Page 1 of 2 1 2 LastLast
Results 1 to 35 of 68
Thread: FS: TR R32T Built Motor, DRP Trans, UM Tuned, 64k miles LI, NY
  1. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    12 VW Golf R, 01 Audi A4 1.8T Quattro, 04 VW R33T(SOLD)
    05-01-2012 06:26 PM #1
    The time has come to sell my R32T, I've finally made up my mind and want to move on to another project so this car has to go to free up money to fund that build. I am the 2nd owner of this car, it has a clean title, hasn't been in any accidents, and has 64,xxx miles. I've owned the car since july of 07 with 41k miles and its had a built motor and been turbo'd since March of 08. The car used to be on a Uni 830 tune and made 666fwhp 603fwtq @31psi with pump/q16 and 525fwhp @25psi same fuel on that run. On the current UM 550 tune the car made 572awhp 545awtq @21psi on pump gas. This car is extremely fast and surprises a lot of people. Best 1/4mile time was 11.49 @128pmh 1.69 60 ft spinning the tires in 1st and 2nd gear (that was on the uni tune at 28psi) fastest time on the UM tune was 11.60 @117 1.76 60ft again spinning the tires 1st and 2nd gear (that was at 22psi). This car hasn't been daily driven since its been turbo'd and hasn't seen snow since before it was turbo'd. The car is very reliable and could be daily driven if you so choose to, I never had to daily it because i always had another car to get around in. I have however driven it to the track made many passes and driven it home, driven it to NJ, PA, CT, and back 4-5 hour trips each way, driven it to work and back everyday (90miles round trip) for a few weeks in the summer, etc... with no issues at all, get in start her up and go. There are plenty of people on these forums that can vouch for me and this car and how well its built and taken care of, this car isn't just a few months to a year of building with a few thousand miles and up forsale, this car has gone through a lot and things have been changed and upgraded on the way to make this the strong, fast, and reliable car it is today.
    Engine:
    - Built by Gino @ Evolution Race Engines @ 54K miles
    - Bored to 3.3L
    - Wossner 8.0:1 Forged Pistons
    - Wossner Forged Rods
    - Polished & Balanced Crank
    - ARP Rod bolts & Main studs
    - Raceware Headstuds
    - CTS T4 Manifold (replaced a pagparts manifold @ 62K)
    - Precision 6765 Journal Bearing Turbo T4 .96 exh. housing (replaced a t4 .81 housing @ 62k)
    - Custom 3" downpipe (made by Ed @ FFE)
    - Custom 3" Exhaust vbanded at the downpipe, 1piece to a 3" single in/single out borla xr1 race muffler with a turndown tip coming down on pass side rear of the car.
    - Precision 46mm wastegate 15psi spring (replaced a tial 38mm wg @ 62k)
    - Custom wastegate dump tube
    - Precison 750hp Intercooler with Custom 3" piping (made by Ed @ FFE)
    - Tial Alpha Q DV
    - C2 SRI
    - Induktion Motorsports low temp thermostat and fan switch
    - ATP Catch Can
    - VF Motor & Trans Mount and BFI stg2 bushings in oem dogbone
    - UM 550cc tune:
    - Launch Control set to 5,800rpm
    - SAI, EVAP, Cat, Rear 02's, and 2nd bank front 02 deleted
    - 550cc injectors
    - stock fuel rail modified to accept -6an fuel line and moved fpr to pass side.
