VWVortex.com - Help: Air Lift Xl's Slam Series
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 41
    Thread: Help: Air Lift Xl's Slam Series
    1. Member 16v dubbin's Avatar
      Jun 9th, 2008
      SoCal
      1995 Vw Cabrio Wolfsburg
      05-01-2012 01:23 AM #1
      I just purchased an entire Mkv Gti digital airlift kit and have been researching quite a bit about the rubbing issues.
      It is a personal nightmare to have a rear bag blow out on me so I want to do the install right the first time and have no worries.
      I have been referred to Drew Dorbritz and looked at his D cups, also the performance height brackets from bag riders.
      I need your experience and wisdom on the subject of Mkv Gti rear bag set up's and how to PREVENT rubbing.
      Thanks,
      Austin
      Oct 16th, 2009
      SF Bay Area
      2008 MkV GTI
      05-01-2012 03:57 AM #2
      Quote Originally Posted by 16v dubbin View Post
      Thanks,
      Austin
      If you have purchased a complete kit, it should come with brackets. no need for D-cups unless you go with other rear bags.
      I have the airlift performance rears and no problems, i daily my car too. Going great for 2months now.
    3. Member bryangb's Avatar
      Jun 16th, 2010
      Hanover, PA
      '08 GTI, '15 Golf TDI, '14 Ram Cummins
      05-01-2012 10:31 AM #3
      Return the airlift rears and go with ss5's and dcups. **** airlift rears
      Instagram: @bryangb
      bags and wheels = build thread
    4. Member 16v dubbin's Avatar
      Jun 9th, 2008
      SoCal
      05-01-2012 04:03 PM #4
      Quote Originally Posted by bryangb View Post
      why are they so bad?
    5. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      05-01-2012 04:17 PM #5
      They're not terrible if they're installed correctly. The XL's just require trimming the upper spring nipple on the Mk5/6.
      SS-5/6 + D-Cups are great as well!
    6. Member 16v dubbin's Avatar
      Jun 9th, 2008
      SoCal
      05-01-2012 04:23 PM #6
      Quote Originally Posted by Andrew@ORT View Post
      After trimming the upper nipple there shouldn't be any issues with rubbing? I have the slam brackets.
    7. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      05-01-2012 04:26 PM #7
      Correct. Most people have rubbing issues with the lower control arms and the slam brackets. Mount the bags inward enough and trim properly, you'll have no problem!
    8. Member 16v dubbin's Avatar
      Jun 9th, 2008
      SoCal
      05-01-2012 04:29 PM #8
      Thank you very much!
    9. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      05-01-2012 04:55 PM #9
      No problem.
      Let me know if you need anything else!
    10. Member bvgoosedd's Avatar
      Mar 5th, 2009
      Raleigh NC
      mk1 Audi TT w/GT3076r Sold + mk4 2.8 VR6 Gli sold 07 EOS 2.0t HERS sold 20th jb daily b5 s4 in shop
      05-01-2012 05:03 PM #10
      is this a problem on mk4's?????
    11. 05-01-2012 06:01 PM #11
      are they still making these rear bags with plastic caps? quality was most def lacking a year ago, not sure if they addressed this...
      the main issue with rubbing comes from the bag sitting in the rear control arm. not saying you can't properly orientate the bag to clear the perimeter of the seat, but it most definetly requires you to jack up and lower the control arm a number of times to find the appropriate position for the top bracket. you'll be drilling and fastening the self-tapping screws a number of times into the body of the car to get it right.
      i highly suggest changing over to ss5's or re5's while using a bottom spacer to bring the bag partly out of the seat in the control arm and custom top brackets. for the time and effort it requires you to properly orientate the airlift bags, you could easily make d-cup-esque brackets yourself and use a higher quality bag.
      either that or return them for bagyard rear bags and call it a day sans cutting
      just a thought before you start cutting your car up to try and make the airlift bags work.
      Oct 16th, 2009
      SF Bay Area
      2008 MkV GTI
      05-01-2012 06:06 PM #12
      does ss/re bags go lower? and do they use about the same
      psi to raise the rears? I'm running about 55-65 psi in the rears with airlift
    13. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      05-02-2012 12:15 PM #13
      No, they will not go lower than the AirLift Slam XL's.
      The SS/RE's will give you a raked look.
    14. Member DoctorDoctor's Avatar
      Oct 18th, 2006
      Bay Area, California
      06 GTI, 04 Jetta (Gone)
      05-02-2012 01:48 PM #14
      I know that when I had my AirLift rear XL's installed, there was a quite a bit of rubbing on the LCA. The guys at Tomas Sport Tuning had to trim the LCA down to make it fit on top of getting rid of the top nipple.
