Results 1 to 9 of 9
Thread: Best oil for 1.8t?
  1. Member codergfx's Avatar
    Jan 10th, 2009
    Cali
    03 GTI GT3076r
    05-02-2012 09:57 AM #1
    Here at work we use castrol 5w40 on all of our Vw vehicles. But I'm running a bigger turbo so what would be good oil to use? And I live in california.
    MY BUILD | 2003 Volkswagen GTI 1.8T | CTT - Carrot Top Tuning - GT3076r, 3" to 2.5" turboback exhaust (vbanded), Tial 38mm wastegate, fx400 6 puck, Peloquin LSD, VF Poly Engine Mounts, Greddy Profec B Type II, walbro 255 inline fuel pump, ID1600cc @ 3bar running on e85. AMB head, AWD bottom end. 424whp 369wtq @ 30psi (OLD: 383 whp 333wtq @ 23 psi)
  2. 05-02-2012 01:54 PM #2
    All matters is the oil temp. 5w-40 / A3 / VW 502 have a built-in margin for excessive oil temps. So, if you don't exceed +120c you still have thick enough oil at 10cSt, which is the SAME as 5w-30 at +100c, normal op temp.
    http://www.widman.biz/English/Calculators/Graph.html
    See, in reality we can get around on thinner 5w-30, and that's what they use now in Europe.
    VW Specific:
    Syntec 5w-40 is an OLD formula, high magnesium. There are better options, starting with Rotella 5w-40. HD diesel oils change and improve their formulas constantly, while Euro spec oils are locked into formulas that can be a decade old.
    idk where to begin, but maybe you should try used oil lab reporting, I use Caterpillar and it's cheap. I went with Edge 5w-30 last winter and it did great in my APR 2.0 TSI manual, and it's no slouch. Here, it's the best 1.8t UOA I ever saw...
    The heaviest 40 weight I know of is Mobil 1 10w-40 HIGH MILES, HT/HS around 4.1cP and a ****load of additives, inc newer ones like Boron and Antimony, some oils sport Titanium add packs too, the Conoco brands and the new Edge. The other grades of Mobil 1 HiMiles are excellent too, inc a rare A3 10w-30. Basically, formulated like a race oil.
    VW 502 isn't special, at all. Same parameters as the generic ACEA A3 sequence. Basicaly, High-Temp/High-Shear rating at +150c >3.5cP, 30 weight oils are 2.9cP for comparison.
    A3 rated...
    Nov 10th, 2010
    mid hudson valley
    02 jetta wagon 1.8t, 03 passat 1.8,06 jetta 20t
    05-02-2012 02:19 PM #3
    just wondering why you did'nt use the 2005 502 spider graph.
  4. 05-02-2012 04:04 PM #4
    Just wondering why you used nothing at all, not even intellect.
    Nov 10th, 2010
    mid hudson valley
    05-03-2012 06:43 AM #5
    Quote Originally Posted by Apexxx View Post
    you start extolling the virtues of 5w-40 502 certified oils and end extolling the virtues of 5w-30. at least you didn't suggest m1 high miles in 10w-40, a great earl, just not for turbo's.
  6. Member
    Nov 10th, 2010
    mid hudson valley
    05-03-2012 06:45 AM #6
    you're great at answering yourself or going off topic to point your supposed superiority.
  7. Junior Member
    Jan 26th, 2012
    Central NJ
    2011 Audi Q5 3.2; 2004 Subaru Forester XT; 2013 TTS Oolong Gray P+
    05-11-2012 03:43 PM #7
    Syntec is API SM and Rotella 5W-40 is API SM. They both contain high magnesium. Post a VOA of each for us to compare.
    I agree that Rotella would probably be a good choice in this application with its thicker kinematic viscosity at 100C, higher High Temp High Shear Viscosity, and higher amount of ZDDP.
  8. 05-12-2012 12:56 AM #8
    API really only limits zink and Mg in 20 and 30 weight oils. Heavier grades don't have a low add cap on them, so the formula is basically "grandfathered" in.
    Take 20w-50 for example, API clears them for SM spec with a higher cap...no need really to develop new formulas and standards anyway, since the product is obsoleted. The API arrangement seems just for labeling's sake, so there is relative continuity across the product line.
  9. 05-15-2012 04:57 PM #9
    just go with Mobile 1 10w40 for summer or 0w40 , http://youtu.be/j0dK697diHo also you make like this tool for oil changes i got one on ebay under pk710 funnel worth a money
