Results 1 to 26 of 26
Thread: Any way to achieve a quieter suspension?
    Aug 20th, 2011
    2012 Audi TT Base Model
    04-30-2012 07:22 AM #1
    I enjoy driving my TT more than, well, just about everything. In my town, the road repair crews can't make a smooth repair if their life depended on it. Thus, my ears get pounded by the impact noise of my suspension as I go over the bumps and ridges.
    The obvious way to get a quieter ride, in general, is to get quieter tires. The OEM Bridgestone Pontenza RE050A's are horrible in this regard. But beyond that, is there anything else I can do to make the car quieter over rough roads? I've already had the car sound dampened, which helped with some of the road noise.
    Softer bushings? Softer spring mounts? I have no idea here..... I"m willing to traid a bit of handling for ears that aren't ringing by the time I arrive at my destination.
    2012 TT, Brilliant Black, Black Alcantera, Heated Seats, Mag Ride, custom JL Audio system with a Pioneer AVIC Z140BH h/u, and a really big go button under my right foot.
    Feb 22nd, 2006
    Stuttgart, Germany
    TT-RS
    04-30-2012 08:33 AM #2
    New tires will help quite a bit. But I don't think you have many budget-ranged options. Basically, you can get new springs or a cup kit which is fairly cheap, but manufacturers don't make them softer... They make them stiffer for better handling. Your only option would probably be an adjustable coilover kit with multi-rate springs. You could adjust it fully soft, but I still think this might be as stiff or stiffer than stock. I don't know
    Where do you live?
    - Jeremy -
    Misano TT RS w/ Tech Pkg, Aluminum Pkg, Sport Exhaust, Alcantara, Heated Seats and Black/Red Wheels + Milltek secondary decat pipes
    Aug 20th, 2011
    04-30-2012 08:36 AM #3
    St. Louis MO.
    I have mag ride suspension, so there's no new shocks or struts as an option.
    What about the control arm bushings? The cushions on the top an bottom of the springs? Is there any way to isolate some of the noise from translating thru the springs and control arms? Even a 15% decrease would be noticable.
  4. 04-30-2012 01:18 PM #4
    I'm not sure what impact noise you're referring to but maybe try switching to 18s?
  5. Member caj1's Avatar
    Feb 16th, 1999
    Washington, DC
    2013 BMW 335is
    04-30-2012 05:42 PM #5
    Trade it in for a Buick.
  6. 04-30-2012 06:07 PM #6
    I experience the same issue. Road condition sucks here in WA
    Aug 20th, 2011
    04-30-2012 08:30 PM #7
    Quote Originally Posted by JohnLZ7W View Post
    My car came with 18's.
    The noise is the Ka THUMP every time I go over an abrupt ridge in the road. Imagine an asphalt repair where someone glopped it on without steamrolling it. Now, drive your car over it. THAT is the sound.
    I hear the sound pretty much equally on all four corners, so I think the car is just designed to be loud and unforgiving. I even bought the $2900 mag ride suspension because I read that, when in comfort mode, it is softer than the normal suspension. The noise is the same regardless of what mode it's in.
    I think before I spend too much more time on suspension research I should spend time on tire research. The more I think about the noise the more I realize that these crap Bridgestones are largely to blaim.
  8. Member Fissues's Avatar
    Nov 6th, 2008
    Marblehead
    '09/TTS/Roaster/APR Tuned 100 Octane, '11 S5 Cabrio
    04-30-2012 09:06 PM #8
    My TTS was the same noisy bitch before I replaced the tires with the Conti DWS. They absolutely transformed the car from rude and insane to very quiet and insane. I picked up the 19's at tirerack for 186.00 and their fine for anything this side of tracking even pushing 355hp.
    '09 TTS/Roadster/APR Tuned/100 Octane - 1st TTS delivered in the US, '11 S5 Cabrio
    Mar 4th, 2004
    Canada EH !
    2010 TTS Coupe, 2011 Q5, 2004 MSM
    04-30-2012 09:38 PM #9
    Quote Originally Posted by MoreGooderTT View Post
    If memory serves me, I think you've already done the tire research. Get rid of the run flats and replace them with a set of the Conti DW and call it a day.
    2010 Ibis TTS - PODI in OSIR mono/ Neuspeed RSB/ MTM 330 flash/ Milltek DP and exhaust/ HPA DSG Stage II + Haldex/ 2011 RNSe w/Dension Gateway 100/ R8 V10 steering wheel/ BC Forged RS31 wrapped with PSS
  10. 04-30-2012 09:58 PM #10
    Quote Originally Posted by Stevelev
    Second that. Contis do seem quiter and smoother. I tried Dynamat but it didn't help much (and was expensive to install). I think the root of the problem is that the aluminum front end used in the TT transmits more road noise than steel (but making the car more nose-heavy would be a phyrric victory).
  11. Member caj1's Avatar
    Feb 16th, 1999
    Washington, DC
    2013 BMW 335is
    04-30-2012 11:07 PM #11
    Quote Originally Posted by Stevelev View Post
    The TTs do not come with run flats, at least 2011+
    Aug 20th, 2011
    05-01-2012 07:25 AM #12
    You're correct. I have done research and had concluded that the Conti's DW's were the way to go. Unfortunately, they are no longer available. Tirerack says they are refreshing the tire to handle heavier load ratings. That translates into stiffer sidewalls. I expressed my surprise to the Tirerack rep I was chatting with. Why would they mess with a tire that is a hot seller? It makes no sense.
