Results 1 to 6 of 6
Thread: New Speakers and Headunit MKIV
    Jul 10th, 2010
    MKIV Jetta TDI, MKIV Jetta 1.8T
    04-30-2012 09:32 PM #1
    I am in the process of collecting parts to replace my radio. I intend on replacing both the speakers and the headunit at the same time. However, I wanted to know what is the best way to do this. Should I use the existing wires and wiring harness?
    I was thinking I could remove the current speakers and connect them to the wires that are already there but something tells me maybe I should upgrade the wires as well. When I do this do I go all the way back to the harness that connects to the radio? I am concerned about doing this because of the K Line involved.
  2. Member blazerpounds's Avatar
    Mar 19th, 2008
    Greeley, CO
    02 GTI 1.8t
    05-01-2012 07:32 PM #2
    The wires are fine. Font worry about the k line.
    Jul 10th, 2010
    05-01-2012 09:38 PM #3
    So it is not necessary to run new lines?
  4. Member blazerpounds's Avatar
    Mar 19th, 2008
    Greeley, CO
    02 GTI 1.8t
    05-04-2012 12:57 AM #4
    unless they are damaged, no.
    Jul 10th, 2010
    05-04-2012 08:06 PM #5
    And I assume the wiring harness behind the radio could then stay the same.
  6. 05-07-2012 09:27 AM #6
    there's actually wiring adapters you can buy. twist the HU wiring on to the adapter then the adapter has a plastic plug that will accept the volkswagen plugs. no cutting of wires necessary.
