Results 1 to 11 of 11
Thread: How To : check for valve leakage with head off
  1. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    05-01-2012 08:46 PM #1
    So people ask, how the heck do you check to see if the valves are sealing with a head off a car.
    With the head IN the car, you can just do a cyl leak down test. But what do you do to check if the head is off the car.
    Water test!
    If the water stays the same overnight in all the cylinders, its good to go. No bent valves yay!
    the car is on an inclined driveway and up on jack stands in the front only
    VW's don't leak oil, they just mark their territory!
    Master L1 ASE certified
  2. 05-07-2012 09:28 PM #2
    Gas is a better choice.
    Up and Atom!
  3. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    05-07-2012 09:54 PM #3
    yea, but it smells, and evaporates overnight.
  4. Member Jesse-B's Avatar
    Dec 4th, 2011
    Fort Myers, FL
    1984 Vw Rabbit, 2004 Passat W8 wagon.
    05-09-2012 03:34 PM #4
    Yea,but with gas you find out immediately!
  5. Moderator root beer's Avatar
    Jun 22nd, 2004
    Linthicum, MD
    96 Golf 83 Scirocco
    05-12-2012 08:14 AM #5
    Tried on a vr head, didn't work.
    Teehee
  6. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    05-12-2012 10:39 PM #6
    then either the valves have carbon buildup or something else is wrong.
  7. 08-29-2012 07:08 PM #7
    can you tell me where should i exactly pour the water, on the head ???
  8. 08-29-2012 07:11 PM #8
    i wanna make sure if my valves are not bent.before when i did compression test i was getting 3.0 3.5 psi on every almost cylinder.???
    and could you advice me
  9. Senior Member need_a_VR6's Avatar
    May 19th, 1999
    Oxford, PA
    03 325i
    08-29-2012 10:56 PM #9
    Its good to check if something is way off but it won't catch small issues. Bent valve, sure. Bad valve job, nope. A fresh race valve job wont pass this test either so... like many things its one of a few tests you can do to figure out the whole story.
    -Paul
    1995 GTI VR6 - 12.90@106 R32 power - 12.833@106 12v power
    KPTuned - Official MegaSquirt: Sales - Repair - Installation - Tuning
    Build Thread: The Build Thread "Good Clean Fun"
  10. Member lil8v's Avatar
    Jun 28th, 2002
    Jersey
    03 20th ann..retired 97 gti that was a lil bit of everything
    10-20-2012 09:26 PM #10
    water is retarted and a good way to start rust on a valve seat...to check with head off a car you need a very thin liquid such as lacquer thinner but yes as paul said sometimes with a race valve job regardless the valves will leak but seal once running....
    2003 mk4 20th anniversary 10.60 at 140...full weight
    for all your vw fabrication and custom parts hit up
    ED at FFE racing he is the best in the business
    me-551 208 8850
  11. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    10-20-2012 10:19 PM #11
    Worked on every head I tried.
