Results 1 to 5 of 5
Thread: Alternatives to the factory door moulding?
    Jul 4th, 2005
    Provo, UT
    2009 Rabbit, 89 Cabriolet
    04-30-2012 11:18 AM #1
    My door moulding doesn't like to stay clipped in despite trying to straighten it and its driving me nuts. My buddy found some good stick on stuff at Pep boys but they don't have any left and I can't find the same stuff online anywhere.
    Does anyone have a good source for some good alternatives to the factory door trim/moulding?
    Nov 30th, 2010
    Apple Valley, MN
    86 Cabriolet, 73 Super Beetle
    04-30-2012 11:31 AM #2
    Are you using original clips? Have you tried new ones?
    I've heard of someone (briano1234 probably) drilling more holes in the door and using additional clips. I did not run into this issue myself but sounds like a good solution.
    I doubt this is the issue that you were running into but i was having trouble with this
    http://forums.vwvortex.com/showthrea...ight=glue+trim
    dink and flicka
  3. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    90, 92, 93 Cabriolet
    04-30-2012 02:24 PM #3
    Yes I added 2 more factory clips to my door moulding, by drilling 2 additional holes. The issue is really that the door flex's too much, and you need to re-glue the Stiffener on to the door, or glue a stiffener to the inside of the door skin as close to the moulding line as you can. Liquid nails on a piece of wood or steel works well.
    On my Green Cabby, they took off the factory moulding, and replaced it with 3m peel and stick, which looks ok.
    Grounds, Grounds, Grounds Replace them things.
    Divorces, Great Coffee, and Electrics, all start with GOOD Grounds.
    Where are my grounds ?
  4. Member
    Jul 4th, 2005
    Provo, UT
    04-30-2012 03:42 PM #4
    Yeah I replaced the clips with the ones from moogie on ebay.
    Briano1234 what is the stiffener you're referring to?
  5. Member briano1234's Avatar
    Feb 20th, 2004
    Atlanta Ga
    04-30-2012 03:53 PM #5
    A piece of steel, plastic or wood, that you glue to the inside of the door near the Trim line.
