Not mine, but here's what you're looking for
#1
I'm sure it's been thought of, but why couldn't we take the existing air filter out of the engine cover (so it's empty) and add a high flow cone filter to the circular entry of the engine cover to sit in the same space the aftermarket ones do?
#3
most people try to eliminate the engine cover bc its a pain in the ass.
Not to mention tht style above sucks the air right off the DUMB hot tranny cooler
Best intake for an auto be is the forge HANDS DOWN
Unitronic Stage III w/ PT5558BB Turbo (What a difference UNI is from APR!!)Unitronic.ca,HPFP Upgrade Stage 1 pump, 3in.TBE, BSH throttle pipe/27mm RSB/Endlinks , Forge 007 DV , RalcoRC SS, 42Draft Design CNC Shifter bushings, N2MB WOT box, BFI stage 2 motor/tranny mounts, 034 Dogbone, Koni FSD shocks, Neuspeed springs/25mm FSB, Whiteline Anti-lift kit/Front control arm bushings, 18x8.5 VMR VB3s, JBL stereo, CTS Turbo 2.0t FSI Big turbo kit!
#4
If you want a cheaper solution just buy a neuspeed pipe and then do something like this...keeps the filter further away from the tranny cooler (This is my car by the way and this setup works a lot better than the standard neuspeed unit and is MUCH cheaper than Forge)
#5
#6
Its Pretty much the same idea as the forge unit it just doesnt have the pretty carbon fiber surrounding the filter. It still sits directly in front of the inlet that the stock airbox hooks up to and sucks all that fresh air in. My neuspeed filter would be very hot to the touch after driving, and now with the relocated filter its always cool to the touch
#7
it may be sligtly more beneficial then the neuspeed. nut the forge is a sealed system essentially and only pulls the air from outside.
I don't like the price of forge either. if you had a manual tranny id say go with the CTS turbo intake hangs down
#8
Yeah I'm definitely not saying its as good as forge's unit cause its not. Just thought I'd share what I had done maybe I can improve on it somehow. Works pretty well as is though![]()
#9
For me, the best intakes for Tiptronics are dbilas and VW Racing!![]()
Passat 2.0TFSI Tiptronic - APR K04 setup
FIAT Stilo 3.0 V6 24V (trackday car)
Golf Mk6 Twincharger DSG - APR stage 1
APR Thessaloniki dealer.
#10
2008 Passat wagon, 2.0T 6MT with mods
Other Rides:
- 2013 Cannondale CAADX-6
- 2010 Specialized Secteur Elite
- 2009 Specialized Rockhopper Comp 29-er
#11
#12
I have the stock air box and simply got a higher flow "performace" filter from ECS and I run UNI 1+ without any issues. Not sure if it is the optimum, but I have plenty of punch for my needs.
#13
