Results 1 to 15 of 15
Thread: Wet Weather VRT Miss (not coil pack)
  1. Member vdubgti2.0's Avatar
    Apr 3rd, 2005
    Summer in March, WI
    '02 Z71, '97 GTI
    05-02-2012 10:07 AM #1
    Alright this one has me stumped so I figured I would turn to the folks that know it all. The car specs are below. I am getting a hard miss in wet weather, but only when I try to get into boost. The car will operate fine if I keep it under 3000 rpm and out of boost. Once I try to build any psi it will completely cut out. It feels like it completely cuts spark all together. I have replaced the coil pack (have also swapped it out with others before), swapped out the throttle body and MAF. All of this without any change. Anyone have any ideas? maybe timing backing down due to bad cam sensor?
    '96 Passat
    2.8L VR with a T04E
    C2 42# software
    Air to Water IC w/ recirculated DV
    Schimmel SRI
    TT 268* cams
    Quote Originally Posted by djshortbus1.8T View Post
    That's Scooter for ya, inspiring vw owners since 2006!
    5th Annual Scooter's GTG European Car Show Saturday June 8th 2013 Milwaukee, WI
    www.scootersgtg.webs.com
    http://forums.vwvortex.com/showthrea...9#post81393169
  2. Member zoidmk5's Avatar
    Sep 16th, 2006
    SoMD
    4.6L 44V 10 Cylinder Turbo
    05-02-2012 01:28 PM #2
    Quote Originally Posted by vdubgti2.0 View Post
    '96 Passat
    2.8L VR with a T04E
    C2 42# software
    Schimmel SRI
    TT 268* cams
    what does it do in the dry?
    ***PM me for VAGCOM services in the SOMD/VA area***
    Buy my MKIV GLI 24V
    Quote Originally Posted by lugnuts View Post
    And I'm just letting you know that you don't know entirely what you are talking about.
  3. Member vdubgti2.0's Avatar
    Apr 3rd, 2005
    Summer in March, WI
    '02 Z71, '97 GTI
    05-02-2012 02:42 PM #3
    runs like a raped ape, if it is dry out it runs perfectly normal. Once it is raining out it go nuts.
  4. Member zoidmk5's Avatar
    Sep 16th, 2006
    SoMD
    05-02-2012 03:17 PM #4
    than it's clearly something electrical. get a VAGCOM log and post it up
    Buy my MKIV GLI 24V
  5. Member djshortbus1.8T's Avatar
    Mar 20th, 2003
    Milwaukee, WI
    05-02-2012 03:35 PM #5
    I know a guy that has a Vagcom
  6. Member vdubgti2.0's Avatar
    Apr 3rd, 2005
    Summer in March, WI
    '02 Z71, '97 GTI
    05-02-2012 04:02 PM #6
    I do not feel that it is plugs, wires, or coil due to it feeling like all the cylinders are down and out. I am leaning more towards cam position or a knock sensor. Any thoughts?
  7. Member zoidmk5's Avatar
    Sep 16th, 2006
    SoMD
    05-02-2012 04:30 PM #7
    can't make that assumption without an accurate VAGCOM scan, or a simple Ohm meter to check on the voltage being sent to it. possibly a break in a wire that is causing an interuption when moisture is exposed
    Buy my MKIV GLI 24V
  8. Member JoHnsVrT's Avatar
    Feb 1st, 2007
    union nj
    89 jetta carat, 90 gti vrt
    05-02-2012 06:28 PM #8
    sounds like a engine speed sensor
    67mm - vrt
    mad slow
  9. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    96 GTI VR6 08 Hyundai Santa Fe SE
    05-02-2012 06:52 PM #9
    Quote Originally Posted by JoHnsVrT View Post
    Make sure all the environmental seals are in the connectors.
    98 GTI - Mustard Mayhem - 1/4 - 11.679@117.58mph - .8 bar - parted Timeslip
    96 GTI - Turbo Panda - 1/8 - 7.63@97mph - 1.1 bar of turbo fun!
    89 325is - New turbo project
    www.lugtronic.com
  10. Member
    Sep 20th, 2004
    se pdx
    87abat drag gti, 95 jetta beater
    05-02-2012 09:04 PM #10
    where does your intake sit, i ask this because i fixed my same exactly problem by moving my intake up out of the fender well. up into the bay so water could not get to it.
    if it was electrical it would miss even out of boost, i replaced my coil thinking the same thing, but then i got home on a wet day poped the hood there was no water on the coil, distributor, or plug wires, took the intake off and had water up in the maf sensor. cleaned it and put it under the hood and its doing great in the wet now.
  11. Member
    Sep 20th, 2004
    se pdx
    05-02-2012 09:05 PM #11
    also what does your wide band say when you get into boost, mine would go to 10-1 or richer which was flooding the car making it feel like a ignition cut.
  12. Member vdubgti2.0's Avatar
    Apr 3rd, 2005
    Summer in March, WI
    '02 Z71, '97 GTI
    05-03-2012 03:04 PM #12
    Ginsterman would an OBD2 car have this sensor? I cannot remember ever seeing one. If so I can check it out. I am going to replace the wires when they come in and the plugs tonight.
    The intake is located on the frame rail, it is an AEM filter with there hydro shield deal. I have not looked into the intake after it has missed or ran poorly to see if I can getting water on the MAF but it is a good idea.
    I appreciate the help with this.
  13. Member GinsterMan98's Avatar
    May 19th, 2008
    Panama City FL
    05-03-2012 06:42 PM #13
    White connector on top of the front motor mount.
    www.lugtronic.com
  14. Member vdubgti2.0's Avatar
    Apr 3rd, 2005
    Summer in March, WI
    '02 Z71, '97 GTI
    05-04-2012 11:15 AM #14
    New wires come in on Wed, if that does not cure it I will check that out. Thanks again
  15. Member Zupek's Avatar
    May 10th, 2000
    Hell has frozen over, WI
    2000 Stage 3+ Audi S4, 1998 24v 3.1L Syncro'd GTi w/ 6speed quaife add-on, 1988 Quantum Syncro Wagon
    05-08-2012 01:03 PM #15
    Out of curiosity, do you have a Limited Slip? Do your tires suck in water? maybe they are breaking loose immediately? beyond that, I would think that its your Engine Speed/Crank Speed sensor, it looks just like the knock sensor, but it's in the front. It's easier if you just jack it up. If the wire and it's interefance coil is at all cut, that's most likely the problem. If it looks like, you are better off OHM testing it.
    My 24v 3.1L Syncro Mk3 build here