    So.... the research kicked off again last night. I still haven't found what I want.
    I'm leary of the Michelin Pilot Super Sport because of their 97 XL load rating. I need softer sidewalls to compensate for these roads. Again.... handling must be sacrificed if my ears are to be saved.
  13. Member
    Aug 20th, 2011
    05-01-2012 07:33 AM #13
    Quote Originally Posted by caj1 View Post
    I'd rather shove a stick through my head from ear to ear. That would serve as permanent earplugs so that I can't hear the noise.
  14. Member
    Mar 4th, 2004
    Canada EH !
    05-01-2012 09:31 AM #14
    Really ??
  15. Member
    Mar 4th, 2004
    Canada EH !
    05-01-2012 10:01 AM #15
    Turn up the tunes ?
    I can honestly say that I have not felt any sacrifice in the handling of my car after swapping to the 245/40/18 Contis (from OEM 255/35/19's). I typically push my car when safe to do so and in day to day driving, the tires provide lots of confidence in both wet and dry conditions. Frankly, I doubt most people would have much to complain about although perhaps mentioning the 12 lb per corner weight savings should be mentionned in my situation. I'm heading to the track in approx. 3 weeks (will probably go a couple times this year) and look forward to seeing how they fare when pushed harder. Since this is my 2nd season on them, they'll need replacement for next summer. Unless the track manners change my mind, there's a good chance I'll end up with the same tires again.
  16. Member caj1's Avatar
    Feb 16th, 1999
    Washington, DC
    2013 BMW 335is
    05-01-2012 11:17 AM #16
    Really ??
    Yes.. just a pump and some spray sealant.
  17. Member caj1's Avatar
    Feb 16th, 1999
    Washington, DC
    2013 BMW 335is
    05-01-2012 11:19 AM #17
    Conti DWS should be fine for you. Quieter and more traction while only sacrificing a bit of handling.
  18. Member J662's Avatar
    Dec 7th, 2011
    San Diego
    2012 Black TT-RS • GIAC Stage 2 • AWE SP Exhaust • AWE Intercooler • 034 M Sway • 034 SS Brake Lines
    05-01-2012 05:26 PM #18
    Buy a caddilac.
  19. Member Fissues's Avatar
    Nov 6th, 2008
    Marblehead
    05-01-2012 07:17 PM #19
    DWS
  20. Member
    Aug 20th, 2011
    05-01-2012 09:50 PM #20
    The Conti DW's are on my short list, if they ever get back into production.
    Thanks for the advice folks.
  21. Member caj1's Avatar
    Feb 16th, 1999
    Washington, DC
    2013 BMW 335is
    05-01-2012 11:47 PM #21
    The Conti DW's are on my short list, if they ever get back into production. 's
    dws, not dw's
    http://www.tirerack.com/tires/tires....emeContact+DWS
  22. Member GaBoYnFla's Avatar
    Oct 2nd, 2005
    Florida
    2011 Audi TTS
    05-02-2012 06:34 AM #22
    Really ??
    No, really, they don't come with run flats! I've got used to the noises and just love the cars handling....I even stiffened the car up a bit with H&R Sport Springs and Neuspeed front and rear larger sway bars....
    Part of it is probably the aluminum front end....but it's all worth it to lighten it up to me! Try you stick idea and get back to us on how it works?
    It's me, it's Earnest T!
    2011 Audi TT S
    Black on Black
    Clear bra, H&R Sport Springs, Magride, Neuspeed 25mm front and rear sway bars
  23. Member Black BeauTTy's Avatar
    Jun 11th, 2011
    SE, PA
    05-02-2012 08:25 AM #23
    This may sound odd, but when I switched to the HRE's, the sound of the suspension changed dramatically. Just getting some of the mass out of the corners helped a ton. Food for thought.
    2012 TTRS: Daytona Gray, Tech Pack, Heated Alcantara, CF Mirrors
    Go Mods: GIAC Stage 2+, AWE SwitchPath, AWE cat-deletes, AWE FMIC, H&R RSB, MSS Sport on order, HRE P40 (19x9, et50, Tinted Clear)
    Other Mods: Winter/Track Wheels: Borbet LV5 (18x8, et35, Anthracite), AWE Boost Gauge, Tinted Tails, Tinted HL Reflectors, Daytona Gray Rear Valence, OSIR Coolant Tank CF Shield
  24. Member
    Mar 4th, 2004
    Canada EH !
    05-02-2012 11:20 AM #24
    Quote Originally Posted by Black BeauTTy View Post
    Hmmm ...
    ... perhaps mentioning the 12 lb per corner weight savings should be mentionned in my situation ...
  25. Member
    Aug 20th, 2011
    05-02-2012 08:51 PM #25
    Hmmm ...
    Roger all of that. I already know that my Audi rims weigh a whopping 26 lbs, and that there's definitely room for improvement. One step at a time.
    On that same note, I always check the weight of the tire I'm researching. Have you noticed how much relatively heavier Bridgestones are for the same size tire?
    Michelin Pilot Super Sports are really appealing to me, on top of the Continental DW /DWS.
  26. Member
    Mar 4th, 2004
    Canada EH !
    05-02-2012 08:54 PM #26
    Yup bridgstones are fat ass tires (known for great turn in likely due to thick sidewalks). The Mich Super Sports are defiitely on my short list due to their ratings and weight.
