Results 1 to 35 of 35
Thread: Has anyone replaced the oil pan and pickup tube?
  1. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    04-30-2012 01:32 PM #1
    I have a decent size dent in my oil pan and fear the pan may be touching the pickup tube. I found a lower pan and pickup tube for a good price but haven't found a DIY, can anyone give advice for this procedure or link to a DIY?
    Done.
    Shiny new pan is on and so far, leak free.
    Quick DIY
    1. Drain the oil from the pan.
    2. Remove the pan bolts using a T30 bit.
    3. Remove the pan by the little indents on the upper pan/block with a pry bar or screwdriver.
    4. Wipe the oil from the upper pan and lower pan mounting surface.
    5. Use a soft touch and a narrow steel scraper to remove the leftover silicone from the mounting surface. It's better to use a softer metal like copper when scraping product from a surface that must remain undamaged.
    6. Make sure the mounting surface is very clean of silicone and oil.
    7. Apply a 1.5-2MM wide bead of silicone on the lower pan mounting surface to the inside of the bolt holes.
    8. Mount the pan and put a bolt at each corner finger tight so it doesn't move.
    9. Put the rest of the bolts in hand tight.
    10. Tighten bolts in a diagonal pattern to 7FT-LBS or 84 INCH-LBS.
    11. Wait at least 30 minutes for the VW silicone to dry before putting oil back in.
    12. Top off the engine oil, start the car and look for leaks.
    13. If you have leaks, make sure all the bolts are tight. If they are, start at step 1.
    Pickup tube:
    1. Loosen the three T30 bits on the pickup tube.
    2. Gently pull the tube from the oil pump. Quite a bit of oil will come out with the tube, be ready.
    3. Put the new oil seal on the end of the pickup tube and stick the tube into the pump.
    4. Hand tighten the two bolts attached to the tube. Tighten the bolt that goes through the retaining ring at the base of the pump.
    5. Torque the three bolts to 7 FT-LBS or 84 INCH-LBS.
    The cause for replacement -
    If it sounds like sarcasm, it probably is.
  2. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    04-30-2012 02:11 PM #2
    Its a fairly easy process.the lower pan is simple. Just remember to correctly torque the bolts. As far as the pick up, its right there, but may require the upper pan be pulled as well I'll check my Bentley for you
    Sent from my DROID RAZR using Tapatalk 2
  3. Member pennsydubbin's Avatar
    Mar 3rd, 2010
    Pa
    2005.5/08 Jetta 2.5T
    04-30-2012 02:33 PM #3
    Quote Originally Posted by TylerO28 View Post
    Yea be careful torquing the pan. I tried torquing to spec on 2 separate occasions ( first for turbo install and fix oil pan leak 3 weeks ago) and I snapped bolts both times before even reaching factor spec Now when I get home I have to try and tap this snapped bolt out hopefully without having to take the pan off after I just put it back on with no leaks this time (except where bolt snapped)
    United Motorsports 2.5T
  4. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    04-30-2012 07:32 PM #4
    That would be great! Looking through the parts breakdown,
    it doesn't look like the upper pan needs to be removed, but since it's a VW who knows.
    Quote Originally Posted by pennsydubbin View Post
    You're freaking me out man. Did you find a gasket or use the gasket maker VW recommends?
  5. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    04-30-2012 07:59 PM #5
    It's gasket maker silicone. But Jimmy is correct.I snapped one as well while installing the turbo.those bolts are horribly soft material...
  6. Member pennsydubbin's Avatar
    Mar 3rd, 2010
    Pa
    04-30-2012 08:11 PM #6
    Quote Originally Posted by Dronks View Post
    I used some kind of make a gasket silicon I bought elsewhere when I put turbo pan on, but I had a few spots that leaked. This past time I just bought silicon from dealer thinking it should be better quality. So far it's held up fine...until later that day I noticed a leak and saw that a bolt snapped
  7. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    04-30-2012 11:59 PM #7
    How tight did you guys torque them?
  8. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-03-2012 05:01 PM #8
    Til tight, nor crazy...use a stubby ratchet so you don't go crazy on it
  9. Member pennsydubbin's Avatar
    Mar 3rd, 2010
    Pa
    05-03-2012 05:20 PM #9
    yes, use a short ratchet so you can't over torque them as easily.
  10. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-03-2012 08:47 PM #10
    Thought you had torque specs. My shiny new Bentley manual says 11 ft lbs.
  11. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-04-2012 12:03 AM #11
    I actually totally forgot to get those for you...but I do have torque specs lol... But I can assure you be careful...
