Results 1 to 6 of 6
Thread: VR6 Exhaust smell questions
  1. Junior Member SlaveToCaffeine's Avatar
    Apr 20th, 2012
    Ohio
    1996 VW Golf GTI Verkürzt Reihenmotor
    05-02-2012 02:50 AM #1
    My exhaust smells rich and is lightly fogged and white in color. i dont think its a blown head gasket cause it doesnt smell sweet by any means.
    can anyone give a little imput as to why the exhaust may smell rich and what else causes it to "steam" per say.
    engine sounds great and healthy, has a little tick but nothing irregular for these
    could removing your air filter cause this? i would not imagine so but i dunno
    thanks in advance peeps.
    The Honda owner says "If I were a Vdub where would I be?"
    The VW owner replies "In front of that Honda no doubt."
    Oct 17th, 2011
    socal
    92 Corrado SLC (sold), 91 GTI VR6
    05-02-2012 05:01 AM #2
    Mine has no cat and it does this...
    DCI-VW
  3. 05-02-2012 09:09 AM #3
    I have the same problem, I have a 97 GTI vr6 na and same thing white smoke fills up the garage in like 2 mins. i would like to know if i can make it stop thanks.
  4. 05-02-2012 09:13 AM #4
    well antifreeeze is usually sweet smelly if ur valve seals are shot it will blow out white smoke with head gasket
    Sent from my iPhone using Tapatalk Reihenmotors
  5. Junior Member SlaveToCaffeine's Avatar
    Apr 20th, 2012
    Ohio
    05-02-2012 10:34 PM #5
    my exhaust is not sweet smelling, i was wondering if anything else besides condensation causes white steamy exhaust for a few minutes.
    and btw if anyone needs to know, the injectors tick like a mother f#$ker naturally. i had a master VW mechanic look at mine today and said its 100% natural and the engine is running mechanically perfect.
    "its definitely not a blow head gasket"
  6. Member
    Oct 18th, 2001
    CT
    '90 Corrado vr
    05-05-2012 07:59 AM #6
    are you loosing coolant? have you checked the oil cap and oil? you wont neccessarily smell a sweetness from the exhaust. does it smell like burned oil or gas? could be a leaking valve seal, bad headgasket or leaking injector depending on the color/smell of the smoke. have you 'palm checked' the tailpaipe? while its running and smoking cup your hand over the exhaust for a few seconds and see what deposits onto your hand, you can usually tell the odor and if its water gas or oil.
