VWVortex.com - FS: 1980 Scirocco S 16v Turbo, Mars Red
    Results 1 to 7 of 7
    Thread: FS: 1980 Scirocco S 16v Turbo, Mars Red
    1. Member 206danebmx's Avatar
      May 16th, 2001
      Seattle, wa
      1996 Passat TDI
      04-30-2012 02:44 AM #1
      So need to sell my scirocco, sad day but I think its time to move on.
      Here are the details:
      Suspension/Chassis:
      -ST coilovers (brand new)
      -Front lower brace 16v scirocco brace
      -Have rear swaybar (not installed right now)
      -10.1" front disc brakes from 16v scirocco, mintex pads
      -Have front hawk pads (not installed at this time)
      -SS Brake lines all around
      -Kosei K1 15X7 rims with Bridgestone RE-11's, 205-50-15 (sticky tires)
      -Poly motor mounts all around
      -Quaife short ratio steering rack with new rack and all new tie-rods
      -Custom reinforcement for front motor mount that attaches to bumper rails
      -Also have a set of ground control coilvers (Koni dampers) that I may include too, they have stiffer springs than the ST setup, (like 400 front and 350 rear)
      Engine/Drivetrain:
      -1.8L 16v (has about 5K miles since rebuild), rebuilt bottom end with Forged JE pistons, 8.5:1 compression
      -2.0L 16v connecting rods, ARP con rod bolt/studs
      -ARP undercut head studs
      -T3/T4 Garret turbo
      -custom 2.5" exhaust, one muffler and one resonator
      -Open dump with tial wastegate (gets real loud under full boost)
      -Tial 50mm BOV
      -air to air intercooler
      -Runs on Megasquirt II, V3 system
      -020 2Y Tranny was just rebuilt and Peloquin LSD was put in by finetuning. About 500 miles on this setup.
      -Currently running Spec Stage 1 Clutch/pressure plate (Have Clutchnet stage III clutch/PP package new uninstalled)
      -Entire shifting system was just gone through when tranny was rebuilt, all new bushings
      In dash Sensors:
      -Oil pressure, Oil temp, EGT probe (in exhaust mani before turbo), innovate wideband AFR, boost/vacuum gauge
      It dynoed last summer at 240whp at 15psi. Is setup with 15psi wastegate spring.
      Car is pretty straight, although there is some damage to the driver's side fender that just recently happened, planning on replacing the fender but have not been able to find a replacement. Picture of damage is in the link below. Only damage is to fender, car drives fine just as it did before the damage.
      Here is a link to an album with pics:
      https://plus.google.com/u/0/photos/1...76185669872209
      Message me if interested.
      $5800...this car really needs nothing, it runs flawlessly and virtually everything is either brand new or is in good shape.
      1996 Passat TDI
      "Horsepower wins races, torque sells muscle cars"
    2. Geriatric Member ValveCoverGasket's Avatar
      Mar 20th, 2002
      trendy homeless camp, OR
      german and british
      05-01-2012 12:45 PM #2
      bump for a really nice car
    3. Junior Member
      Aug 1st, 2011
      Marysville/Everett, WA
      1978 Rabbit L (Alice) 1996 Passat GLX (Amalia)
      06-26-2012 04:07 AM #3
      God i would love to buy this but don't have 6k but i do know where there are some rocco fenders Arlington pick n full has 2 roccos i got a neuspeed throttle body off of one
    4. Member VWM4YH3M's Avatar
      Sep 20th, 2011
      Where it rains. PNW
      RUINED 83 GTI
      06-26-2012 11:56 AM #4
      bump wishing i had 6G's
      THE ONLY BAGS I USE WRAP AROUND MY 40oz KDL GNARlow
      SECONDS FROM THE END, WHATS IT GONNA BE?
      PULL THE TRIGGER BITCH
    5. Member 206danebmx's Avatar
      May 16th, 2001
      Seattle, wa
      1996 Passat TDI
      07-06-2012 01:47 AM #5
      Still looking to sell, and thanks for the pointer on a fender, I'll look into that.
      $5800
      Message me if interested. I updated the original post as I got the SS braided brake lines installed and I've also got a brand new clutchnet stage III clutch/PP that comes with uninstalled.
      1996 Passat TDI
    6. Member 206danebmx's Avatar
      May 16th, 2001
      Seattle, wa
      1996 Passat TDI
      08-05-2012 02:29 AM #6
      Price drop...$5400...still for sale
      1996 Passat TDI
    7. Member 206danebmx's Avatar
      May 16th, 2001
      Seattle, wa
      1996 Passat TDI
      08-26-2012 12:35 AM #7
      SOLD
      1996 Passat TDI
