Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 35 of 145
Thread: Uni 830 - What should a block 031 look like on a WOT pull?
  1. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 02:32 PM #1
    Here is my what my AFR looks like on a WOT pull right now. (FYI, I'm limiting boost to 10 PSI.) Look at the goofy looking AFR-Request though. Why is the ECU requesting such a bizarre AFR? And if it's requesting such a bizarre AFR, why am I running such a normal looking AFR?
    Code:
    RPM	AFR-Request	AFR-Actual
    2520	14.7		14.5824
    2640	14.7		14.5824
    2800	29.2677		13.7886
    2960	29.2677		13.3182
    3140	29.2677		13.0977
    3340	29.2677		12.8625
    3540	29.2677		12.7449
    3720	29.2677		12.5244
    3900	29.2677		12.5244
    4100	29.2677		12.4068
    4300	29.2677		12.4068
    4520	29.2677		12.4068
    4720	29.2677		12.1716
    4900	29.2677		12.0687
    5040	29.2677		11.9511
    5140	14.7		11.9511
    My Build
    FS: New in box, primer'd 20AE body kit (front+rear valences and side skirts) -- PM me for details
    FS: Fiberglass 20AE replica spoiler. No scratches. Reflex Silver.
  2. Member Vegeta Gti's Avatar
    Feb 12th, 2003
    konoha village
    1984 GLi 20v, '06 M3, '10 Ninja, '10 690 Duke
    04-30-2012 03:25 PM #2
    uhh..weird...it isnt getting proper signal or something. that is...strange...
    :HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
    Quote Originally Posted by frechem View Post
    I like my women how I like my whiskey; aged 18 years and mixed up with coke.
  3. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 03:43 PM #3
    My rear o2 is clogged if that matters at all
    No misfires
    No timing pull
    My Build
  4. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 05:59 PM #4
    ^^bump
    ...for some insight.
    My Build
  5. Member Rac_337's Avatar
    Sep 23rd, 2004
    Toronto
    337 PTE5857 DBB, Volvo C70
    04-30-2012 06:12 PM #5
    Quote Originally Posted by groggory View Post
    ^^bump
    no codes either?
    i've never seen this before.
  6. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 06:15 PM #6
    Quote Originally Posted by Rac_337 View Post
    no codes either?
    My MAF is disconnected.
    My tune is a Uni 830 MAF'less file. So yes, I'm getting a code for my MAF being disconnected.
    My Build
  7. Member Rac_337's Avatar
    Sep 23rd, 2004
    Toronto
    04-30-2012 06:24 PM #7
    shouldnt matter then.
    did this just start happening out of the blue?
  8. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 06:30 PM #8
    I've been having problems for 4 or 5 months now. I've been down a couple dozen paths trying to figure things out.
    My old exhaust had a collapsed cat and was causing me to kill o2 sensors. So during that period I ignored the bad AFR data because I attributed that to the bad exhaust. I have since replaced the exhaust with a 3" 42dd turboback (gorgeous I may add) w/ high flow cat.
    So, I'm not sure of the start date of THIS issue. I've been tracking down gremlins for awhile now.
    I have it scheduled sometime this week to pull the valve cover and double check the cam to cam timing too. My car spits raw fuel out the tail pipe at idle and fouls plugs like it's nobody's business.
    I guess the question here is what would cause the Uni software to give me a requested lambda of maximum value? If I knew what would cause that crazy number to show up I'd have a guess at what's causing some of the other problmes.
    My Build
  9. Member Rac_337's Avatar
    Sep 23rd, 2004
    Toronto
    04-30-2012 06:57 PM #9
    What does 032 look like while this is going on?
    i'd double check the timing like you said. something is causing the fuel dump.
    just a theory, but is it possible because of this your ecu is trying to request a super lean condition just to correct for the excess fuel?
    maybe FPR is acting funny? thats another thought. do you have a fuel pressure gauge?
    how does it run otherwise? like a bag problably im guessing if you see raw fuel out of the tailpipe
  10. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 07:02 PM #10
    I'll reply back with my 032 on the drive home...
