Results 1 to 6 of 6
Thread: BBS CH028 18*8 will they fit a 09 jetta
  1. 04-30-2012 04:57 PM #1
    BBS CH028 came across a set for sale with 235/40R18 on them just want to make sure the wheels fit before i buy
  2. Member DboyDub1's Avatar
    Dec 30th, 2010
    LV PA
    Mk5 Jetta(current), Mk3 Golf, Mk2 Jetta, 1984 E30
    04-30-2012 05:17 PM #2
    Quote Originally Posted by jem286 View Post
    Offset would help. If they are et43 you are good. They may also come in et35 which may take a little work to fit.
    Post the offset for a answer.
  3. 04-30-2012 05:51 PM #3
    ya they are advertized as et43. they are coming off a s4 so it should be good then thanks for the info
  4. 04-30-2012 06:26 PM #4
    Avant Garde M310's 18x8.5 Et.38 5x112 with 225/40/18' fit as well
  5. Member DboyDub1's Avatar
    Dec 30th, 2010
    LV PA
    04-30-2012 07:54 PM #5
    What's your suspension set up? If you are below 24 FTG that could rub a dub. 215/40/18 would be a better choice or try to get somewhere near et 42-45.
  6. Member Kolwala's Avatar
    Aug 9th, 2011
    Where Kids Ride Horses to School
    TR Rabbit
    04-30-2012 09:47 PM #6
    Those are some beefy tires... neg. camber will help with that. Not sure about the fronts though...
    I root
