VWVortex.com - Wrong clutch kit?
    Results 1 to 3 of 3
    Thread: Wrong clutch kit?
    1. Junior Member muctur's Avatar
      Mar 25th, 2008
      Spokane, WA
      79 Bug, '89 Golf, '15 GTI Autobahn
      05-01-2012 12:48 AM #1
      Hey guys,
      I ordered a clutch kit for a 94-99 Jetta 2.0L off of Clutchnet.
      We've now switched transmissions and are putting on a G60 02A.
      Will that clutch kit work on the G60 02A?
      Or do I have to buy a whole new one?
      Aug 14th, 2005
      Germany
      05-01-2012 05:02 AM #2
      Quote Originally Posted by muctur View Post
      Sorry, it will not work. The 02A uses a totally different way to operate the clutch. In fact if you ever worked on any older US models it works just like them, standard or conventional might be a way to descride it's function.
      You are going to need a new flywheel also and a starter. The shifter is cable operated, which I found much better than the rod/lever mess, so a new shifter assy is also required (have heard a mechanical conversion is possible). Clutch "operation" is also an issue. The 02A is most times operated using hydraulic fluid (brake fluid) but you can get a mechanical operation assy used in some models for cable operation.
      It requires some work and parts to install one but if done correctly you will enjoy it much more than the 020 with its rods and levers and bushings. I even used a short shifter from Hurst which made the throws so smooth and close it took some time to get used to driving with it.
    3. Junior Member muctur's Avatar
      Mar 25th, 2008
      Spokane, WA
      05-01-2012 11:13 AM #3
      Thanks a lot. I appreciate it!
    « Back
