VWVortex.com - Question for the KO4 Guys...
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 42
    Thread: Question for the KO4 Guys...
    1. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      2014 Chevy Silverado V8
      04-30-2012 10:20 PM #1
      So I am considering making the jump... Not set in stone, but its been on my mind a lot :roll eyes:
      Right now I am APR Stage 2+, and hooking up Water/Meth soon to run a 100 octane file
      That being said, I want more. What should I be looking at as far:
      Clutch goes? (what are you guys running??)
      Internals? (anything I should be looking to do??)
      Any other suggestions? I don't want to go big turbo. I want something daily enough and reasonably priced, so thats why I want to go KO4. Note: I also want to run a 100 octane file on the KO4 so bear that in mind
    2. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      05-01-2012 10:53 AM #2
      Bump
    3. Member eatonrabbit.'s Avatar
      Apr 16th, 2009
      DFW
      2008 GTI APR Stage 2+ / 2001 Land Rover Discovery II
      05-01-2012 11:15 AM #3
      You just need the KO4 set up then. IIRC, upgrade your injectors, intercooler, ko4 w/ manifold, reflash for the ko4 set up and still run your w/m.
      You only need to change internals if you go BT.
      2008 GTI DSG - APR Stage 2+ . Devils Own Water-Methanol Injection Stage 2 . GIAC DSG . MMS Catless Downpipe . MMS Test Pipe . Evolution Stage 2 CAI . Autotech HPFP . Custom VTA Catch Can . Eurojet TB Pipe . Noise Pipe Deletion . S4 Coil Packs . BFI Torque Arm Insert . FK Streetlines .
    4. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      05-01-2012 11:22 AM #4
      How about clutch work? Car has 78k on it now, so Im not sure how it will hold up
      Oct 5th, 2011
      2007 vw gti dsg
      05-01-2012 11:57 AM #5
      Quote Originally Posted by emmauslax31 View Post
      change that shet bro
      clutch every 80 k
      Quote Originally Posted by alexj87 View Post
      heffery starts the best threads, so good at instigating.
    6. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      05-01-2012 12:02 PM #6
      Really?? I've honestly never heard that soon? Considering my mk4 vr6 went to 136k and is still going strong
      Oct 5th, 2011
      2007 vw gti dsg
      05-01-2012 12:06 PM #7
      well i guess it just really depends on your driving habbits, my old subaru the clutch would go around 70k because i drove it like the wind, but i also used to work at repair shops and its recomended every 80k.
      it sounds like you have alot of miles on your clutch and i would definitly replace it if your going ko4
    8. Member firstorbit84's Avatar
      Feb 25th, 2006
      CO
      '14 Jetta 1.8T, '16 Tiguan, '99 911
      05-01-2012 12:11 PM #8
      How much faster is the k04 than stg 2, really?
      Is it worth it?
      If your car feels like it's on rails, then you're going too slow.
    9. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      05-01-2012 12:27 PM #9
      Gain roughly 40-60hp and about 30ft/lbs.
    10. Member bryangb's Avatar
      Jun 16th, 2010
      Hanover, PA
      '08 GTI, '15 Golf TDI, '14 Ram Cummins
      05-01-2012 12:39 PM #10
      APR lists stage 2 at 270hp (with only the required supporting modifications) and list stage 2+ at 280hp. They list their k04 upgrade at around 325-330hp if I'm remembering correctly.
      So roughly a 40-50hp gain
      Instagram: @bryangb
      bags and wheels = build thread
    11. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      05-01-2012 12:46 PM #11
      Quote Originally Posted by bryangb View Post
      Exactly. I was just rounding off bc I'll be running a 100 oct file so it's a bit more power, worth it in my opinion. Every upgrade I've done I've noticed the increase between stages.
    12. Member SCIROCCO SPEED's Avatar
      Dec 6th, 2002
      Colorado
      73 Superbeetle, 86 Golf (RIP), 88 Scirocco 16v, 93 Corrado SLC, 07 GTI, 04 Jeep GC 4.0L, Cannondale
      05-01-2012 01:05 PM #12
      Quote Originally Posted by heffery117 View Post
      WTF? how about you just replace it when it starts going out?
      Engineers do it better.
    13. Member firstorbit84's Avatar
      Feb 25th, 2006
      CO
      05-01-2012 02:21 PM #13
      I guess I meant, were you happy with just the stg 2? or how long did it take to want to go for the k04? Once you got the k04, did it reallty feel like that big of a jump? Like stg2 vs stock or more like stg2 vs stg1? Did you feel that it was really worth it in the end to go for it?