  12. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    1k-m-cbta-02q-PTE5858
    05-04-2012 01:13 AM #12
    seems a bit much... maybe 11nm?
  13. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-04-2012 03:53 AM #13
    As per Bentley 7ft-lb or 10Nm...he must have been looking at the 2.0t section
  14. Member thygreyt's Avatar
    Jun 7th, 2009
    fort lauderdale, FL
    05-04-2012 08:10 AM #14
    i thought so. same as the valve cover...
  15. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-04-2012 12:52 PM #15
  16. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-04-2012 02:02 PM #16
    I've got another question! When you guys dropped the pan did you notice if the pickup tube went into the upper pan? I'm replacing mine and Bentley tells me to replace the oil seal at the top of the pickup tube.
  17. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-04-2012 02:37 PM #17
    Yeah it's right there...get the seal.but if it's all clean and not damaged I'd just leave it alone. you'll actually notice the seal on the pan in quite solid.I have an OEM pan if you'd like to buy it...save yourself some cash... If I were you, I'd replace those OEM bolts with stronger stainless hardware.I did because I didn't want to snap any others.pulling one out after the head is off sucks
  18. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-04-2012 06:21 PM #18
    Thanks for the recommendation on the bolts, I think I'll get some stainless ones!
    Do you think the upper pan would have to be removed to replace the oil seal at the top of the pickup tube or is it in clear view and easy to get to? That seal is the only part I'm nervous about. A local shop wants $250 to swap the pan and pickup tube.
  19. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-04-2012 11:38 PM #19
    I think when I had mine off, it was a simple bolt holding it in place from below... The upper pan essentially is the crank girdle for lack of a better term
  20. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-05-2012 02:39 AM #20
    Thank ya
  21. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-06-2012 03:37 PM #21
    where is the big Dent actually located? Because you may not be near the pick up anyway.before replacing it, check it out
  22. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-06-2012 10:46 PM #22
    Throughout the width of the pan.
  23. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-07-2012 04:14 PM #23
    pics?
  24. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-07-2012 04:22 PM #24
    I'll have pics and a write up tomorrow. The reason I'm doing this is because there's a noise that sounds like the timing chain is slapping around when cold but is nearly gone when the car warms up after a few miles. Using a mechanics stethoscope I snooped around the oil pan and bottom of the transmission and heard a faster vibration that sounds like the pickup tube is hitting the bottom of the pan.
    That's the theory anyway, I'll find out tomorrow.
  25. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-09-2012 11:18 PM #25
    Done.
    Last edited by Dronks; 05-18-2012 at 12:00 AM. Reason: Pics and instructions added to the first post.
  26. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-10-2012 02:01 AM #26
    nicely done! looks like a new oil pickup design...
    so any pics of the pan before? and the pickup?
  27. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-10-2012 02:59 AM #27
    Thank ya!
    It is an all new pickup design from what was in mine.
    I didn't take the time to get the pan and pickup cleaned today but I'll make some time tomorrow and get some pics up.
  28. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-17-2012 11:55 PM #28
    Sorry I took my sweet ass time posting these
    The dent is a little bigger than it looks in the pictures.
  29. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-18-2012 07:27 PM #29
    Meh, not bad looking, but probably a smart move regardless
    Sent from the bottomless pits of HELL!
  30. 05-24-2012 03:05 PM #30
    Looks like I will need to replace the lower oil pan and the oil pick up tube and the transmission pan for my 2008 VW Jetta SE 2.5L CBTA. Does anyone have advise on whether I should go for OEM or aftermarket on these parts? What about cost? Where can I find good deals? I'm in NC.
  31. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-24-2012 06:29 PM #31
    I'm pretty sure its only a dealer part.no aftermarket parts are really available...I have an OEM pan that's nearly perfect came off when I installed the turbo...you want it?
  32. 05-24-2012 07:53 PM #32
    I would have been interested in yours, yes, but I already ordered one, albeit not OEM. Besides, you're on the other side of the continent. Thanks, anyway. I am looking for the transmission pan and the oil pick up tube though. Any leads?
  33. Member TylerO28's Avatar
    Jul 7th, 2008
    Mill Creek, WA
    '08 2.5Turbo Rabbit
    05-24-2012 10:12 PM #33
    Let me look into that for you
  34. 05-25-2012 08:24 AM #34
    I appreciate that. Let me know if you come up with anything.
  35. Member Dronks's Avatar
    Jun 7th, 2011
    Green Bay, WI
    MKV Jetta 2.5l M5
    05-28-2012 05:55 PM #35
    I bought my stuff from VWpartsdept.com. Great prices on OEM parts and fast shipping.
