Results 1 to 4 of 4
Thread: WTT: My modded 1987 16V for your stock(ish) S1
  1. Member SciroccoPowered's Avatar
    Jul 28th, 2011
    1987 Scirocco 16V
    05-02-2012 12:08 AM #1
    1987 Scirocco 16V
    9A Swap, finishing up now
    Raceland header
    OBX muffler
    Test pipe
    Eurosport wires
    Eurospec flywheel
    Built long gear transmission with torsen LSD and bolt kit
    Custom rear trans mount, unbreakable, uses a poly control arm bushing and steel bracketry, eliminates need for front mount reinforcement
    H&R Sport springs
    Bilstein HD in front
    KYB GR-2 in rear
    AC/PS delete
    Tuned DPR on previous motor to run at 12.5:1 at WOT
    Recently replaced DS axle and radiator
    Just replaced heater outlet flange oring, valve cover gasket, oil pan gasket is going on within the week
    Includes (uninstalled)
    Kent aluminum adjustable cam gear
    ARP Head studs used once
    ACT pressure plate
    Broken odometer/Not original gauge cluster
    Has 160MPH speedo, but clock doesnt work
    Has some rust around arch on rear PS side, slight scrape on plastic arches on PS side, dent on fender/door on DS
    Sunroof leaks/missing parts because some ******* tried to break in to the car through it, i've also replaced both the door and quarter glass on the DS, lol, sunroof is ziptied shut and currently has duct tape sealing it
    Needs o2 sensor/bung installed
    Rear bumper skin is missing, but i have a spare i just need to dig it out of storage
    DS Cabriolet seat sits high but has no rips, matches passenger side pattern
    I'm wanting a running/driving Scirocco I, with no major rust, that isnt missing a ton of parts. Considering the main appeal of this trade is how many aftermarket parts come with.installed on the car, and that i dont ask for any in return, i feel this is fair.
    I can do a little cash on top for nicer examples, would be best if we could meet half way and trade cars, would prefer to not have to drive over 500 miles. I am located in Louisville KY.
    I will take current pictures during the daylight tomorrow.
  2. Member SciroccoPowered's Avatar
    Jul 28th, 2011
    1987 Scirocco 16V
    05-08-2012 01:32 AM #2
    Cam gear and head studs no longer included, still looking for a decent mk1.
  3. Member rocconut's Avatar
    Feb 20th, 2004
    Montpelier VA
    16v Scirocco x 5 MKI GTI, MKII GTI 55 CHEVY
    05-08-2012 04:23 PM #3
    IM sent
  4. Member rocconut's Avatar
    Feb 20th, 2004
    Montpelier VA
    05-09-2012 08:26 PM #4
    Willing to sell outright?
    Price?
