Results 1 to 6 of 6
Thread: Accessory wire? Does anyone know where there is an accessory wire on the Passat?
  1. 05-01-2012 11:46 AM #1
    I am about to install a custom gauge and I need to find an accessory wire to power it. I know I can't use the clock or light wire from the center clock because that is powered all the time. I guess I could tap the cig lighter but I was wondering if anywhere else I could get a better source of power without tearing apart all my dash.
    Current: 2012 VW Passat TDI SEL Premium
    Previous: '07 VW GTI 2.0T, '07 BMW K1200LT, '00 VW Golf 1.8T (4DRGTI), '92 GTI 2.0 16V, '04(2) Nissan Altima, '83 Rabbit GTI, '85 Golf GTI, '86 cabrio, '91 GTI 2.0 16V, '93 Passat VR6 and a couple others that I won't mention.
    My 2012 Passat TDI SEL Premium Fuelly Record
  2. 05-02-2012 05:27 PM #2
    So today I was like oh I got it just look at the fuses in the fuses box....except I have no clue what fuse does what :-(
    They cheaped us out on a fuse diagram...
  3. 05-03-2012 07:52 AM #3
    Ok so real easy, go to advance auto and purchase a Pico 0956pt Mini Fused Circuit 16 Awg 10a
    ( http://amzn.com/B001QRSBW0 ) This would replace a fuse and provide 2 fuse slots. So the Cigarette lighter works off you key :-) The fuse for the cigarette lighter is a 30amp fuse located at the bottom of the fuse box inbetween the driver door and the dash. I will provide pictures in the next day or 2 :-)
  4. Member
    Jan 30th, 2006
    2012 Passat TDI
    05-03-2012 10:40 AM #4
    You can also do similar to this to add a curcuit
    http://www.myturbodiesel.com/1000q/m...dd-circuit.htm
  5. 05-03-2012 12:56 PM #5
    Quote Originally Posted by redneckracing View Post
    I actually saw this when i was looking for a solution, but that involves going to the deal and while don't get me wrong, it is nice, I am lazy.... my solution worked perfectly for what I needed.
  6. 05-04-2012 09:33 PM #6
