VWVortex.com - OEM wheels sound like rubbing...
    Results 1 to 10 of 10
    Thread: OEM wheels sound like rubbing...
    1. Member pumasarge's Avatar
      Mar 30th, 2009
      Milwaukee, WI
      2012 VW GTI Autobahn, 2012 Ducati Monster 1100 EVO
      04-30-2012 09:47 PM #1
      Hey all, I recently picked up some Samarkands for my 3.6 4motion Passat which originally had the 17s on it. Since swapping, I first had a little wobbling issue which was mostly resolved with a balancing of the wheels. Now the only thing remaining is this sound of rubbing going on up front. It's pretty prominent at lower parking lot speeds since my ears can catch the sounds of the rotation. Being that they're factory wheels, from another Passat originally, I assumed they would bolt right up with no issue. They're ET44 18x8.5. Am I missing something here? Do I need spacers or something. Any help or advice would be much appreciated before I go chasing a rabbit down a hole I can't fit in. If its anything involving an alignment, that would be awesome because I'm gonna need one after I lower the car when I get back from my trip. Thanks a bunch.
      A..B..C.. Always Be Closing!!
      Aug 6th, 2007
      Seacoast, NH
      '03 W8 Wagon(RIP), '79 euro BMW 635 csi, B6 3.6 4motion wagon, fleet of Scoot Coupes/mopeds
      04-30-2012 10:00 PM #2
      Did you change suspension? If so, you need to run the limiters.
      Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
      North.East.Region.Dubs
      Aug 5th, 2001
      Fargo, ND
      08 Passat, 08 GTI, 09 Routan, 03 Passat, 04 Passat, 99 Jetta TDI
      04-30-2012 11:01 PM #3
      I have a new to me 4mo wagon w/ 18's. Are you sure that u aren't just hearing tire rumble? Mine is pretty pronounced at low speed w/ new tires.
    4. Member pumasarge's Avatar
      Mar 30th, 2009
      Milwaukee, WI
      05-01-2012 12:28 AM #4
      I haven't changed the suspension yet. Going to be putting on H&R springs shortly. The sounds has too much of a rubbing sound for it to seem like tires noise. I will further investigate that hypothesis though. Thanks.
    5. Member low_passat's Avatar
      Sep 11th, 2010
      Goodyear, AZ
      '07 B6 Passat
      05-01-2012 12:52 AM #5
      There are actually 18x8 not 8.5. What size tire are you running?
      2007 Candy White/Black Passat 2.0T Wolfsburg Edition| APR Stage 2+ | APR HPFP | Forge WINtake | S3 Intercooler | B&B 3" Turbo-Back Exhaust | Dogbone Insert | FK Silverline+ Coilovers | Front Lip Spoiler/Hi-Def Sideskirts | Votex Trunk Lip Spoiler | R-Line Fog Grilles | Clear Corners | HID Kit - low beams & fogs | RCD-510 | Podi Boost gauge | R-Line Pedals | GTI Steering Wheel |
    6. Member pumasarge's Avatar
      Mar 30th, 2009
      Milwaukee, WI
      05-01-2012 02:10 AM #6
      They're Goodyear eagle F1 225/40
      Feb 17th, 2008
      brooklyn ny 11230
      07 passat 2.0t wagon,09 vw cc vr6 4motion
      05-01-2012 03:57 PM #7
      I think the 40 psi plus less rubber. = tire rumble especially if ur on summers. If ur rubbing tire something is broken. Just my opinion
      strictly a lower case poster Mods waaaaaaay too many to list
      Oct 14th, 2008
      '07 Passat 3.6 4mo wagon; '05 GLS 4mo wagon
      05-01-2012 08:52 PM #8
      Did you check inside the wheel well to see if the plastic liner thing might be loose and rubbing?
    9. Junior Member 2VW's Avatar
      Mar 2nd, 2007
      Sudbury, MA
      2007 VW Passat 3.6 4Motion
      09-19-2013 01:43 PM #9
      just in case you didn't think of that.
    10. Member
      May 11th, 2008
      Miami - Fl
      90 GLI 16V
      09-19-2013 11:23 PM #10
      I'm on the same size wheel and tire running and H&R Cup Kit and you won't run. Also no need for limiters with the H&R's you won't hit and will want the extra travel on the dampness.
      If you aren't swapping struts at the same time frankly don't waste your time, money and effort. Look into a good set of upper strut mounts as well so you do it right once.
