VWVortex.com - 2nd gear grinds quite often....
    Results 1 to 17 of 17
    Thread: 2nd gear grinds quite often....
    1. Junior Member
      Sep 26th, 2011
      newport ri/bostonma
      1998 mk3 GTI VR6 candy white sold. 99 Dodge Ram 1500 sold. 1995 Audi a6 SCRAPPED. now my 04 a4 DD!!!
      05-01-2012 12:55 PM #1
      this happens not all the time, but really only when i "throw" it in secnod.
      it grinds and then catches, a loud and honestly distrubing noise....
      any thoughts?
      much appreciated
    2. Member tylerlb's Avatar
      Jun 13th, 2004
      Ottawa, ON
      05-01-2012 01:07 PM #2
      toasted synchro
    3. Member Sky-Fi's Avatar
      Jan 19th, 2008
      Charleston, SC
      97 LG5R Jetta GLS
      05-01-2012 01:08 PM #3
      Syncro rings are worn out. You could just slow the shift down a little bit, too. The more you grind it, the more worn out it will get and the worse it will become.
      We need a series like this state-side. I'm in if there is one, or will be one. VW Cup 2017, anyone?
      DIY: Adding a "cruise engaged" indicator to the cluster
      Odometer: 163326mi | 266 full tanks | 83,638.9mi | 2,928.918gal | 28.55625mpg | US$0.10171/mi
    4. Member stealthcheetah's Avatar
      Jan 2nd, 2010
      IN
      '09 LB9A GTI
      05-01-2012 01:21 PM #4
      I feel your pain OP. My 1-2 has been really bad lately when driving enthusiastically, so I suppose its time for a tranny overhall.
    5. Member Sky-Fi's Avatar
      Jan 19th, 2008
      Charleston, SC
      97 LG5R Jetta GLS
      05-01-2012 02:11 PM #5
      My original trans was getting pretty bad for 1 and 2. Picked up a reconditioned one and 3rd grinds a lot, but at least 1-2 works great. Never really need to slam it into 3rd though, so it works out.
      Also, changing the gear oil may help a little..or a lot. If it is really old and yucky, it will make a bigger improvement. That's what I did about 10,000 miles before getting another trans and it made a huge difference.
    6. Junior Member
      Sep 26th, 2011
      newport ri/bostonma
      05-03-2012 12:40 AM #6
      thanks
      any recmmended tranny fluid?
    7. 05-03-2012 12:49 AM #7
      im not sure whats the best fluid, but i would use whatever vw recomends, go to germanautoparts.com and see what fluid they have listed for the car. site is very reliable (for me at least), never had any problems. i recently got a bunch of power steering fluid and brake fluid to do a flush, and it was a lot cheaper than going through the stealership.
    8. Member gtr3nos1's Avatar
      Sep 6th, 2008
      Danbury CT
      97 Golf VR6 (Show Car) 99.5 A4 1.8T (Daily) 95 Jetta City 97 Golf (Sold) 00 Gti VR6 (Sold)
      05-03-2012 12:54 AM #8
      Quote Originally Posted by 401wagonguy View Post
      thanks
      synchromesh
      Instagram --> @Filipe__Silva__
    9. Banned vento86's Avatar
      Oct 13th, 2008
      05-03-2012 01:26 AM #9
      Or get that redline trans fluid. **** works wonders
    10. Member Sky-Fi's Avatar
      Jan 19th, 2008
      Charleston, SC
      97 LG5R Jetta GLS
      05-03-2012 01:29 AM #10
      The unofficial list of good oils are:
      Redline MT-90
      Pennzoil Syncromesh
      GM synthetic fluid (I forget the name of it, but I've heard most chain stores have it)
      Royal Purple
      Basically, you just need one that is GL-4 certified/approved. Some bottles say it right on there, but others may need some skimming of the documentation.
    11. Member Ickey's Avatar
      Sep 6th, 2009
      Richmond IN
      97 Jetta VR
      05-03-2012 09:47 AM #11
      Redline is the best i have used so far ....used the syncromesh too and it was ok but felt lilke the redline performed better in the long run ...but for price and if ur just gonna replace the trans syncromesh aint too shabby either
    12. 08-18-2012 03:40 PM #12
      2000 vr6, my 2nd gear has been grinding every up shift and inconsistent downshifts. I recently changed gear oil (Lucas 80-90). 2nd still grinds but all the other gears are MUCH smoother. They were all getting a little rough. So it looks like I will just be continuing to avoid 2nd gear to save the syncro.
    13. Member Sky-Fi's Avatar
      Jan 19th, 2008
      Charleston, SC
      97 LG5R Jetta GLS
      08-18-2012 04:10 PM #13
      Well something else you can do to help the syncros out is to get a lot closer with rev-matching, like you would do when you float the gears. If you're hitting it as an upshift, you'll eventually figure out the timing of when you drop your foot off the gas and the revs fall down, you end up with a short window to get 2nd to be pretty close to rev-matched.
      Can also just slow down your shifting process, too. Regardless, it does sound like the syncro for 2nd is pretty worn-out.
    14. Banned the mad conductor's Avatar
      Nov 11th, 2009
      mesa az
      corrado
      08-18-2012 05:52 PM #14
      Also try re-aligning your shifter and check for bushing play.
    15. Junior Member
      Jul 27th, 2007
      lynchburg, va.
      95 vw golf gti vr6
      08-18-2012 05:59 PM #15
      I have a 95 vr6 and my synchro has been gone for a while...the gear oil works great ( I used redline) slow down the shifting or double clutch it....works for me
    16. Banned the mad conductor's Avatar
      Nov 11th, 2009
      mesa az
      corrado
      08-18-2012 06:12 PM #16
      Grinding could also be caused by a stretched shift cable.
    17. 08-18-2012 07:13 PM #17
      For real. Not allot of people check out the bushings on the cables where it enters the shift box. Not included in rebuild kit and allot overlook it. Same for the 3 on top of trans holding the front cable bracket.
      If the symptom lessens as the trans warms, it's likely a bushing/alignment issue. If it sucks from cold to warm, probably internals as mentioned.
      Did you know that it's not pronounced Em Kay ? ALL OF THE CAR LOUNGE WILL BE HAPPY TO LET YOU KNOW THAT. SERIOUSLY. IT STANDS FOR MARK. DID YOU KNOW THAT? BEFORE THAT A1,A2, A3, ETC WAS USED. LIVE UP TO TCL STANDARDS BEFORE YOU GET ON MY ASS. THAT'S DISGUSTING.
      Example of TCL's standards
