Results 1 to 9 of 9
Thread: Vacuum line replace?
  1. Junior Member
    Oct 21st, 2011
    Cleveland, OH
    '85 MkII Rocco 16v
    04-30-2012 11:26 AM #1
    Im doing the vacuum lines on my Rocco today, but Ive been having trouble finding a thorough how-to guide on it. Anyone have a link to a 16v vac line replace thread? Thanks!
  2. Member Blaines_Rocco's Avatar
    Nov 8th, 2011
    Texas
    1986 Scirocco 16v
    04-30-2012 11:47 AM #2
  3. Junior Member
    Oct 21st, 2011
    Cleveland, OH
    '85 MkII Rocco 16v
    04-30-2012 11:55 AM #3
    It does, thanks man. Do you know if the vacuum hoses 4mm, right off hand?
  4. Member BluDemon's Avatar
    Jun 19th, 2005
    Dickson, TN
    2012 Golf R (3/12), 2008 Audi RS4, 2004 Aprilia Scarabeo 500, 1988 VW Scirocco
    04-30-2012 12:00 PM #4
    Quote Originally Posted by SvedeBringer View Post
    I think it's 3mm...
  5. Junior Member
    Oct 21st, 2011
    Cleveland, OH
    '85 MkII Rocco 16v
    04-30-2012 12:20 PM #5
    Looks like Ill be finding out here in about 20 min, Im glad to be taking out those old cloth covered lines
  6. Member BluDemon's Avatar
    Jun 19th, 2005
    Dickson, TN
    04-30-2012 02:24 PM #6
    I bought a roll of new cloth covered vac hose last year and just went through replacing a bunch Looks good. Just replace a piece at a time to lessen confusion on placement.
  7. Junior Member
    Oct 21st, 2011
    Cleveland, OH
    '85 MkII Rocco 16v
    04-30-2012 04:09 PM #7
    Well....after using started fluid to test each line, it turns out none of my vac lines are bad, no rpm difference at all. Im having a fuel/air ratio problem right now, about 25% of the time, if Im stopped, and then start to move, my rpms will drop pretty low, the engine will sputter, and I cant move. If I apply slightly more gas with the throttle, and don't try to put it in gear, and then wait a sec, it will correct itself and return to normal rev level. I had a bad ISV, but thanks to a local forum (fatDUBS) I found a new one for free, which alleviated a great deal of idling troubles, but it still does it occasionally, like I said. Im thinking of doing a CIS-E rebuild and cleaning next, unfortunately bad gas was ran through it right before I bought it. Thoughts?
  8. Member thescirocco.com's Avatar
    May 15th, 2002
    Bear, Delaware 19701
    1981 Scirocco S 1984 Rabbit GTI 1999 Jeep Wrangler 1989 Cherokee 2006 ZX10
    04-30-2012 04:51 PM #8
    How old is your transfer fuel pump?
    If it's a VDO pump, replace it with Pierburg.
    Discount Dealer of Techtonics and Peloquin, too low to advertise...
    H4 Headlight Connectors, with rubber seal, $23 including US shipping
  9. Junior Member
    Oct 21st, 2011
    Cleveland, OH
    '85 MkII Rocco 16v
    05-01-2012 01:29 AM #9
    Quote Originally Posted by thescirocco.com View Post
    I'm not entirely certain, Id have to do a check. Its driving me crazy, though