      Also, how is anyone putting that kind of power down? I feel like the car needs more rubber and a lsd even with stock power. I would definitely get a lsd before even thinking of k04
    14. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      05-01-2012 02:37 PM #14
      Quote Originally Posted by firstorbit84 View Post
      Hence why I asked (clutch, internals, limited slip... So on. Trying to do my research before I go any direction) as far as stage 1 vs stage 2+ I was extremely impressed. But as impressed as I was, it only made me want more.. So hence why I want to go ko4. Stage 3 is simply too much money, and a ko4 I feel like is perfect
    15. Member eatonrabbit.'s Avatar
      Apr 16th, 2009
      DFW
      05-01-2012 02:47 PM #15
      an LSD is not needed for a KO4 mainly for BT's. It's definitely helpful though.
    16. Member
      Sep 10th, 2010
      2008 GTI
      05-01-2012 02:59 PM #16
      You'll find a lot more useful information and the answers you're looking for if you just google "fsi k04" or something similar. I just did this for hours during the dumb hours of the night thanks to a Rockstar.
      Quote Originally Posted by cracKness View Post
      You can buy a header?
      Is that like buying a pant at the Gap? You must be the person to go to when I'm looking for a scissor.
    17. 05-01-2012 11:53 PM #17
      Is this something that's commonly done?
      I wouldn't recommend using a tune for a higher octane than you're going to be running. Water/meth injection and 93 octane is not equivalent to 100 octane fuel.
      The tune is set to advance timing, thinking you will be running the correct octane, and will only slightly adjust it by pulling timing in order to prevent knock. Not safe.
      You should really only be using water/meth in our cars to keep boosted air temps closer to ambient temps, since we cannot tune specifically for the addition of the water/meth.
    18. Member SCIROCCO SPEED's Avatar
      Dec 6th, 2002
      Colorado
      05-02-2012 01:47 AM #18
      Quote Originally Posted by HereticByDefault View Post
      W/M with 93 oct fuel will effectively yield 112-116 octane in the combustion chamber on a proper setup.
    19. 05-02-2012 03:31 AM #19
      Quote Originally Posted by SCIROCCO SPEED View Post
      I guess I underestimated the content
    20. 05-02-2012 10:30 AM #20
      clutch every 80 k
      dumbest advice I've heard all week. Here I am @ 105k miles stage 2 and tuned for over 80k miles of those 105k with a perfectly fine non slipping original clutch and I should change it routinely at 80k miles because if it fails or starts slipping later I'll have to do a catastrophic clutch replacement If you have no reason to pull the tranny and the clutch is not slipping leave it alone! you might go another 50k miles with a k04. Might only go another 10k but you have zero to lose by waiting and a whole lot of potential usages out your current clutch assuming its trouble free now.
    21. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      05-04-2012 01:26 PM #21
      another go around for some more input... Any body have any clutch recommendations? I've looked at several companies just like getting real world feedback before I make a comittment
    22. Member guesswho's Avatar
      May 9th, 2009
      Washington, Home of the meth
      mkiv jetta RIP, mkv gti... loooong gone... 69 Triumph (it's euro)... 29 roadster (better than a vw)
      05-04-2012 01:56 PM #22
      dude, i've had my k04 on for about 15/20k or so (can't remember unless i check the car) and there is NO NEED for an upgraded clutch in it. the car feels great for daily commuting and great when you get on it. just get the k04, s3 injectors, a dv reroute kit/s3 dv kit/or an intake with a bung for the dv reroute, an aftermarket intercooler (oem s3 will suffice just fine), and call it a day. youll be zippin around on your w/m no problem.
      if you want more/better info, go to the fsi engine forum on here. lots of k04 intel for you to peep at. I spend more time in there than i do in here, haha.
      http://forums.vwvortex.com/forumdisp...I-Engine-Forum
      a.k.a. vdub-ranger, a.k.a. ChrisTheBlackGuy, a.k.a. Banned....again
      MOD LIST: blood, sweat, tears... mixed with a tad bit of semen on the rear seat. what a night... My BOUGHT Thread
      My man-piece is longer than Mike Kippen's Build Thread... and just as pretty
    23. Member Zaedrous's Avatar
      Sep 17th, 2009
      Pittsburgh, PA
      12 GTI Autobahn - TUNED SOON | 07 GTI APR STG 2 - RIP
      05-04-2012 03:49 PM #23
      Yeah absolutely no need for a clutch replacement, I'm stage 2 with 145k+ on my stock clutch and it is an strong as brand new. Earlier MKVs have a stronger clutch anyway.
      "What we do in life, echoes in eternity."
    24. Member
      Jul 26th, 2010
      La Joya, TX
      2008 GTI FSI
      05-07-2012 04:40 PM #24
      ko4 for about 10k already i love it once u get all of the hikups out....clutch i have not changed out and working very well
      ko4'ed APR tuned track times coming soon
    25. Member emmauslax31's Avatar
      Apr 11th, 2007
      Emmaus
      05-07-2012 09:05 PM #25
      explain what hiccups? just out of curiosity, i know there will be things to smooth out but just like the leg up to know what to expect
