expert has done right.
  15. Junior Member
    May 20th, 2011
    2000 Jetta VR6
    05-02-2012 10:38 AM #15
    I'm pretty good with tools and cars. I've rebuilt engines and automagic transmissions, but still, one day would be pushing it unless you start at the butt crack of dawn and finish late.
    Then again, I'm slow and methodical with my car.
  16. Member dogyouare's Avatar
    Aug 9th, 2009
    Port Orange, FL
    05-02-2012 11:28 AM #16
    yea 3hr is a kill... that includes a vw repair shop with everything in hand (parts, tools, lift, tranny jack, and more). big thing is take your time