    That's possible, but seems like a weird way to correct for it. Seems like the computer would say, "Gimme 13:1 AFR" and then all the other logic would give fuel, take fuel, give more air, take more air, etc to reach that 13:1.
    It runs oddly. Sometimes it pulls hard. Sometimes I'll run the revs out and then it'll make a high speed stuttering sound, all my power is taken, and a cloud of black smoke covers the car tail gating me (). At that point I'll ease off the accelerator for a moment then slowly roll it back on and have power again.
    My Fuel economy sucks. v10 truck level suck.
    If I idle my car in the driveway I leave a black spot behind the tail pipe on the concrete and have to clean it with some APC (all purpose cleaner, unleaded gasoline) to get it off later.
    ...lol...
    My Build
  11. Member Rac_337's Avatar
    Sep 23rd, 2004
    Toronto
    04-30-2012 07:07 PM #11
    this is true...also i forgot the me7 can only correct up to 26% which would be 18/19:1 AFR or so....requesting 29:1 is extremely odd.
    any chance you can post the raw data log when you get home? im curious to see it.
    also when you take a look at your cam to cam timing, double check the vvt tensioner and make sure its in good shape.
    when i first had my car i had the vvt shoe crack on me causing a weird running condition too. thing ran like ish. when i pulled the valve cover there were bits and peices of shoe all over the place.
  12. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 07:13 PM #12
    http://db.tt/2rdeQBdf
    Block 032
    -3.9% / 25%
    My Build
  13. Member Rac_337's Avatar
    Sep 23rd, 2004
    Toronto
    04-30-2012 07:23 PM #13
    Block 032
    -3.9% / 25%
    first block is idle, 2nd block is partial/wot correction i believe. corrections are maxing out at 25%. gotta find that excess fuel problem.
    a) check cam timing to be sure.
    b) try and measure fuel pressure with a mechanical gauge while this is happening. tricky i know... i want to take a guess at bad FPR.
  14. Member babarber's Avatar
    Nov 2nd, 2008
    Richmond Kentucky
    2001 jetta wolfsburg, 1989 jetta gli
    04-30-2012 07:36 PM #14
    im pretty sure its backwards isnt it? negative means excess fuel and a positive # means its adding fuel please correct me if im wrong
    Quote Originally Posted by G3T3I7 View Post
    because race springs
    Quote Originally Posted by Vegeta Gti View Post
    i love sacks
    Quote Originally Posted by bryangb View Post
    TCL isn't car enthusiasts. It's a forum for 40 year old guys to brag about their 2007 Hyundai Sonata. And to talk meaningless sh*t on anything VW
  15. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 07:46 PM #15
    Cam timing will be checked later this week. Overall timing is spot on (timing belt)
    I have an in-car boost gauge and in-car fuel pressure gauge. At 10 PSI boost (according to boost gauge) I have 55 PSI fuel pressure. Which for a 3 bar fuel pressure regulator it's spot on.
    At idle, 20 in HG Fuel pressure = 34 PSI
    At idle with FPR disconnected from vac fuel pressure = 43 PSI
    My Build
  16. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 07:55 PM #16
    Quote Originally Posted by babarber View Post
    positive means the ECU is adding fuel
    My Build
  17. Member T-Boy's Avatar
    Jul 16th, 2003
    ATL
    04-30-2012 08:20 PM #17
    You sure you have an ECU with Uni 830 flashed on it? 100%
  18. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 08:21 PM #18
    Quote Originally Posted by T-Boy View Post
    100% sure. It shows Uni 830 in Vag Com
    My Build
  19. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    audi tt gt3076r 01 aston martin db7 04 land rover disco 99rolls royce seraph
    04-30-2012 08:44 PM #19
    I don't get it you have a Maf less file but you get a code when your maf is unplugged???
    http://forums.vwvortex.com/showthrea...t-done-I-guess
    ^^^Big Turbo build lots of pics^^^
    Best shop for repair and custom workin ma
    http://www.wentworthmotorsports.com/
  20. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 08:53 PM #20
    Quote Originally Posted by 01ttgt28 View Post
    Yeah...I worked with Uni for awhile on that one. They had me plug it in, clear a code, unplug it, back and forth in this combination and that....in the end they said, "Don't worry, your file is MAF'less"
    The bummer is I lose my traction control because the ECU sees the MAF as missing.