      Tomas Sport Tuning + Bag Riders = BAGS & BBS RS
    15. 05-02-2012 02:03 PM #15
      is that a joke? if you install re5's with no mounting brackets i doubt you would even be able to raise the back of the car to a driveable height...
      i have a 2.25" spacer in the lower control arm to get the lift i need from these bags
      collapsed height on re5's is 2.9", collapsed height on slam xl rear bags is 5"
      this is completely dependent on how you mount these bags
    16. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      05-02-2012 02:38 PM #16
      No, it's not a joke, sorry.
      After rereading the conversation, we were referring to d-cups + ss/re bags and not a bracket-less setup. Sure, remove the brackets and you will go drastically lower, but that's not what we were talking about.
    17. Member 16v dubbin's Avatar
      Jun 9th, 2008
      SoCal
      05-02-2012 02:52 PM #17
      All I wanted to know was if there is precaution's you can take to not rub with airlift xl's with slam brackets
    18. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      05-02-2012 03:02 PM #18
      Sorry for derailing your topic, I was just responding to hypetrain's post regarding the Slam Specialties bags collapsed height.
    19. 05-02-2012 03:16 PM #19
      it honestly kills me that people think d-cups are their only option when choosing a universal bag
      no stab at dorbritz or anything, but come on... is everyone that impressed by this design or is it just a mindless solution?
      air suspension has become way too "off the shelf" imo, lets see some interesting set-ups with specific design intent
      /rant
      sorry andrew, didn't mean to come off like a jerk
    20. Former Advertiser
      Aug 22nd, 2006
      Malvern, PA
      M3 / W211 Estate
      05-02-2012 03:21 PM #20
      Feel free to contact me via PM, I don't want to jam up this poor chap's thread with a discussion about d-cups and bag setups
    21. Member DAS-AUTO's Avatar
      Apr 10th, 2009
      Massachusetts
      2007 gti, 2010 audi a3, 2000 audi a4 avant, 1960 bug.
      05-03-2012 11:36 PM #21
      i bought the air lift rears. i brought it to a shop and got it done professionally and theyre great,
    22. Member 16v dubbin's Avatar
      Jun 9th, 2008
      SoCal
      05-05-2012 12:45 AM #22
      Quote Originally Posted by DAS-AUTO View Post
      Awesome!
    23. Member steaguejr's Avatar
      Aug 2nd, 2006
      VA Beach
      04 MKIV JETTA / 08 MKV JETTA
      05-12-2012 10:24 PM #23
      Quote Originally Posted by itzkv View Post
      I'm still learning here but the performance rears are the non-slam serious correct? If so you and running that kit with the u-bracket? did you cut the perch or install a d-cup? If your car is the nonslam and no mods with the u-bracket, do you have a picture? would like to see how low they are. Im not all about laying from, just clean proper stance.
      For the non-slam serious and the u-bracket, have you heard of any rubbing issues or issues in general? and do you have to have d-cups installed in all rears to prevent rubbing?
    24. Member Seppdelaney's Avatar
      Apr 11th, 2011
      Houston, Tx
      2015 Golf GTI and a 2014 VW Tiguan 4 Motion SE
      05-13-2012 12:57 AM #24
      The airlift performance rears are the same bag as is with the Xl's, I think. The difference is the mounting brackets. The performance go a bit higher than the xl's, but low enough for me- I don't want to rest on my exhaust- but they get low enough that my fender liners still hold me up in the rear.
      ///”VDUBkill 2:0 – The path of 2.0T is beset on all sides by the injustice of the speed trap and the Plague of the Prius drivers. But blessed is he who in the name of disparity overwhelmeth the exotic in the valley of the s-bends. And I shall strike down upon thee with great revs and furious acceleration those who attempt to obstruct or delay my overtaking and you will know my engine is turbocharged when I lay my powerband upon thee.”
    25. Member
      Oct 16th, 2009
      SF Bay Area
      2008 MkV GTI
      05-13-2012 01:22 AM #25
      Quote Originally Posted by steaguejr View Post
      seppdelaney said it perfect. The only modification you will need to do to the rear is to use a 1/2" Drill bit to widen the existing hole on the upper nipple for the nusert. Any also on the LCA, there is also a identical "nipple" which holds the OEM Spring pad, that will be needed to be grinded down to about 1/4" so that the bottom of the airbag cup can fit flush on the LCA.
