Results 1 to 14 of 14
Thread: Very slow boost spool
  1. Member giles712's Avatar
    Aug 4th, 2009
    Central Maine
    '02 Jetta 1.8t
    04-30-2012 01:25 PM #1
    Car description is in my signature. I'm running MBC @20psi in parallel with oem n75 valve. As far as deletes, pretty much everything that can be removed has been removed.
    It was running perfectly for a couple days then today I let it idle in my driveway for 20+ minutes. When I took off I mashed the throttle in 1st gear and boost spooled extremely slow from 0-15psi then snapped to 20 like normal. Normally the second you step on it the boost will snap right to 20 and do the normal k04 taper off to 15lbs bullsplit. I know that I have an exhaust leak from my head to manifold gasket because I used a crappy Felpro gasket when I rebuilt the head.
    When I got back I sat in the driveway listening to it, when I rev it up it sounds fine, but when it comes down from rev, i get a nasty high pitched rattle from the downpipe area.
    Idles at 18.5"hg
    forge 007 yellow spring 1 shim
    ball/spring boostvalve mbc
    rpturbo k04-001 pos w/ 6000 miles(already leaks oil...)
    unitronic 2+
    I have non-registered vag-com with codes:
    Camshaft position sensor(replaced before I cleared the codes)
    secondary o2 sensor(catless)
    Any ideas?
    '02 1.8t Jetta
    President - Pine State Euro Club
  2. Member giles712's Avatar
    Aug 4th, 2009
    Central Maine
    '02 Jetta 1.8t
    04-30-2012 02:33 PM #2
    help me pleaseeeeee
    '02 1.8t Jetta
  3. Member armymech666's Avatar
    Sep 29th, 2007
    Lebanon, PA
    2001 jetta 1.8t, 1990 jetta 16v, 1982 Caddy Diesel
    04-30-2012 02:40 PM #3
    mine is doing the same thing and I haven't really checked yet, but I am thinking it is an exhaust leak pre-turbo. I have no boost spike at all. just slow building boost.
  4. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 02:44 PM #4
    know that I have an exhaust leak from my head to manifold gasket because...
    That'll do it.
    Your turbo spools because of the high pressure differential between before the turbine and after the turbine. If you have a pre-turbo exhaust leak you're letting pressure out from behind the turbine THUS reducing the pressure differential.
    Less pressure before the turbo = less energy to spool the turbo.
    Less energy = slower spool
    Slower spool = sad panda.
    My Build
  5. Member giles712's Avatar
    Aug 4th, 2009
    Central Maine
    '02 Jetta 1.8t
    04-30-2012 02:47 PM #5
    Quote Originally Posted by groggory View Post
    That'll do it.
    This. I'll definitely replace my exhaust manifold gasket asap. any ideas about the noise i'm hearing?
    '02 1.8t Jetta
  6. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 02:51 PM #6
    Quote Originally Posted by giles712 View Post
    exhaust leaks in that area get loud real quick.
    I left an o2 bung open for a minute and started it up and the car sounded like a tractor. That's a ~ 1" hole in the downpipe.
    I think getting all the leaks out of your exhaust will fix a lot of the noises you're hearing.
    My Build
  7. Member giles712's Avatar
    Aug 4th, 2009
    Central Maine
    '02 Jetta 1.8t
    04-30-2012 02:54 PM #7
    okay. i'll get on it and report back. thank you so much!
    is there any way to replace the manifold gasket w/o removing the turbo?
    '02 1.8t Jetta
  8. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 03:08 PM #8
    Not to my knowledge. Sorry.
    My Build
  9. Member giles712's Avatar
    Aug 4th, 2009
    Central Maine
    '02 Jetta 1.8t
    04-30-2012 11:52 PM #9
    turns out my wastegate was sticking. soaked the rod with pb blaster then soaked with some graphite lube. runs mint now! other than my exhaust manifold leak. the rattle is because one of my heat shields fell down slightly and is tapping my exhaust.
    '02 1.8t Jetta
  10. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-01-2012 03:13 AM #10
    Cool.
    But just FYI...your car is going to run much better once you have no more pre-o2 exhaust leaks. Your spool will go faster, your car will run better, your car will idle better, and your fuel economy will go up.
    My Build
  11. Senior Member 87vr6's Avatar
    Jan 17th, 2002
    Okinawa, Japan
    IY 20th in America, Evolution IV in 沖縄, 日本
    05-01-2012 07:37 AM #11
    But just FYI...your car is going to run much better once you get rid of the rpturbo.
    Fixed.
    Sorry OP, you already knew that... If that wastegate, which comes with the turbo, only has 6k on it and it's already sticking, it's only a matter of time before it completely fails. Get a Borg Warner unit sooner rather than later.
    You noted in your sig you made 180~ BHP? That's what the factory motors are rated at...
    And for the record, 6k and it's failing? I've owned two 1.8t powered cars, one has 90k (current 20th) and the last one had 135k with a 185k turbo. Factory turbos, no problems with the wastegate on any of the three turbos (two on the older car)
  12. Member giles712's Avatar
    Aug 4th, 2009
    Central Maine
    '02 Jetta 1.8t
    05-01-2012 03:48 PM #12
    yeah the 180hp is sarcasm because everybody craps on k04-001 turbos, i have no idea what i'm actually putting down for power but my butt dyno says its pretty quick. I know very well that my rpturbo sucks bad. cash is tight right now(college sucks) or i'd have a borg warner k04-001 at least. Saving for waterfest right now i cant really afford the extra ~500-700 for a good used one.
    '02 1.8t Jetta
  13. Member babarber's Avatar
    Nov 2nd, 2008
    Richmond Kentucky
    2001 jetta wolfsburg, 1989 jetta gli
    05-01-2012 05:44 PM #13
    frankenturbos are a good reliable upgrade that will cost you about the same as the oem turbo so when your ready to replace ur pos rpturbo do yourself a favor and give doug a call
    Quote Originally Posted by G3T3I7 View Post
    because race springs
    Quote Originally Posted by Vegeta Gti View Post
    i love sacks
    Quote Originally Posted by bryangb View Post
    TCL isn't car enthusiasts. It's a forum for 40 year old guys to brag about their 2007 Hyundai Sonata. And to talk meaningless sh*t on anything VW
  14. Member forcefedjetta's Avatar
    Aug 14th, 2003
    metrowest
    02 jetta 1.8t
    05-01-2012 07:13 PM #14
    What dp are you using I had the same problem and found the flex joint in my ghl collapsed and was about the size of a quarter
    i wish my grass was emo so it would cut it's self
