Results 1 to 3 of 3
Thread: Quick cam timing question...
  1. 05-01-2012 04:38 PM #1
    If the lower cover wasn't touched, its not possible to be off 1/2 tooth, correct? The timing mark on my flywheel and the cams aren't lining up 100% perfect, just a smidge off.
  2. Member GTIVRon's Avatar
    Jul 24th, 2009
    Keller, Texas
    92 Corrado SLC, '12 Golf R
    05-01-2012 05:17 PM #2
    From what I've seen, they very rarely line up perfectly. Consider the inherent slack/lash.
    Just make sure that all your chain slack is on the tensioner/slack-adjuster side.
    2002.5 Jetta 1.8T - TOTALED (dodging deer)
    2002.5 24v GTI - TOTALED (rear-ended by a Jeep)
    1992 Corrado SLC - The toy & DD
    2012 Golf R - The weekender
  3. Member Scotty_2.0's Avatar
    Jan 13th, 2005
    North York, Ont.
    Mk2 GTI VR6... .......................Mk5 Rabbit 2.5
    05-01-2012 09:59 PM #3
    Quote Originally Posted by GTIVRon View Post
    This. If the cam needs a touch just to get the plate in, you're good.
    /// VRSociety Member #298 /// Mk2 Milita-VR6 Battalion-2dr Regiment /// Instagram @scottyvr6 ///
    My 2.9L BVH build and the machine shop #%@- up that almost ruined it all.