    My Build
  21. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    04-30-2012 09:04 PM #21
    I have a uni 830 file no maf all deletes and i got no Maf codes??
    Are you wide band???
  22. Member burkechrs1's Avatar
    Nov 30th, 2008
    Minden, NV
    2001 VW GTI 1.8t Pag billet 3071r
    04-30-2012 09:07 PM #22
    It shouldn't throw a code if the MAF is tuned out.
    I would put money on your mafless tune not being 100% correct..
  23. Member Rac_337's Avatar
    Sep 23rd, 2004
    Toronto
    04-30-2012 09:19 PM #23
    even if the maf was unplugged, threw a code, and it was a MAF tune for example; it would revert to other tables and be able to keep the trims in range if the map is correctly built no?
  24. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 09:19 PM #24
    Quote Originally Posted by burkechrs1 View Post
    They don't keep copies of each tune they build for people, so what are my options here? Send it to Canada and be out a car for 3-4 weeks? lol. Lavi checked on this with Mike Z. Maybe I'll give them a call again. They checked this out back in Dec of 2010
    Update: Reset fuel trims and did some more pulls.
    The crazy AFR request is still as crazy as ever.
    The actual AFR is a little higher, closer to 12.5.
    Sounds like I have two issues here..
    1) Potential problem with my cam to cam timing
    2) Software issue/ ECU issue
    http://dl.dropbox.com/u/9842192/Mygt...2-031-115.xlsx
    My Build
  25. Member Rac_337's Avatar
    Sep 23rd, 2004
    Toronto
    04-30-2012 09:36 PM #25
    just had a quick thought about this...wouldn't cam to cam timing being off give you a P17748 - Cam timing, incorrect correlation code?
    just throwing ideas out there to help narrow down.
  26. Member T-Boy's Avatar
    Jul 16th, 2003
    ATL
    04-30-2012 09:41 PM #26
    Thought: If you're running so rich that you're dripping raw fuel out of your exhaust, you should stop driving and logging. You could potentially wash your cylinders down and ruin your rings....amongst other things.
  27. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 09:55 PM #27
    That would suck
    My Build
  28. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    04-30-2012 10:13 PM #28
    The graph was with or without the Maf ??
    And on all your delets do you have any open?? did they all get resistored??
    Just asking??
  29. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    04-30-2012 10:15 PM #29
    No maf on this car
    I'll do a leak down test tomorrow
    My Build
  30. Member babarber's Avatar
    Nov 2nd, 2008
    Richmond Kentucky
    04-30-2012 11:01 PM #30
    just a thought... try plugging in a maf and do a log
    i love sacks
  31. Member 01ttgt28's Avatar
    Jun 23rd, 2009
    dartmouth ma
    04-30-2012 11:05 PM #31
    X2
  32. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    2002 1.8T JETTA & 2000 TTQ
    04-30-2012 11:19 PM #32
    what T-Boy said x2
    check your 02 wires to make sure they aren't frayed, trace them as close as you can to the ecu to
    make sure nothing is out of the ordinary...look into block 030 (sorry I haven't used vagcom in a while) and check out 02 voltage, it should tell you if the sensor is bad http://forums.vwvortex.com/showthrea...ips-and-Tricks
    what does the car do when you plug the MAF back in? does it run better?
  33. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-01-2012 01:27 AM #33
    Newest logs...
    I plugged the MAF in and cleared codes. This in turn reset the fuel trims.
    BTW...I didn't graph it, but the crazy AFR request is still there. Maxing out just like before.
    Here's a pull for ya...
    My Build
  34. Member 18T_BT's Avatar
    Sep 15th, 2005
    Silver Spring, MD
    05-01-2012 08:47 AM #34
    you are having a HW issue it seems
  35. Moderator groggory's Avatar
    Apr 21st, 2003
    Long Beach, CA
    2002 VW GTI 1.8 BT
    05-01-2012 11:01 AM #35
    Quote Originally Posted by 18T_BT View Post
    I agree
    My Build