    - stock fuel filter modified to accept -6an fuel line
    - Oil changed every 3k with Mobil 1 Synthetic 5w40
    Drivetrain:
    - DRP Transmission w/58K installed @ 59k, replaced 3rd, 4th, 6th gears with drivers @ 60k by FFE
    - Peloquin Front diff @ 60k by FFE
    - Peloquin Rear diff @ 63K
    - Rear Diff/Haldex assembly replaced @ 63k w/40k unit
    - Clutch Masters FX600 Twin Disc Clutch W/Steel Flywheel @57K
    - USP Stainless Clutch line
    - Transfer case replaced @ 62k w/20k unit
    Suspension:
    - FK Highsport Coilovers installed with new strut mounts @ 61K
    - Gruven Parts adj. Rear Lower Control Arms @61k
    - ECS Poly Front Lower Control Arm Bushings @ 60k
    - Yarrow Sport Rear Strut Bar
    Brakes:
    - GTI 11.3" Front Calipers
    - ATE Slotted Front Rotors
    - Porterfield R4S Front Pads
    - Oem rear pads and rotors
    - Calipers Painted Black w/G2 Caliper Paint
    (Before people complain about the brakes and say they are inadequate, they are not, the car stops very well with the smaller brakes. IMO they stop the same if not better than the factory sized brakes and with less fade. The brakes were downsized to accommodate 15" wheels with slicks or drag radials and to drop some weight.)
    Wheels:
    - 17X8 et35 Enkei RPF1's
    - 235/40/17 Dunlop Direzza Star Specs
    - Wheels and tires put on at 62K
    Exterior:
    - Jetta Front end w/OEM GLI valance and euro rubstrip
    - Helix Smoked Ecodes
    - Smoked repeaters
    - Hella R/S/S/R Tail lights
    - GTI Rear bumper w/OEM 25AE TDI rear valance (20th style with no exhaust cutout)
    - No Clear coat issues
    Interior:
    - Recaro SRD Seats w/ Wedge Engineering Brackets & Sliders
    - Euro Kreations Rear Seat Delete
    - New South Full Pod w/V-Gauges Digital Vac/Boost Gauge (solenoid built into gauge, good to 50psi)
    - 42 DD A-pillar pod w/AEM Uego Wideband A/F Gauge
    - Alpine Single Din CD player with Ipod hookup in glovebox
    - Alpine Type-S Components w/crossovers
    Price: $27,000 OBO.
    [B]Price drop! $26,000 OBO[B]
    I am open to trades + cash/certified bank check on your end, lemme see what you got.
    Pics:
    some of the pics are a little older, helix oem hid reps are no longer on the car, the drivers side lower seat bolster has since been replaced with a new bolster, and the airbag light is no longer on.
    Nov 11th, 2007
    ny
    05-01-2012 07:13 PM #2
    Wow Dave, the car looks awesome!!
    I can personally vouch for how clean, well taken care of and absolutely awesome this car is. Whoever buys this will have a huge smile on their face.
    Goodluck dude!
  3. Member Rmeitz167's Avatar
    Dec 15th, 2007
    NEPA
    tred r33t
    05-01-2012 07:14 PM #3
    Admired this car for a while, finally saw it at our show upclose and personal and everyone there can attest to how good the car sounds. Whoever buyes this is no doubt getting a good car, with good parts, and a good tune!!!
    WunderWagens June 10,2012 in Gilbert, PA... 2nd year http://www.wunderwagens-show.com
    UnitedMotorsport r32 cam flash... get one
    My Turbo .:R Build Thread
    WunderWagens Vortex Forum
    WunderWagens Facebook
  4. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-01-2012 08:44 PM #4
    thanks guys
    May 9th, 2009
    Long Island
    current 2004 Audi S4, 04 RS R32, 01 S4, 04 BMP R32, 02 1.8t gti, 03 325i, 03 tr gli, 02 a4, etc etc
    05-01-2012 09:56 PM #5
    Bump for a badass R!!!!!!
    -Kenny
  6. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-02-2012 07:38 AM #6
    Thanks Ken!
  7. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-02-2012 03:54 PM #7
    bump
  8. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-03-2012 06:40 AM #8
    Bump
  9. Junior Member
    Mar 25th, 2008
    San Antonio
    04 TR R32
    05-03-2012 07:15 AM #9
    Why the change of the front calipers and rear bumper to a gti version?
