Yes and yes. If your not making a bunch of power or your not Turbo, there is no reason to vent the vavlecover. Just use the stock breather in the block.
#1
I want to do a catch can on my stock 2l 16v. I am kind of unsure where to start. Can i just use the stock block breather and hook that up to a catch can and then run a vent with a filter on the end under the vehicle. And then block the original hookup from the block breather to the intake?
Do I need to run the valve cover breather from a newer beetle?
Just some pictures of your setup would help.
Thanks
#2
84 Rabbit GTI, 12.1.1 comp 16VT, 15psi 307whp 278wtq Winner 2012 bugRun Pro class
JONES PERFORMANCE VW, Swaps, Custom Builds, MS install & tuning. MK1, MK2, Specialists
2vwjones@gmail.com Website under construction.
#3
OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
Mk2 16v parts for sale.
Mk2 Golf_GL 16v @ Streets of Willow Raceway.
Project Гольф Мк2 (Carbed)
#4
there are a few good threads on this subject worth reading in the archives
91 GTI 16V Project - All Motor - My Build Thread - http://forums.vwvortex.com/showthrea...ssembly-Thread
#5
if you are still running stock injection, and a mostly stock engine, leave it alone
