#1
Hi All. I'm just curious as to how many miles did your transmission got before it died? When it dies, what caused it? I believe it's only the solenoid that needs replacement and it will be just as good as new. reason i'm asking this is i have 110k miles on my car, still the original transmission. i replaced the fluid multiple times already. i just noticed that when it's cold, and i put it in D, it does not grab the gear right away. any ideas or experiences you have is very helpful. Thank you.
#2
#3
My daughters tranny was still going fairly strong at 156k. I rebuilt it then since the motor was out for rebuild. There was one clutch pack that was starting to go, but probably would have made it a few more k. And it had one bad solenoid causing wrong pressures.
The solenoids and the ribbon are common issues with these trans, besides valve wear in the valve body. A failing solenoid or bad connection on the ribbon strip can cause many problems and overall trans failure.
#4
My shift solenoids went at 153,000 plus clutch packs only had 1st and 2nd.
Sent from my iPhone using Tapatalk 1Sexy337/1FastGti
#5
I bought the car with 251.000 km, anything done on it and is going perfect still![]()