  10. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-03-2012 09:48 AM #10
    The calipers were changed to be able to fit 15" wheels with slicks, the rear bumper was changed to give the car more of a sleeper look.
  11. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-03-2012 09:33 PM #11
    Bump
  12. Member Rmeitz167's Avatar
    Dec 15th, 2007
    NEPA
    tred r33t
    05-03-2012 11:20 PM #12
  13. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-04-2012 02:34 PM #13
    Let's see some reasonable offers!
  14. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-04-2012 09:54 PM #14
    Bump
  15. 05-05-2012 01:27 AM #15
    Good luck bro, buy a V8 with RWD next!!
    Tough to sell a car like this man, I had to part my baby out Might be your best bet in the end you will get a bunch of money if you do it!
  16. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-05-2012 07:37 AM #16
    Thanks! I've got nothing but time, and if after a while no worth while offers come out of it I'll either keep it or part it out for stock parts and sell the car stock. If I wanted to go that route I already have someone interested in the motor/turbo setup and another person interested in the trans, so it's possible it could end up that way. We'll see how it goes.
  17. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-05-2012 05:57 PM #17
    Bump
  18. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-06-2012 11:15 AM #18
    Bump
  19. Member iBoost25's Avatar
    Nov 24th, 2008
    Long Island
    2001 Golf 2.0L / 2006 Evo IX 2.0L
    05-06-2012 12:14 PM #19
    Bump For a Good Guy and a Nice Car.
  20. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-06-2012 04:00 PM #20
    Quote Originally Posted by iBoost25 View Post
    Thanks Kris!
  21. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-07-2012 08:35 AM #21
    Bump
  22. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-08-2012 10:39 AM #22
    Got some trade offers, let's see some more!
  23. Member iBoost25's Avatar
    Nov 24th, 2008
    Long Island
    05-08-2012 11:24 AM #23
    Trade for a Stock Evo + Cash on your End Bro..
    Kris K
    Instagram: iBoost25
  24. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-08-2012 03:16 PM #24
    Lol I can't take ur car u have to make it faster first
  25. Member iBoost25's Avatar
    Nov 24th, 2008
    Long Island
    05-08-2012 04:56 PM #25
    Runs 9's as is.
    Bump
  26. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-08-2012 06:33 PM #26
    Hahaha
  27. Member DasB5's Avatar
    Oct 16th, 2010
    Brunswick, ME
    2006 Jetta 2.5L 2006 GTI Stage 2.
    05-09-2012 08:58 PM #27
    I'm in love with your car. Bump
    To many...
  28. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-10-2012 09:53 AM #28
    Thanks!
  29. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-11-2012 07:10 AM #29
    Some more interested people but still nothing pending so let's see some more. I'm sure there are plenty of people out there that want a badass turbo R.
  30. Member flynscot63's Avatar
    Dec 29th, 2004
    Salisbury NC
    04 R32 Silver, 12 Mini Cooper S JCW Spec
    05-11-2012 09:52 AM #30
    Very Nice GLWS
  31. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-11-2012 10:43 AM #31
    Quote Originally Posted by flynscot63 View Post
    Very Nice GLWS
    Thank you!
  32. Member Snitches Get Stitches's Avatar
    Jul 21st, 2007
    Southern NJ
    2002 Hybrid VR6T Jetta, 1997 Lifted Subie Outback
    05-11-2012 10:49 AM #32
    How does she drive off boost with the 8:0:1 Wossners?
    Did the bump in displacement make it negligible?
  33. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-11-2012 11:42 AM #33
    It drives very well off boost, the bump in displacement deff made the drop in compression negligible. The car still pulls well if you stay at 0psi or less. I thought that it would be a little more sluggish because of the compression drop but it's actually very impressive.
  34. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-12-2012 02:37 PM #34
    Bump
  35. Member dave13s4's Avatar
    Dec 16th, 2004
    Long Island
    05-13-2012 12:10 PM #35
    Bump
