Im not usually a fan of b3's but I really like![]()
#1
Some point and shoot action, I was going to edit but my PS CS3 trial ended a few days ago and I need to get a new code lol
1991 Passat VR6 swap. B4 from the B pillars forward conversion inside, full OBD2 swap and full B4 harnesses. H&R cup kit, B4 front bumper, and a touch of POS.
98 Silver Arrow Jetta
#3
You're not running w/o the air filter are you?
'90 Corrado |'92 Jetta 8v | '91 Golf 8v | '95 GTI | '98 Jetta VR6 |'04 Jetta 2.0 |'04.5 GLI |'92 Passat VR6
#4
Only for about 50 miles. I picked up a spectre from autozone...its awful. Depending on if I keep the car im going to build an intake
#5
Look at the pictures without reading the text, and I was like VR + 4x100
Is that mono-wiper properly converted, as in modified linkages? Looking forward to doing the same thing to mine and I'd enjoy peeking at somebody else's setup.
#6
My VR MK2 was also 4 lug, I like the narrow track and wheel options!
The mono wiper was a function thing. I flipped my wipers on a few weeks ago and the drivers side arm didn't stop when it went up, and continued past the A pillar lol. The nub is stripped out. If I can mod the linkage I'll keep the mono.
#8
I bought this car in July with no motor for $200, gutted it from the B pillar forward and replaced all the wiring and trim with B4 stuff for another $200. Added my OBD2 VR swap I had laying around and boom! $400 VR6 passat. Spun a rod bearing in October, drove it to the last show of the year and put a hole in the block on the way home.
All reds
B4 Dash
B4 bumper, coilovers, and wheels
FREEBIE! Floor mats from a dealer who's had them for 20 years.
Some of this BS
Porting a spare head
I put together another motor and had a ticking issue....
I put my ported head on, 3 angle valve job, all stock OEM hardware (brokestatus), MK4 HG and put it back together. It pulled as strong as my buddies 200whp MK3 VR <--- his words, and I agree. Only issue is it was blowing smoke like crazy and had lifter tick. The mechanic told me it was a collapsed lifer and bad rings, which is what my guess was anyway, just wanted a 2nd professional opinion. On the way back from the shop yesterday I heard a rod bearing let loose....
Motor #1 - Rod bearing
Motor #2 - Bent valves
Motor #3 - (same bottom end as #2) Spun rod bearing
Hopefully #4 will be kind to me.
#9
How about some ARP rod bolts this time around? It probably wasn't the bearing itself that took a dump but the fasteners.
#11
I like this threadGood form!
COMING SOON...!
Preventative Maintenance is like tying your shoe laces... fools be trippin'
#12
So my story continues...
On Monday around 8:30 pm I pulled my friends good obd1 VR6 that he was trading to me, finished up and made my 1 hour journey back home. I pulled the bad motor out of the passat and got the new one put in, odb2 harness swapped, and running by 2am.
Tuesday night I worked on it from 10p til 4a
Wednesday I worked on it from 10p and didn't stop until 6pm Thursday night.
Things I accomplished in the week:
Pulled 2 motors
Installed 1 motor
Rear mounted battery
Re-loomed all engine bay wiring
5 lug 11.3" swap
MK4 rear calipers (with 2 working ebrake cables!!!)
My wife ran stereo wiring
Installed H&R cup kit (designed for a GTI, so I worked up custom rear mounts)
Painted Beetle steelies
Painted a RX2 for a spare
bled brakes
got an alignment done
Ended up rolling on some neat looking tuner wheels since they had tires mounted already
and the list is longer but it's all the little things in between that take up minutes
The car purred like a cat, drove great too so we loaded up and got on the way. About 2 hours into the trip the drivers front wheel bearing started to hum. Dually noted.... About 2 hours from Helen we got a bad wobble so I pulled off and the lug nuts had backed out. Ball seat lugs on cone bored wheels, and the heat/vibration from the wheel bearing didn't help. I torqued them down good, double checked my axle nut and hit the back roads into town.
I skipped all the activities Saturday, didn't even get to go to the show because I was running all over trying to fix the wheel bearing. I picked up a bearing at Autozone and we rigged a 'shop press' that wasn't quite fit for the job. Luckily in the town about 10 miles away I stumbled into an open shop, they hooked me up big time and I left with a spinning spindle/hub. Everything was put together as night fell, and I figured the best way to break in a new wheel bearing is with some burn outs, so I did 2 or 3 big ones.
This morning we got up and I checked fluids, put loctite on the lugs, checked the axles nut again, tire pressure, put a full 18 gallons in it and headed on our cruise home via the tail of the dragon. I couldn't down shift into second gear from 3rd so I was taking it sorta easy in the twisties, but I was getting it with a few MK3 VRs and my friends e36 M.
15 miles out I heard my motor rattling, pulled over to hear it better and knew right away what it was. Yup, a rod bearing...
Alex from Panzer Automotive out of Louisville ran his VR6T Rallye Golf out to meet me. Kinda sucked for him, I mean he HAD to drive a 500+ hp AWD MK2 through perfectly smooth winding mountain roads. He confirmed the rod bearing diagnosis, headed back to get his truck and trailer to bring me back into town. Chris Collier of C2 Motorsports graciously allowed my paper weight in his trailer for a ride back to Louisville. AAA was going to be $2000+ for the tow.
Clint (Nash_TDI) gave my wife an I a ride home. That meant Luke (Psst97), Clint, my wife and I put everything unnecessary in the trailer so his car wouldn't rub.
We made it home, got back to our 9 month old who was so happy to see us. The support from some in the community was outstanding, from my friends riding around with me Saturday looking for parts and a shop to Alex and Chris going above and beyond to help us out. Our spirits are still up even after this **** luck thanks to everyone who helped.
#13
I know that roller coaster your riding. I have a q for ya. Is that face mask diy?
#15
Found a B3 and B4 at a local just yard, both are mostly complete. I'm getting the hood and maybe fenders and doors from the B3, and the fuel tank, air box and all the A/C stuff, unbroken cup holders, center console and trunk carpet from the B4. I shouldn't be doing it, but my bad rod bearings aren't going anywhere, and who knows when these cars are headed to the scrapper!
