Results 1 to 5 of 5
Thread: corrado master, 02m slave anyone got this setup ?
    Apr 30th, 2007
    Quebec, Canada
    Jetta TDI 03, Corrado 24v 90.
    05-01-2012 07:58 PM #1
    I've got a corrado with an early model clutch master cylinder (metal one) and a o2m slave cylinder they are connected with usp braided clutch line made for this application. I am wondering if the mkIV master cylinder as a bigger cylinder being to move more fluid than the mkII master. My clutch bites at the the upper part of the stroke, almost at the top. The system seems to be bled properly I bled it again today with my motive power bleeder and there are no air bubbles coming out, only fluid.
    If there's anyone running a similar setup, I'd like to know if your clutch bites when the pedal is almost at the top.
    I also have a FST singlemass flywheel, stock clutch, and stock pressure plate.
  2. Member sdezego's Avatar
    Apr 23rd, 2004
    Hurricane Central FL
    '90 Corrado | '62 Harley Panhead
    05-01-2012 08:48 PM #2
    if your clutch is biting to far up top, you may want to incorporate the 02m UFO into your line. This is the Round disk dampener in line by the trans and it does as described.
    I can't tell you the before and afters because mine is still in my Mock bay. I was originally going to modify the 02m Master and still might, but since I had to replace the master in my Corrado recently, I may decide to use it. Regardless though, I have the dampener JIC.
    Build: Project sc2020
    My G60 now on MS3 | 4Cyl Torque Plate Rental | 02M Mounts
    Apr 30th, 2007
    Quebec, Canada
    05-01-2012 09:03 PM #3
    Ok, I see what you mean, it's true that I'm missing that piece.
    I'm not sure how this piece would affect the friction point but I'll try to find the UFO Dampener.
    I'm concerned that my actual clutch line with the connecting male end might not fit into the Dampener. Do you know if they use the same kind of connection than the one used on the plastic bleeder/restrictor ?
  4. Member sdezego's Avatar
    Apr 23rd, 2004
    05-01-2012 10:57 PM #4
    Quote Originally Posted by madonion View Post
    Yes, it slips right into the plastic bleeder T with an O Ring and uses that clip to secure. I bought the factory line, to use to make it easy, but your line should have the one slip joint end.
    Here is a pic from Nater's thread -> 1st page -> http://forums.vwvortex.com/showthread.php?2633108
    Apr 30th, 2007
    Quebec, Canada
    05-14-2012 09:11 PM #5
    I've read threads about clutch being installed backward was causing the clutch to no disengage. http://forums.vwvortex.com/showthread.php?4451944. I'm starting to think it could be a possibility, I don't remember which side I've installed it. Is it possible to install it backward ? could it create a really high engagement point ?
